cassius4388
28 -
Berichten die geplaatst zijn door cassius4388
Delta Oscam
in OSCam
Dezelfde foutmelding "dynamic RSA init or"
Is CCcam geen optie. Schijnt dat daar die RSA ingebakken zit?
Delta Oscam
in OSCam
Dat zou een hoop verklaren. Maar daar is niet achter te komen zeker?
Delta Oscam
in OSCam
Ik heb zoveel lopen veranderen dat ik het niet meer weet. Ik zal hem veranderen.
- 2020/04/20 13:08:16 6D904F0C c (client) plain dvbapi-client granted (dvbapiau, au=auto (3 reader))
- 2020/04/20 13:08:16 6D904F0C c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam-emu/oscam.ccache
- 2020/04/20 13:08:16 6D904F0C c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
- 2020/04/20 13:09:11 6D904F0C c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0604 ECM_PID: 0032 PROVID: 000000
- 2020/04/20 13:09:11 6D904F0C c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0618 ECM_PID: 0064 PROVID: 000000
- 2020/04/20 13:09:11 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in caPMT
- 2020/04/20 13:09:11 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 13:09:11 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in PMT
- 2020/04/20 13:09:12 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:B8E5FA35E6870BD99C312731C9ECE691): not found (145 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 13:09:12 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
Delta Oscam
in OSCam
De newcamd is eruit en dvbapi erin
Delta Oscam
in OSCam
- 2020/04/20 12:47:44 00000000 s (main) Host name = lc
- 2020/04/20 12:47:44 00000000 s (main) Release = 4.10.12
- 2020/04/20 12:47:44 00000000 s (main) Version = #1 Thu May 17 09:25:59 CEST 2018
- 2020/04/20 12:47:44 00000000 s (main) Machine = mips
- 2020/04/20 12:47:44 00000000 s (main) Stb model = lc
- 2020/04/20 12:47:44 00000000 s (main) Stb boxtype = lc
- 2020/04/20 12:47:44 00000000 s (main) creating pidfile /tmp/oscam-emu.pid with pid 28128
- 2020/04/20 12:47:44 00000000 s (emu) OSCam-Emu version 786
- 2020/04/20 12:47:44 00000000 s (config) userdb reloaded: 2 accounts loaded, 0 expired, 1 disabled
- 2020/04/20 12:47:44 00000000 s (main) signal handling initialized
- 2020/04/20 12:47:44 00000000 s (config) 11 provid's loaded
- 2020/04/20 12:47:44 00000000 s (config) 168 service-id's loaded in 3 ms
- 2020/04/20 12:47:44 00000000 s (reader) Delta [internal] creating thread for device /dev/sci0
- 2020/04/20 12:47:44 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
- 2020/04/20 12:47:44 00000000 s (main) waiting for local card init
- 2020/04/20 12:47:44 4E633E30 r (reader) Delta [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=5.40 MHz)
- 2020/04/20 12:47:44 4E633E30 r (reader) Delta [internal] Reader sci internal, detected box type: lc
- 2020/04/20 12:47:44 41955431 h (webif) webif: decompressed 179686 bytes back into 443792 bytes
- 2020/04/20 12:47:44 41955431 h (webif) HTTP Server running. ip=:: port=8888
- 2020/04/20 12:47:45 4E633E30 r (reader) Delta [internal] card detected
- 2020/04/20 12:47:48 4E633E30 r (reader) Delta [internal] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 37 2E 30 9F
- 2020/04/20 12:47:51 4E633E30 r (reader) Delta [internal] Buffers readed 0 bytes total time_us 3023807
- 2020/04/20 12:47:53 4E633E30 r (reader) Delta [internal] detect irdeto card
- 2020/04/20 12:47:53 4E633E30 r (reader) Delta [internal] Irdeto SC 70 version 2 revision 0, patch level 1
- 2020/04/20 12:47:53 4E633E30 r (reader) Delta [internal] caid: 0618, acs: 0.06, country code: NLD
- 2020/04/20 12:47:53 4E633E30 r (reader) Delta [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [internal] active providers: 4 (xxxxxx,ffffff,ffffff,ffffff)
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [internal] found card system irdeto
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] entitlements for provider: 1, id: xxxxxx
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 000F, date: 2019/01/10 - 2019/01/25
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 006E, date: 2020/04/15 - 2020/05/16
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 0070, date: 2020/04/16 - 2020/05/17
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 006F, date: 2020/04/15 - 2020/05/16
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 7FFD, date: 2020/04/17 - 2020/04/27
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: 7FFE, date: 2020/04/17 - 2020/05/17
- 2020/04/20 12:47:56 4E633E30 r (reader) Delta [irdeto] chid: FFD8, date: 2020/04/17 - 2020/05/17
- 2020/04/20 12:48:01 4E633E30 r (reader) Delta [irdeto] ready for requests
- 2020/04/20 12:48:02 00000000 s (main) init for all local cards done
- 2020/04/20 12:48:02 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 1 ms
- 2020/04/20 12:48:02 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
- 2020/04/20 12:48:02 00000000 s (anticasc) anti cascading disabled
