VU+ Duo streamen via router naar M8S+ met pvr client. (in kodi)
hd1450
Klopt. De Netgear 1Gb switch helpt ook niet.
Toch jammer dat dit niet voldoende is:
CPU Amlogic S812 Quad Core Cortex A9 2.0 GHz
Google Android™ 4.4.2 Rooted
GPU Octo-Core Mali™ GPU up to 600MHz
FLASH 8GB NAND FLASH
RAM 2GB DDR3
3D Hardward 3D graphics acceleration
Lan - 1GB
Colour - Black
VUDU DRM Supporting and VUDU Supporting
Wireless Support Dual Band WIFI Support 802.11 a/b/g/n 2.4GHz/5.0GHz AP6330 Module
3G Support most external 3G USB dongle
User interface - Windows style
Support External Hard Disk drives 10GB to 2TB
Power Supply Specifications Power Supply DC 5V
Power Indicator (LED) Power ON:blue; Standby:Red
Bluetooth™ 4.0 Support
Decoder HD MPEG1/2/4,H.265/HEVC, HD AVC/VC-1,RM/RMVB,Xvid/DivX3/4/5/6 ,RealVideo8/9/10
Support Media Format AVI/RM/RMVB/TS/VOB/MKV/MOV/ISO/WMV/ASF/FLV/DAT/MPG/MPEG.
Support Audio Format MP3/WMA/AAC/WAV/OGG/AC3/DDP/TrueHD/DTS/DTS/HD/FLAC/APE
Support Photo Format HD JPEG/BMP/GIF/PNG/TIFF
Dolby DTS - Dolby True HD and DTS
USB Host 2 High Speed USB 2.0,Support U DISK And USB HDD
Card Reader SD/SDHC/MMC Cards (upto 32gb max)
HDD File System FAT32/NTFS/Ext3
Support Subtitle SRT/SMI/SUB/SSA/IDX+USB
High Definition Video Output Support All Standard SD/HD/4K2K Ultra HD Decoding And Output
OSD type of languages English/French/German/Spanish/Italian etc. Multilateral Languages
LAN Ethernet:10/100/1000m, Standard RJ-45
Mouse/Keyboard Support Mouse And Keyboard Via USB; Support 2.4GHz Wireless Mouse And Keyboard Via 2.4GHz USB Dongle
HDMI™ Plays or stream content in true 1080P HD up to 4K2K@30Hz,Support 3D
SPDIF/IEC958 Optical Digtal audio output
IPTV And OTT Support Many Kinds of IPTV And OTT Programmes
Interface - 2 * USB 2.0 HOST,1 * SD/MMC slot, 1 * RJ45 wire Ethernet connection, 1 * HDMI output, 1 * AV Output (Standard resolution AV), 1 * Optical output,1 * 5V DC port
Link naar reactie
Delen op andere sites
dat kan een specifiek toeval zijn in combinatie met je hardware, beste quattro
daar ging dit ook over
mede in samenhang mbt de asus router
met geen enkele VU+ heb ik zelf tot nog toe problemen gehad met streamen " in tha House "
overigens heeft Moderator Wiz in het verleden ook al eens een specifieke Switch voor ons geanalyseerd in samenhang met een slechte network throughput (die kon ik even niet vinden maar levert verhelderende inzichten)
vandaar dat er beslist een oplossing is
overigens nu en straks is dit belangrijk Support 2.4GHz Wireless
start je VU+ maar eens opnieuw op en voer via telnet het commando >dmesg< uit, dan weten we ook al een en ander
tenminste dat kun je uit de console zo in het forum per CODE <> in een bericht plakken
Eternal Alexander
Vangelis
Link naar reactie
  • 4 weken later...
Zo,
eindelijk weer eens tijd om te kijken of het nog gaat lukken.
Op aangeven van Tonskidutch in telnet  de opdracht dmesg gegeven. Het volgende kwam er uit:
Console: switching to colour dummy device 80x25
__clk_enable: network [1]
__clk_enable: enet [1]
bcm7552_pm_genet_enable 00
eth0 Link DOWN.
eth0 Link UP.
Auto config phy
eth0: Link is up, 100 Mbps Full Duplex
NET: Registered protocol family 10
eth0 Link DOWN.
eth0 cable unplugged, powering down
eth0 cable plugged in, powering up
eth0 Link UP.
Auto config phy
root@xp1000md:~# df -m; echo ">>> DONE <<<";
Filesystem           1M-blocks      Used Available Use% Mounted on
ubi0:rootfs                105        58        47  56% /
devtmpfs                   115         0       115   0% /dev
tmpfs                        0         0         0   0% /media
tmpfs                      115         0       115   0% /var/volatile
>>> DONE <<<
Hopelijk zegt dit iets.
Link naar reactie
Er staat meer in,maar dat kan ik niet kopieren op de 1 of andere manier. Hopelijk heb je hier wat aan.
Waar let je dan op? Ben ik erg benieuwd naar.
In ieder geval bedankt voor de moeite en tijd.
cm7335: hotplug_callback():
otplug - status.connected 1
otplug - status.connected 0
Link naar reactie
het ligt er een beetje aan wat voor telnet client je gebruikt
in windows is putty eigenlijk de favoriet
in linux ga je direct op 1:1 middels de console
in apple heb ik nu geen favoriet
maar met putty kun je de hele uitvoer van het commando dmesg kopieren en dan Op een Website in CODE <> via de volledige editor invoegen.
maar plukkies zoals bovenstaand ga ik niet bekijken, is ook erg oninteressant
Eternal Alexander
Vangelis
Link naar reactie
  • 2 weken later...
ja dat is begrijpelijk als je niet doorgewinterd in dit soort aspecten bent dat je een en ander nog niet weet.
putty is een programm voor windows dat kan helpen om indien je een telnet verbinding aangaat met je VU+ receiver heel veel kwesties makkelijker kunt regelen , simpelgezegd een goede console voor telnet commando's en editor tegelijkertijd.
als je bepaalde gegevens highlight hebt in post 18
en als je een deel van de gegevens kunt oproepen waar ik om vroeg in post 21
dan vraag ik me af wat je specifiek zoekt in vraag post 23
een enigma2 programma ken ik niet
back to topic
desondanks is de oude VU+ DUO prima te streamen en dat kun je eenvoudig zien door het webinterface van de duo op te roepen en op de zenderlijst te gaan
aldaar aangekomen klik je op het TV ikoontje van een zender en je krijgt een werkende stream te zien (onder firefox loopt dat altijd) en VLC.exe ( Full met Firefox addon ) ook op windows geinstalleerd
bovendien zie je daar ook welke url der gebruikt wordt per zender kun je daar een lijst ja van maken
aangepast door Tonskidutch
Eternal Alexander
Vangelis
Link naar reactie
  • 2 maanden later...
Bedankt voor alle info. VLC werkt hier nu ook prima.
Ben inmiddels overgestapt naar een andere internet provider (Om een heel andere reden), en wat schetst mijn verbazing?
Nu geen stotterend beeld meer als ik vu+ kijk via kodi.
Link naar reactie
dat is inderdaad verbazingwekkend daar een ISP eigenlijk niets met je LAN te maken zou mogen hebben,
die router ethernet poorten zijn nu wellicht selfsensing en automatisch instelbaar
zou voor de lezers wat kunnen betekenen om te weten wat u voorheen had en wat u nu heeft
Eternal Alexander
Vangelis
Link naar reactie
