68 -
Berichten die geplaatst zijn door driesje
geweldige image weer zonder problemen geinstaleerd maar waar vind ik in hemelsnaam de blauwe knop update
Heb hier de 7000 staan en de 500 en heb met beide hetzelfde probleem.
Elke x als ik de ontvanger aanzet moet ik newcamd opnieuw opstarten,met de 5620 had ik daar geen last van terwijl ik dezelfde configuratie heb
Samsung Brand 5512 Model
Dual CI
VIACCESS
HW version 5.04
Loader version 5.01
Select Download
Timeout
Reboot
STLLI_Init(LLI)=Ok
STLLI_Open(LLI)=Ok
STAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STCLKRV_Init(CLKRV0)=Ok
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003
QPSK STI2C_Read STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003)
Demodulator Reset FAILED!
PTI_Init()=Ok
STCLKRV_Open(CLKRV0)=Ok
declared symbols = 0 (0 commands + 0 macros + 0 strings + 0 numbers)
allocated symbols = 0 / 0
free memory size = 758500 bytes
STAUD_Init(AUD0)=Ok
STVTG_Init(VTG0)=Ok
QPSK STI2C_Write Ok
STVID_Init(VID0)=Ok
QPSK STI2C_Write Ok
STTTX_Init(TTX)=Ok
QPSK STI2C_Write Ok
STAUD_Open(AUD0)=Ok
QPSK STI2C_Write Ok
STVTG_Open(VTG0)=Ok
QPSK STI2C_Write Ok
STVID_Open(VID0)=Ok
5512STDENC_Init : Done
STDENC_Open, Device 'DENC0' Opene
5512********* BDGHI QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing ack
STDENC_SetEncodingMode : Done
QPSK STI2C_Write Ok
STVTG_SetMode()=Ok
Mode 576,50,27000
)P
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003device is using the bus
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003K STI2C_Write STI2C_ERROR_BUS_IN_USE - Another Master device is using the buster
)e
(0x00080007))
QPS
)S
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003ce is using the bus
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003I2C_Write STI2C_ERROR_BUS_IN_USE - Another Master device is using the bus STI2C_
)R
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003SK STI2C_Write STI2C_ERROR_BUS_IN_USE - Anothe07)
QPSK STI2C_Write STI2C_ERROR_BUS_IN_USE - Another Master device is
)s
(0x00080007)
(0x00080007)ite STI2C_ERR
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003he bus
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003us
Subscribe OkDevice 'OSD0' initialisedQPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK -STI2C_Read STI2C_ERROR_BUS_IN_USE - Another Master device is using the busr dev
PAL
OSD: Region creation . . . passed
(0x00080007)
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003 device is using the bus
OSD Region: W=720, H=576, X=0, Y=0
(0x00080007)
OSD: bot_address = C010B408, bot_address_tail = C013DE08I2C_ERROR_BUS_IN_USE - Anoth
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003 is using the buster device is using the bus
OSD: set draw region addresses . . . passed
(0x00080007)07)
QPSK STI2C_Write STI2C_ERROR_ADDRESS_ACK - no addressing acknowledge (0x00080003ing the buster device is using the
OSD: palette init . . . pas
OSD: fonts definitions size = 131kB
@Erik
dit is wat ik krijg als ik hyperterminal opstart.
wat ik ook doe de samsung blijft na opstarten in een zwart gat hangen.
eerst 9500 in beeld en daarna niets meer, ook op de tv geen scart verbinding.
als ik de samsung reset komt de scart wel in maar als 9500 uit beeld verdwijnt gaat ook de tv van scart af en naar de gewone kabel.
help
Ook ik heb hetzelfde probleem met de samsung.
heb firmware 5.4.1 ?? eringezet nieuwe lijst erbij en het resultaat is een sammy die opstart met 9500 en daarna zwart beeld.
Heb via hyper terminal een andere firmware geprobeerd maar niets helpt kan van alles naar de sammy sturen maar blijf na 9500 in de display te hebben gezien een zwarte display overhouden.
Kan het zijn dan de eeprom waar je de software heen stuurt niet meer leegraakt en dat er daarom geen doorstart plaatsvind.
Heb hier inmiddels hetzelfde probleem gehad, spanning op de lnb valt weg. Ben met de doos naar een reparateur geweest en die heeft 2 condensatoren op de voeding vervangen. De LXV 16 V 1000 uF en nu is het probleem bij mij weer opgelost. Heb het laten doen bij een bedrijf in Eelde.
<img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Nee dat is niet mogelijk, of je moet een ftp progje gebruiken zoals hierboven ook al staat geschreven.
windows commander bv.
Peter makket er mar een raar sootsje von mar vooruit ek zil em er een bietsje bie helpe.
ik zie geen rode balk. Als ik dreamup opstart en connect dan laat ik de box herstarten en geeft dreamup aan van upload oke zie de blauwe balk helemaal vol lopen en dan staat hij in waiting for acknoweledge.
ik heb hem zo wel 10 min laten staan dus daar kan het niet aan liggen.
