skycar008
114 -
Berichten die geplaatst zijn door skycar008
release 0.5.0:
- fixed a bug on rebooting the system
- better CI cams handling
- support for upper and lower CI slots on the current live tuner, no more needs to put the cam only on the upper one
- added new dvdplayer
- support for timeshift
- fixed alpha blending colour on images
- updated e2 cvs to 30/05/2009
- fixed fstab auto mounting for hdd
- vsftpd log on file disabled by default
- fixed a bit keymap for 250hd/200hd, audio subtitles now is mapped
- added autoload of epg (using myepg now the file will be loaded automatically at enigma2 restarts)
- some fixes on mediaplayer for some multimedia files
- many fixes all around for better stability, now i think most part of drivers are done
- updated arabic language
AAF:
+ AAF-Panel V4.1
+ Softcam-Panel V0.21
+ Addon-Manager V1.73
+ MediaCenter
+ HD-Skin Wine Metallic
+ HD-Skin Ice Metallic
+ VFD-Standby V0.1
+ Automount
+ Cifs,Samba
+ Cardreader Unterstützung
+ NewCS Control V0.2
+ Permanent Clock
+ SetstartChannel
+ Network Browser
und vieles mehr...."
Hope this is good!
Binnenkort meer.....
Houdt de bekende fora in de gaten!
Inmiddels is versie 0.88 uit
09/07/2009, V0.88
- fixed another bug on irdeto channels
NICO Dank voor je image. Werkt over het algemeen goed. Als cam zit hier camd3 ingebouwd icm newcs 1.66 via de interne reader. Echter er komen geen updates binnen van CD...... iemand een idee. Hierbij de config van NewCS 1.66:
<!--NLBCFG2: upper_no_boxkey(nordic),lower_boxkey(German) -->
<newCSconfig>
<readers name="Card Readers">
<device>
<name>Card no boxkey</name>
<type>sci</type>
<mhz>357</mhz>
<node>/dev/sci0</node>
<parity>even</parity>
<reset>normal</reset>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<PTShandshake>no</PTShandshake>
<crypto-special>no</crypto-special>
<carddetect>yes</carddetect>
<newcamd_port>32100</newcamd_port>
<priority>round</priority>
</device>
<device>
<name>Card boxkey 0000000000</name>
<type>sci</type>
<mhz>357</mhz>
<node>/dev/sci1</node>
<boxkey>0000000000</boxkey>
<newcamd_port>32101</newcamd_port>
</device>
</readers>
<cache>
<emm>10</emm>
<ecm>10</ecm>
</cache>
<httpd>
<server> <!-- Port to accept connections on -->
<port>9000</port>
</server>
<user>
<name>root</name>
<password>relook</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<level>normal</level>
<type>init</type>
<output>console</output>
<logfile></logfile>
<console_options></console_options>
<file_options></file_options>
</debug>
<newcamdserver>
<name>cardserv</name>
<deskey>11 12 13 14 15 16 17 18 19 10 11 12 13 14</deskey>
<!-- <userfile>/tmp/users.txt</userfile> -->
<user>
<name>ip9000</name>
<password>nlbimage</password>
<au>on</au>
</user>
<user>
<name>ip9000pip</name>
<au>on</au>
</user>
<user>
<name>ip9000rec</name>
<au>on</au>
</user>
<user>
<name>ip9002</name>
<au>on</au>
</user>
<user>
<name>ip9002pip</name>
<au>on</au>
</user>
<user>
<name>ip9002rec</name>
<au>on</au>
</user>
</newcamdserver>
</newCSconfig>
Enigma 1 voor de ABCOM HD Boxes is uitgekomen. Zie de readme.
Readme:
AB Enigma1HD_9xxx_110609beta
This is Beta version of AB Enigma1HD for AB IPBox 9000HD/900HD/910HD and 91HD
How to install:
- unzip downloaded file to your PC
- Copy file from your PC into USB flash memory and rename it into "usb_update.img"
- IMPORTANT: Use "Safety remove USB device" function before disconnecting your USB flash memory from PC !
- Turn off your receiver (Standby+OK on front panel) and connect USB memory to USB (host) connector on your receiver.
- Press and hold Standby on front panel until "BOOTING" message appears on display,
press Up button . "USB UPGRADE" message should appear on display of your receiver - software update performs automatically.
- Wait until DONE message appears and restart your receiver.
How to install E2 HD (USB stick version) via internet with E1 HD installed inside box (Multiboot function):
- connect USB flash memory to receiver and formatt it to ext3
- go to Menu - Setup - System settings - Harddisc setup - line "connected"and make sure if USB is mounted to /hdd or /mnt/sda (if you don´t have installed HDD) or to /mnt/sdb (if you have installed HDD)!!!
- press blue button and go to "tarx", press OK, and choose "Download Addon". You will see "Enigma2.sda" and "Enigma2.sdb" files for each model of HD boxes.
