11 -
Berichten die geplaatst zijn door homeaion
14 hours ago, Zilverster said:
- 2021/10/14 15:01:45 5C0B5ED9 r (reader) Ziggo_SC [smartreader] Reader initialized (device=TripleP2;Serial:00000022, detect=cd, mhz=600, cardmhz=600)
- 2021/10/14 15:01:46 5C0B5ED9 r (reader) Ziggo_SC [smartreader] card detected
- 2021/10/14 15:01:53 5C0B5ED9 r (reader) Ziggo_SC [smartreader] ATR: 3B 9F 21 0E 49 52 44 45 54 4F 20 41 43 53 20 56 35 2E 38 95
- 2021/10/14 15:01:53 5C0B5ED9 r (reader) Ziggo_SC [smartreader] Effective reader settings mhz =600 F= 558 D= 1 N=0 T=14 inv=0 parity=NONE
- 2021/10/14 15:01:55 5C0B5ED9 r (reader) Ziggo_SC [smartreader] detect irdeto card
- 2021/10/14 15:01:55 5C0B5ED9 r (reader) Ziggo_SC [smartreader] Irdeto SC 58 version 21 revision 1, patch level e
- 2021/10/14 15:01:55 5C0B5ED9 r (reader) Ziggo_SC [smartreader] caid: 0604, acs: 0.05, country code: NLD
- 2021/10/14 15:01:55 5C0B5ED9 r (reader) Ziggo_SC [smartreader] providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
- 2021/10/14 15:02:00 5C0B5ED9 r (reader) Ziggo_SC [smartreader] Warning: needed try nr 2, next ECM has some delay
- 2021/10/14 15:02:04 5C0B5ED9 r (reader) Ziggo_SC [smartreader] active providers: 4 (abcdef,ffffff,ffffff,ffffff)
- 2021/10/14 15:02:04 5C0B5ED9 r (reader) Ziggo_SC [smartreader] found card system irdeto
- 2021/10/14 15:02:04 5C0B5ED9 r (reader) Ziggo_SC [irdeto] THIS WAS A SUCCESSFUL START ATTEMPT No 1 out of max allotted of 1
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] entitlements for provider: 1, id: ABCDEF
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: FFE0, date: 2021/10/11 - 2021/11/11
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 000B, date: 2021/10/11 - 2022/04/30
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 0384, date: 2021/10/12 - 2022/04/30
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 7FFE, date: 2016/04/03 - 2016/05/03
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 7FFD, date: 2021/10/13 - 2021/10/23
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: FFD8, date: 2021/10/13 - 2022/05/01
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 0028, date: 2021/10/11 - 2022/04/30
- 2021/10/14 15:02:05 5C0B5ED9 r (reader) Ziggo_SC [irdeto] chid: 0027, date: 2021/10/11 - 2022/04/30
ATR staat er netjes en doet niet vreemd. Echt ik heb alles tig keer clean ge installeerd. Gebeurt niets. DVBAPI is connected en vangt alleen EMM's maar decodeerd niets.
8 minutes ago, Zilverster said:
@homeaion,
OK, sorry, ik heb geen ervaring met Oscam.
Er zijn meer mensen hier op het forum die dat wel hebben en die komen jou wel helpen, gr.
Zilverster.
ik hoop het
1 hour ago, Zilverster said:
@homeaion,
Geeft de kaart wel beeld in een originele ontvanger ?
Gr.
Zilverster.
Originele ontvanger staat er naast. Daar geeft hij netjes beeld.
40 minutes ago, Kowalski said:Zo te zien is de kaart up-to-date, dus beeld zou er moeten zijn.
Nog iets wat me opvalt, heb je de newcamd key = 11223344556677889900AABBCCDD ook ingevuld bij de reader configuratie?
ik heb boxkey en rsakey bij [reader] ingevuld. Verder staat bij oscam.conf onder [newcamd] dezelfde key ingevuld als bij de newcam CA user in tvheadend.
38 minutes ago, Zilverster said:@homeaion,
Ik las hier boven :
Als die her activatie niet in een originele ontvanger is gebeurd kan het wel eens mis gaan, gr.
Zilverster.
De ontvanger waar hij mee kwam staat er sinds dag 1 naast. Is een Irdeto 0604 kaart by the way.
Ik heb exact hetzelfde probleem.Heb tig keer opnieuw fresh install gedaan maar nul resultaat.
caid/sid/emm worden idd netjes doorgegeven maar ook Can not descramble service
Voor de zekerheid wat waren jouw oscam.user, oscam.server en oscam.conf instellingen?
Cs378x is jammer genoeg geen oplossing voor mij icm Kodi
als ik alleen port = 9001 invul maakt hij er dit in de log van (ecm) tvheadend (0604@009001.............
Hoe moet ik Kodi met Cs378x laten werken? 😅
22 minutes ago, Kowalski said:
Probeer eens Port=9001 zonder dat achtervoegsel en ident en chid beiden leeg laten (niet nodig), en ik mag aannemen dat je bij “knippieknip” de goede waarden hebt staan? Kijk dan eens wat de logs melden.
Probeer ook eens Cs378x protocol i.p.v. newcamd en dan zonder die key.
Als dat niet werkt, zou ik ook de settings onder [dvbapi] nog eens bekijken, maar ik heb een andere setup en daar dus ook wat anders staan.
Hi Kowalski,
Dus ipv port = 9001@0604:000000,ABCDEF bedoel je dat ik port = 9001 neer moet zetten?
En als ik Cs378x moet instellen wat is de conf die ik invul?