Ook heb ik de snelheid al op verschillende standen gehad ook niks.
kan het aan de box zelf liggen???
Dries
Als ik met dreamup probeer te loggen op de box gaat alles goed, maar na upload completed blijft hij hangen in waiting for acknowledge.
Wie kan mij helpen.
Dries
ik heb al tijden de zelfde configuratie op de ontvanger en er is niets verandert of bijgekomen in de buurt van het apparaat.
ik heb een triax schotel met 4 lnb,s en op alle 4 de sattelieten hetzelfde probleem.
Als ik de ontvanger een min of 5 aan heb dan gaat het signaal met rasse stappen achteruit.
Zo erg dat je de groene balk even helemaal ziet verdwijnen en weer terugkomen.
Als ik een andere onvanger aansluit heb ik geen probleem dus aan de lnb kan het niet liggen.
Iemand een tip om nog wat te controleren of moet ik hem maar gelijk naar de winkel brengen voor reparatie
Wat je kan doen is de stekker ongeveer 5 minuten uit het stopcontact halen zodat de ontvanger goed stroomloos is geweest, eerder langer dan korter en het dan nog eens proberen. Een reset naar fabrieksinstellingen geven en dan de zenderlijst er weer in. Maar vooral een poosje stroomloos doet wonderen.
Citaat:Dit is ook niet waar...
Dat staat wel in de omschrijving als je een nieuwe kaart koopt, maar kan het ook zo zijn dat als je je kaart verkoopt dat die dan moet worden overgeschreven naar de nieuwe eigenaar.
Of als je geen 15€ per jaar betaald dat dan eerst de gegevens worden opgevraagt en pas daarna activatie.
Maar 1 ding is zeker het staat in de papieren dat het anders 7.50€ kost. -
Vind ik allemaal prima wat ze daar doen, vooral snellere wisseling heb ik geen problemen mee maar die 2 nieuwe kanalen op welke frequentie zitten die
als je het pakket hebt waar je niets voor betaald dan moet je € 7.50 betalen voor heractivatie.
Dries
Ik moet heel eerlijk bekennen dat ik geen flauw idee heb want ik moet de rekening nog krijgen omdat ik het er niet mee eens was want voor dat bedrag had ik van te voren toch wel even een belletje verwacht en ik wacht nu op een antwoord van die kant maar als ik het weet zal ik het doorgeven.
Dries
Heb ik hier ook gehad , nadat de stroom er weer was een dode xsat. Ook mijn gedachte was een kapotte zekering,maar wat blijkt er zit helemaal geen zekering in. Dus opgestuurd en 100€ armer.
Dries
en ja hoor na de irdeto firmware ben ik nu weer zwaar onder de indruk.
Dries <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Als je nou eerst het board eens goed leest dan heb je echt geen uitleg meer nodig, het staat op vele plaatsen hier uitstekend geschreven.
Gebruik de zoekfunctie maar eens.
Dries
als je er een settingslijst inzet van een ander staat die meestal ook ingesteld op zijn ontvanger, als jij nu even meld wat voor instelling jij hebt bv disec enkele lnb of meerdere of met motor dan kan ik je verder helpen.
Dries
Nieuwe software versie beschikbaar op Astra.
Main software version 132
Dries
nee bij mij gaat dat niet de 1e ontvanger bepaald wat de 2e mag zien
Dries
Ik heb nu al ongeveer 1 jaar 2 sammys aan elkaar, 1 doorgelust dus, en heb ze ook altijd alle 2 aanstaan heb nog nooit ervaren dat iets niet meer goed werkt alleen is het zo dat als ik met de eerste sammy ga schakelen naar een andere transponder dat de 2e dan geen beeld meer heeft maar voor de rest nog geen storingen gehad lijkt mij ook stug dat dat na 1 jaar nog zal gebeuren.
Dries
had ik ook,heb gisteren de settings van satkoos 15-11-03 draaibaar erin gezet en toen had ik weer beeld.
nadat je de lijst erin hebt gezet stekker uit het stopcontakt de drie knopjes indrukken en de stekker er weer in.Zo heb ik weer beeld gekregen.
[DM500] advies gezocht over betrouwbare image voor CD kaart
in Dreambox
nu ben ik toch wel benieuwd naar z'n antwoord <img src="/forums/images/graemlins/smile.gif" alt="" />
als hij de extra features van een dreambox toch niet gaat benutten, waarom wil hij er dan één ?
je koopt toch ook geen boot om er vervolgens niet in te gaan varen ?
ennuh, update-perikelen worden geregeld door Canal Digitaal Nederland, niet door de satellietontvangers.
merDe
Hee, Ome Merde , ikke wel hoor ben dit jaar nog niet met de boot te varen geweest maar heb er elk weekeinde lekker op zitten luieren.
Dries