- 2020/04/20 12:48:02 6D904F0C c (client) plain dvbapi-client granted (dvbapiau, au=off)
- 2020/04/20 12:48:02 6D904F0C c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam-emu/oscam.ccache
- 2020/04/20 12:48:02 6D904F0C c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
- 2020/04/20 12:48:52 6D904F0C c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0604 ECM_PID: 0032 PROVID: 000000
- 2020/04/20 12:48:52 6D904F0C c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0618 ECM_PID: 0064 PROVID: 000000
- 2020/04/20 12:48:52 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in caPMT
- 2020/04/20 12:48:52 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:52 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in PMT
- 2020/04/20 12:48:52 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (143 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 12:48:53 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:53 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:53 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (5 ms) by Delta - RTL4 HD
- 2020/04/20 12:48:54 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:54 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:54 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:48:54 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:55 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:48:55 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:55 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:56 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (5 ms) by Delta - RTL4 HD
- 2020/04/20 12:48:56 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:56 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:57 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (5 ms) by Delta - RTL4 HD
- 2020/04/20 12:48:57 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:57 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:58 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:2959747612E8B2658BC6747138141EDE): not found (141 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 12:48:58 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:48:58 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:48:59 6D904F0C c (dvbapi) Demuxer 0 stop descrambling program number 02C1 (RTL4 HD)
Hier is hij verwijderd.
Delta Oscam
in OSCam
- 2020/04/20 12:40:25 00000000 s (main) Host name = lc
- 2020/04/20 12:40:25 00000000 s (main) Release = 4.10.12
- 2020/04/20 12:40:25 00000000 s (main) Version = #1 Thu May 17 09:25:59 CEST 2018
- 2020/04/20 12:40:25 00000000 s (main) Machine = mips
- 2020/04/20 12:40:25 00000000 s (main) Stb model = lc
- 2020/04/20 12:40:25 00000000 s (main) Stb boxtype = lc
- 2020/04/20 12:40:25 00000000 s (main) creating pidfile /tmp/oscam-emu.pid with pid 27223
- 2020/04/20 12:40:25 00000000 s (emu) OSCam-Emu version 786
- 2020/04/20 12:40:25 00000000 s (config) userdb reloaded: 2 accounts loaded, 0 expired, 1 disabled
- 2020/04/20 12:40:25 00000000 s (main) signal handling initialized
- 2020/04/20 12:40:25 00000000 s (config) 11 provid's loaded
- 2020/04/20 12:40:25 00000000 s (config) 168 service-id's loaded in 3 ms
- 2020/04/20 12:40:25 00000000 s (net) cs378x: initialized (fd=3, port=12005)
- 2020/04/20 12:40:25 00000000 s (net) newcamd: initialized (fd=4, port=15050)
- 2020/04/20 12:40:25 00000000 s (net) -> CAID: 0618 PROVID: xxxxxx
- 2020/04/20 12:40:25 00000000 s (reader) Delta [internal] creating thread for device /dev/sci0
- 2020/04/20 12:40:25 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
- 2020/04/20 12:40:25 00000000 s (main) waiting for local card init
- 2020/04/20 12:40:25 257D80FE r (reader) Delta [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=5.40 MHz)
- 2020/04/20 12:40:25 257D80FE r (reader) Delta [internal] Reader sci internal, detected box type: lc
- 2020/04/20 12:40:25 4E633E30 h (webif) webif: decompressed 179686 bytes back into 443792 bytes
- 2020/04/20 12:40:25 4E633E30 h (webif) HTTP Server running. ip=:: port=8888
- 2020/04/20 12:40:26 257D80FE r (reader) Delta [internal] card detected
- 2020/04/20 12:40:29 257D80FE r (reader) Delta [internal] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 37 2E 30 9F
- 2020/04/20 12:40:32 257D80FE r (reader) Delta [internal] Buffers readed 0 bytes total time_us 3023791
- 2020/04/20 12:40:34 257D80FE r (reader) Delta [internal] detect irdeto card
- 2020/04/20 12:40:34 257D80FE r (reader) Delta [internal] Irdeto SC 70 version 2 revision 0, patch level 1
- 2020/04/20 12:40:34 257D80FE r (reader) Delta [internal] caid: 0618, acs: 0.06, country code: NLD
- 2020/04/20 12:40:34 257D80FE r (reader) Delta [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [internal] active providers: 4 (04abc4,ffffff,ffffff,ffffff)
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [internal] found card system irdeto