Alvast dank voor de hulp. Ik ga dat 9001 verhaal proberen. En de RSA klopt 100% ja.
Beste allen. Het probleem is als volgt. Ik heb een geavtiveerde 0604, een TVHeadend met Homerun die netjes alle kanalen gescanned heeft op 5555 en een OScam die geconfigureerd is volgens de geldende standaard voor een 0604 kaart (volgens sommigen op dit board.)
De kaart wordt gezien, EMM's komen netjes binnen maar de kanalen worden niet descrambled (zie screenshots voor meldingen.)
Ik ben aan het einde van mijn kunnen en plaats di bericht om te kijken of iemand iets ziet wat ik niet zie.
Alvast dank,
Hardware:
- Triple reader
- Raspberry Pi 4
- HDHomerun
- Hardware Model HDHR3-4DC
- Firmware Version 20210624
Software:
OS: Libreelec (official): 9.2.8 (kernel: Linux 4.19.127)
TVheadend: Build: 4.2.8-36 ~ LibreELEC Tvh-addon v9.2.0.123 (2020-09-16T18:12:04-0400)
OSCam: 1.20_svn Build: r11518 Compiler: armv8a-libreelec-linux-gnueabi
oscam.conf
# oscam.conf generated automatically by Streamboard OSCAM 1.20_svn SVN r11518
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.conf.txt[global]
logfile = /storage/.kodi/userdata/addon_data/service.softcam.oscam/log/oscam.log
nice = -1
usrfile = /storage/.kodi/userdata/addon_data/service.softcam.oscam/log/oscamuser.log
cwlogdir = /storage/.kodi/userdata/addon_data/service.softcam.oscam/log/cw[cache]
[newcamd]
serverip = 127.0.0.1
keepalive = 1[dvbapi]
enabled = 1
au = 1
pmt_mode = 4
request_mode = 1
user = tvheadend
read_sdt = 2
write_sdt_prov = 1
boxtype = pc-nodmx[monitor]
port = 988
aulow = 120
monlevel = 1
hideclient_to = 15[webif]
httpport = 8888
httpuser = admin
httppwd = pasword
httphideidleclients = 0
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255,192.168.1.0-192.168.255.255
aulow = 120
hideclient_to = 15oscam.user
# oscam.user generated automatically by Streamboard OSCAM 1.20_svn SVN r11518
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.user.txt[account]
user = dvbapi
au = 1
group = 1[account]
user = tvheadend
pwd = tvheadend
au = 1
group = 1oscam.server
# oscam.server generated automatically by Streamboard OSCAM 1.20_svn SVN r11518
# Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.server.txt[reader]
label = Ziggo_SC
description = Ziggo Card
protocol = smargo
device = /dev/serial/by-id/usb-Argolis_Triple_Reader+_00000022-if01-port0
autospeed = 0
caid = 0604
boxkey = 1knippieknip8
rsakey = 3Cknippieknip6A
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 600
ident = 0604:000000,ABCDEF
chid = 0604:000000,00FFE0,00000B,00270E,000384,007FFE,007FFD,00FFD8,000028
group = 1
emmcache = 1,3,15,0
auprovid = ABCDEFOscam logfile
>> OSCam << cardserver log switched at Wed Oct 13 14:32:12 2021
2021/10/13 14:32:12 40C11223 r (reader) Ziggo_SC [irdeto] tvheadend emmtype=global, len=43 (hex: 0x2B), cnt=0: written (85 ms)
2021/10/13 14:32:12 00000000 >> OSCam << cardserver log switched, version 1.20_svn, build r11518 (armv8a-libreelec-linux-gnueabi)
2021/10/13 14:32:17 40C11223 r (reader) Ziggo_SC [irdeto] tvheadend emmtype=shared, len=63 (hex: 0x3F), cnt=0: written (88 ms)
2021/10/13 14:32:23 56A112D8 c (ecm) tvheadend (0604@000000/000B/4C05/44:742D4CEE9B90FCE7365E688474289886): not found (175 ms) by Ziggo_SC - RTL 4 HD (Ziggo_SC irdeto_do_cmd [2])
2021/10/13 14:32:23 56A112D8 c (ecm) tvheadend (0604@000000/270E/4C05/44:04BD6FFBB1B8678C3EBCCA548672536F): not found (309 ms) by Ziggo_SC - RTL 4 HD (Ziggo_SC irdeto_do_cmd [2])
2021/10/13 14:32:33 40C11223 r (reader) Ziggo_SC [irdeto] tvheadend emmtype=global, len=43 (hex: 0x2B), cnt=0: written (85 ms)
2021/10/13 14:32:43 56A112D8 c (ecm) tvheadend (0604@000000/000B/4C05/44:BDB3B0C475D576BE816F69BB1A78E97D): not found (176 ms) by Ziggo_SC - RTL 4 HD (Ziggo_SC irdeto_do_cmd [2])
2021/10/13 14:32:44 40C11223 r (reader) Ziggo_SC [irdeto] tvheadend emmtype=shared, len=63 (hex: 0x3F), cnt=0: written (88 ms)
Het probleem Oscam icm 0604 kaart
in OSCam
Ik heb het probleem kunnen achterhalen. Het was een hardware probleem. Nadat ik de Triple reader verving voor een blauwe Smargo (die ik maar voor de zekerheid had gekocht) was het probleem weg. Niets aan de settings veranderd. Alleen nieuwe reader toegevoegd en de Triple uitgezet. BAM! Hij doet het.
Triple readers zijn waardeloos.