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] entitlements for provider: 1, id: xxxxxx
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 000F, date: 2019/01/10 - 2019/01/25
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 006E, date: 2020/04/15 - 2020/05/16
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 0070, date: 2020/04/16 - 2020/05/17
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 006F, date: 2020/04/15 - 2020/05/16
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 7FFD, date: 2020/04/17 - 2020/04/27
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: 7FFE, date: 2020/04/17 - 2020/05/17
- 2020/04/20 12:40:37 257D80FE r (reader) Delta [irdeto] chid: FFD8, date: 2020/04/17 - 2020/05/17
- 2020/04/20 12:40:42 257D80FE r (reader) Delta [irdeto] ready for requests
- 2020/04/20 12:40:42 00000000 s (main) init for all local cards done
- 2020/04/20 12:40:42 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 0 ms
- 2020/04/20 12:40:42 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
- 2020/04/20 12:40:42 00000000 s (anticasc) anti cascading disabled
- 2020/04/20 12:40:42 6D904F0C c (client) plain dvbapi-client granted (dvbapiau, au=off)
- 2020/04/20 12:40:42 6D904F0C c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam-emu/oscam.ccache
- 2020/04/20 12:40:42 6D904F0C c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
- 2020/04/20 12:41:01 6D904F0C c (dvbapi) Demuxer 0 ecmpid 0 CAID: 0604 ECM_PID: 0032 PROVID: 000000
- 2020/04/20 12:41:01 6D904F0C c (dvbapi) Demuxer 0 ecmpid 1 CAID: 0618 ECM_PID: 0064 PROVID: 000000
- 2020/04/20 12:41:01 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in caPMT
- 2020/04/20 12:41:01 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:01 6D904F0C c (dvbapi) Demuxer 0 found 2 ECMpids and 6 STREAMpids in PMT
- 2020/04/20 12:41:02 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (152 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 12:41:02 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:02 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:03 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (6 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:03 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:03 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:03 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:04 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:04 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:04 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:05 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (5 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:05 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:05 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:06 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (15 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:06 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:06 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:07 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:08 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:08 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:08 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (136 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 12:41:09 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:09 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:09 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:E23022AA4DB4FC00955CDB5ADE3D2558): not found (8 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:10 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 0 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:10 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:10 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:B6BE4548BF7679EF62C9635CD7AC40F9): not found (137 ms) by Delta - RTL4 HD (Delta dynamic RSA init or )
- 2020/04/20 12:41:11 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:11 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:11 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:B6BE4548BF7679EF62C9635CD7AC40F9): not found (4 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:12 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:12 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:12 6D904F0C c (ecm) dvbapiau (0618@000000/0000/02C1/50:B6BE4548BF7679EF62C9635CD7AC40F9): not found (12 ms) by Delta - RTL4 HD
- 2020/04/20 12:41:13 6D904F0C c (dvbapi) Demuxer 0 restarting decodingrequests after 1 ms with 1 enabled and 1 disabled ecmpids!
- 2020/04/20 12:41:13 6D904F0C c (dvbapi) Demuxer 0 trying to descramble PID 1 CAID 0618 PROVID 000000 ECMPID 0064 ANY CHID PMTPID 02EE VPID 02EF
- 2020/04/20 12:41:13 6D904F0C c (dvbapi) Demuxer 0 stop descrambling program number 02C1 (RTL4 HD)
Hij stond inderdaad niet goed.
Delta Oscam
in OSCam
Geprobeerd zelfde resultaat
Delta Oscam
in OSCam
- 2020/04/19 12:32:11 00000000 s (main) Host name = lc
- 2020/04/19 12:32:11 00000000 s (main) Release = 4.10.12
- 2020/04/19 12:32:11 00000000 s (main) Version = #1 Thu May 17 09:25:59 CEST 2018
- 2020/04/19 12:32:11 00000000 s (main) Machine = mips
- 2020/04/19 12:32:11 00000000 s (main) Stb model = lc
- 2020/04/19 12:32:11 00000000 s (main) Stb boxtype = lc
- 2020/04/19 12:32:11 00000000 s (main) creating pidfile /tmp/oscam-emu.pid with pid 18986
- 2020/04/19 12:32:11 00000000 s (emu) OSCam-Emu version 786
- 2020/04/19 12:32:11 00000000 s (config) userdb reloaded: 2 accounts loaded, 0 expired, 1 disabled
- 2020/04/19 12:32:11 00000000 s (main) signal handling initialized
- 2020/04/19 12:32:12 00000000 s (config) 11 provid's loaded
- 2020/04/19 12:32:12 00000000 s (config) 168 service-id's loaded in 3 ms
- 2020/04/19 12:32:12 00000000 s (net) cs378x: initialized (fd=3, port=12005)
- 2020/04/19 12:32:12 00000000 s (net) newcamd: initialized (fd=4, port=15050)
- 2020/04/19 12:32:12 00000000 s (net) -> CAID: 0618 PROVID: xxxxxx
- 2020/04/19 12:32:12 00000000 s (reader) Delta [internal] creating thread for device /dev/sci0
- 2020/04/19 12:32:12 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
- 2020/04/19 12:32:12 00000000 s (main) waiting for local card init
- 2020/04/19 12:32:12 4E633E30 r (reader) Delta [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=5.40 MHz)
- 2020/04/19 12:32:12 4E633E30 r (reader) Delta [internal] Reader sci internal, detected box type: lc
- 2020/04/19 12:32:12 41955431 h (webif) webif: decompressed 179686 bytes back into 443792 bytes
- 2020/04/19 12:32:12 41955431 h (webif) HTTP Server running. ip=:: port=8888
- 2020/04/19 12:32:13 4E633E30 r (reader) Delta [internal] card detected
- 2020/04/19 12:32:16 4E633E30 r (reader) Delta [internal] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 37 2E 30 9F
- 2020/04/19 12:32:19 4E633E30 r (reader) Delta [internal] Buffers readed 0 bytes total time_us 3023717
- 2020/04/19 12:32:21 4E633E30 r (reader) Delta [internal] detect irdeto card
- 2020/04/19 12:32:21 4E633E30 r (reader) Delta [internal] Irdeto SC 70 version 2 revision 0, patch level 1
- 2020/04/19 12:32:21 4E633E30 r (reader) Delta [internal] caid: 0618, acs: 0.06, country code: NLD
- 2020/04/19 12:32:21 4E633E30 r (reader) Delta [internal] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [internal] WARNING: For Irdeto cards you will have to set 'mhz= 600' in oscam.server
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [internal] active providers: 4 (xxxxxxffffff,ffffff,ffffff)
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [internal] found card system irdeto
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max alloted of 1
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] entitlements for provider: 1, id: xxxxxx
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 000F, date: 2019/01/10 - 2019/01/25
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 006E, date: 2020/04/15 - 2020/05/16
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 0070, date: 2020/04/16 - 2020/05/17
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 006F, date: 2020/04/15 - 2020/05/16
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 7FFD, date: 2020/04/17 - 2020/04/27
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: 7FFE, date: 2020/04/17 - 2020/05/17
- 2020/04/19 12:32:24 4E633E30 r (reader) Delta [irdeto] chid: FFD8, date: 2020/04/17 - 2020/05/17
- 2020/04/19 12:32:29 4E633E30 r (reader) Delta [irdeto] ready for requests
- 2020/04/19 12:32:29 00000000 s (main) init for all local cards done
- 2020/04/19 12:32:29 00000000 s (emmcache) loaded 0 emmcache records from /tmp/.oscam/oscam.emmcache in 1 ms
- 2020/04/19 12:32:29 00000000 s (emmcache) loaded 0 emmstat records from /tmp/.oscam/oscam.emmstat in 0 ms
- 2020/04/19 12:32:29 00000000 s (anticasc) anti cascading disabled
- 2020/04/19 12:32:29 6D904F0C c (client) plain dvbapi-client rejected (dvbapi disabled account)
- 2020/04/19 12:32:29 6D904F0C c (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam-emu/oscam.ccache
- 2020/04/19 12:32:29 6D904F0C c (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 1 maximum amount of possible filters is 32 (oscam limit is 32)
- 2020/04/19 12:32:29 6D904F0C c (dvbapi) PMT6: Trying connect to enigma CA PMT listen socket...
- 2020/04/19 12:32:29 6D904F0C c (dvbapi) PMT6 CA PMT Server connected on fd 11!
- 2020/04/19 12:32:45 6EBD3E2B c (newcamd) client connected to 15050 port
- 2020/04/19 12:32:45 6EBD3E2B c (client) encrypted newcamd:15050-client 192.168.11.67 granted (user1, au=on (1 reader))
- 2020/04/19 12:32:45 6EBD3E2B c (newcamd) user user1 authenticated successfully (ACamd)
- 2020/04/19 12:32:45 6EBD3E2B c (newcamd) AU enabled for user user1 on reader Delta
- 2020/04/19 12:32:45 6EBD3E2B c (ecm) user1 (0618@xxxxxx/0000/61AB/50:04237C7132ECB13BBB881AF3282F3ED0): not found (124 ms) by Delta (Delta dynamic RSA init or )
- 2020/04/19 12:32:45 6EBD3E2B c (ecm) user1 (0618@xxxxxx/0000/61AB/50:04237C7132ECB13BBB881AF3282F3ED0): not found (2 ms) by Delta
Dit is een volledig log als ik een gecodeerd kanaal afstem. ID's zijn weggehaald.
Volgens mij heeft het inderdaad met RSA te maken maar die zijn goed. Ik heb ze vergeleken met Daan.
Delta Oscam
in OSCam
Op de enigma2 tuner werkt het ook niet. Er is iets met de kaart. In een CI tv of ci+ tv doet hij het wel. Ik vind het heel vreemd.
Delta Oscam
in OSCam
Ik heb inmiddels getest met een enigma2 cardserver. Als ik (naar mijn weten) alles goed invul krijg ik weer fout melding:
user1 (0618@xxxxxx/0000/3E88/50:38875BFA1E11C1957316F68613CFE800): not found (186 ms) by Delta (Delta dynamic RSA init or )
xxxxxx heb ik zelf veranderd was mijn id
Delta Oscam
in OSCam
Delta Oscam
in OSCam
Ik heb verschillende echte smargos geprobeerd werken allemaal niet. Ik vermoed dat het komt omdat hij volgens het internet op t1 moet staan voor irdeto en standaard staat hij op t0 nu heb ik er geen één op t1 gekregen omdat die allemaal vast lopen met de setting tool op Windows 10. De Chinese werkt tot nu toe het beste ik krijg geen card error meer.
Delta Oscam
in OSCam
Welk protocol raad je aan? Phoenix staat er bij mij niet bij in oscam. Ik heb smargo ook geprobeerd.
Delta Oscam
in OSCam
Crystal Phoenix een chinese card reader. Het gekke is wel dat als ik de schakelaar op smardmouse zet dan werkt hij niet in oscam protocol mouse dan krijg ik error nu staat hij in Phoenix en dan werkt hij wel met oscam protocol mouse. Ik heb hiervoor al smargo's geprobeerd maar die werken helemaal niet.
Delta Oscam
in OSCam
ja zeker. krijg in oscam nu deze melding
- 2020/04/13 12:42:01 14E24D6F c (ecm) user1 (0618@000000/0000/61AB/50:533CFD4C8B6EE07BEDAF24414F1F043C): rejected group (0 ms) (no matching reader)
- 2020/04/13 12:42:12 14E24D6F c (ecm) user1 (0618@000000/0000/61AB/50:AE73EC4C039E0CD40F4FE2F8F68CF741): rejected group (0 ms) (no matching reader)
- 2020/04/13 12:42:23 14E24D6F c (ecm) user1 (0618@000000/0000/61AB/50:5E7901C87862357D40EE9AF00496F594): rejected group (0 ms) (no matching reader)
Delta Oscam
in OSCam
Ik heb ze alle twee weg gehaald zonder effect...
Delta Oscam
in OSCam
Delta Oscam
in OSCam
Emulator staat uit. Ik zal zo mijn oscam.server posten (zonder keys) alleen mijn internet ligt er constant uit. Met dank aan T-Mobile....
Delta Oscam
in OSCam
26 minuten geleden, Tonskidutch zei:doe dat nou eens zonder een client, dan weet je waarom vreemde channelID's verschijnen
Hoe bedoel je dat precies? Dank je voor het mee denken.
Delta Oscam
in OSCam
Delta Oscam
in OSCam
#NEXT#
C:\Program Files (x86)\DVBLogic\DVBLink\sources\TVSource-1\plugins\ACamd.dll
Blocked 1 same messages...
07:09:54.987: Ch: 300 - BBC First HD
07:09:54.987: Programm crc: 2CE56AC3
07:09:54.989: PMT: ACamd_PMT.txt, search, not found PMT=012C (AND SID=61AB)
07:09:54.989: 0x012C 0x61AB 0x0618 0x00000000 0x0066 0x0031 11111110
07:09:55.140: Incomming PackageSize [184]
07:09:55.303: Login attemp (1)
07:09:55.303: connecting to 127.0.0.1:15050/tcp (127.0.0.1)
07:09:55.456: Newcamd 0: CaID=0618 admin=1 srvUA=000000001600A654 provider 000004/0000000000000000 000003/0000000001FFFFFF 000002/0000000001FFFFFF 000001/0000000001FFFFFF 000000/000000000004ABC4
07:09:55.456: 0: chid 0000*
07:09:55.593: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.137)
07:09:55.593: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:09:55.621: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.001)
07:09:55.621: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:10:00.447: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.131)
07:10:00.447: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:10:11.435: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.130)
07:10:11.435: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:14:43.444:
07:14:43.444: Ch: 300 - BBC First HD
07:14:43.444: Programm crc: 2CE56AC3
07:14:43.445: PMT: ACamd_PMT.txt, search, not found PMT=012C (AND SID=61AB)
07:14:43.445: 0x012C 0x61AB 0x0618 0x00000000 0x0066 0x0031 11111110
07:14:43.737: 0: chid 0000*
07:14:43.737: socket: write failed: Winsock Error 10054: Connection reset by peer.
07:14:43.737: send error. reconnecting...
07:14:43.737: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.000)
07:14:43.737: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:14:46.322: Login attemp (1)
07:14:46.323: connecting to 127.0.0.1:15050/tcp (127.0.0.1)
07:14:46.337: Newcamd 0: CaID=0618 admin=1 srvUA=000000001600A654 provider 000004/0000000000000000 000003/0000000001FFFFFF 000002/0000000001FFFFFF 000001/0000000001FFFFFF 000000/000000000004ABC4
07:14:46.468: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.131)
07:14:46.468: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:14:46.627: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.002)
07:14:46.627: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:14:57.455: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.130)
07:14:57.455: Newcamd 0: ECM [0066][0618/00000000] not able to decode
07:15:08.452: Newcamd 0: ECM [0066][0618/00000000] Pro, CHID=0000 (0.126)
07:15:08.452: Newcamd 0: ECM [0066][0618/00000000] not able to decode
Delta Oscam
in OSCam
ik weet het wel trouwens daan zegt dat ze goed zijn
Delta Oscam
in OSCam
Nee die staan erin en volgens mij de goeie weet het niet 100%
Delta Oscam
in OSCam
ik ben inmiddels wat verder. Ik gebruik dvblink als tv server software en acamd als plugin. acamd maakt nu verbinding met oscam maar oscam geeft de volgende melding:
- 020/04/11 15:32:36 5076B0F2 c (ecm) user1 (0618@000000/0000/006C/50:E2E847A4FA7B2E3CE7E01139D0FED4DC): not found (125 ms) by reader (reader dynamic RSA init or)
- 2020/04/11 15:32:36 5076B0F2 c (ecm) user1 (0618@000000/0000/006C/50:E2E847A4FA7B2E3CE7E01139D0FED4DC): not found (1 ms) by reader
- 2020/04/11 15:32:47 5076B0F2 c (ecm) user1 (0618@000000/0000/006C/50:F4A241A69D3FAB14CC0F4EC52248FD4E): not found (131 ms) by reader (reader dynamic RSA init or)
- 2020/04/11 15:32:58 5076B0F2 c (ecm) user1 (0618@000000/0000/006C/50:1EF43790B348C49F1EDC9CFC5C97AA11): not found (131 ms) by reader (reader dynamic RSA init or)
Voor de rest herkend hij wel de kaart en wacht op verzoeken.
Delta Oscam
in OSCam
Nou het werkt dankzij Daan door zijn config doet hij het in de enigma2 box. Ik heb een user aangemaakt voor de tv server en werkt ook eindelijk. Alleen de tweede keer deed hij het niet met foutmelding "not right ecm type" of zoiets. De derde keer deed hij het weer wel. Misschien nog eens naar kijken binnenkort. Is allemaal wat moeilijker doordat ik geen internet heb. Is hopelijk snel opgelost. Bedankt Daan!