"Enigma2.sda" - choose only when you don´t have installed HDD
"Enigma2.sdb"- choose only when you have installed HDD
- after choosing correct file, download will start and after that confirmation window will appear - press OK on "yes"
- when you will see window with "OK", you have successfully installed E2 HD on USB
- if you want run E2 HD just turn box off (Standby+OK on front panel),that press standby button and press and hold number 2 or 3 (it depends of installed HDD)
number 1 - booting from internal flash
number 2 - booting from sda
number 3 - booting from sdb
number 4 - booting from nfs
number9 - booting from set up enviroment 192.168.1.25 ipaddr,
192.168.1.102 server ip, nfsroot
/home/ipbox/rootfs
This can be helpfull:
- IMPORTANT: By manual searching of channels ever press "retune" after inserting all parameters.
This behavior differs from original E1, so don't forget about it when you need to do manual scan
- In Expert setup you can find "User reset" - this returns box to first setup with basic setting for 4 satellites
- In menu "Common Interface" you can find this: "can handle two services" - when you marked it to on, it is possible one scrambled channel record and one scrambled channel from same TP watch.
Note: this function must be also supported by CAM module!(e.g.Cryptoworks from Mascom supports this)
- If use 720p or 1080i mode with teletext, after teletext switch on, press Menu button and activate "true type fonts" item.
Please note that this is E1 HD, so in IP9000HD is supported only first tuner.
Known issues:
- DVB-C tuners not supported
- internal card readers don´t work (external USB card readers work)
- works upper CI slot only, after inserting CAM module you have to restart it in menu of box. After every restarting of box you have to put out CAM from box and put in to box and reset CAM in menu of box.
- DVB and TXT subtitles are not working
- problem with formatting some 3,5" HDD´s
- some bugs by playback recordings from HDD
- it is not possible timer recording from EPG
- SD menu graphic supported only
- installed games don´t work in 720p and 1080i mode. (work in 576i and 576p mode)
- signal indicators don´t work
- in some situations box doesn´t present any channels, need reinsert CAM and reset CAM in Common Interface menu
NOTE: Source code of AB Enigma1HD will be released ASAP. Stay tuned
hier hetzelfde.... geen vastlopers maar geen epg
De nieuwe versie NewCS1.66 RC 1 is. Zie wijzigingen
.1.66 RC1
ALL cdks are new, due to server crash.. many many changes to libs etc.
Support for TNTSAT.
Experimental support for *** 0963. NB! Remember to put the 4 byte hex boxkey in config!
Multi-realms added to chameleon.
Support for pin-code on specific channels specified by in config.
Added the ability to disable/enable certain virtualcards on chameleon in config, or disable whole list.
NB! NewCS has gone green - removed all support for windows
Time to grow up, get a powerfriendly little linux-device to run NewCS on!
Welk NLB image gebruik je?
Origineel bericht van: CB1Origineel bericht van: ikbennicoEn als EPG nu niet even werkt ligt aan CanalDigitaal (de rest heeft er ook last van) maar de box krijgt meteen de schuld.Sorry voor deze uitlating maar moest het even kwijt.
Nico
Even een klein citaat uit een ander onderwerp.
Ik HAD hier ook last van maar ben nu 2 versies terug gegaan met nlb en nu heb ik wel weer epg.
Ik begon er over na te denken toen iedereen zei het ligt aan canal digitaal en ik vervolgens via mijn kabeltuner ook geen epg meer van Ziggo had.
Ik dacht het ligt hem dus helemaal niet aan cds maar aan de software zelf.
En zie daar,
een paar versies terug en zie daar ik heb weer epg.
Gr CB1
Workarround uitgevoerd inmiddels ook weer EPG op NL123
Bedankt voor de oplossing. Het werkt weer goed (zonder EPG). Wel vreemd trouwens EPG werkt op de DB normaal op ned 123
Gisteren is mij wel opgevallen dat CD de key vernieuwd heeft. Mogelijk dat he hiermee te maken heeft.
Hier precies hetzelfde probleem op dit moment crash ned 123. vreemd ......
Klik om te tonen.. -
Heb dezelfde problemen met MGCAMD 1.31 en NEWCS 1.65. Management datum en 006A Canal Digitaal verschillen voortdurend. Hierdoor sommige kanalen op zwart. Na een heractivatie gaat het weer een paar dagen goed (3dagen)..... Ik heb een DB 7020 (gebruik icm Newcs 1.65) en een IPBOX 9000 die ik laat connecten mbv MGCAMD naar de DB7020..... meerdere mensen met dit probleem
Ik ben op zoek naar een goede settingslijst voor de IPBOX 9000. Ik maak gebruik van het NLB image. Weet iemand een goed site waar ik deze settingslijsten kan downloaden. Het gaat mij om settings lijsten ala HenkSat. Misschien kan iemand een settingslijst toevoegen. Allen Dank!
Hij doet het inmiddels PID was foutief dank een ieder!
Ik heb een ipbox 9000 met NLB image 9047. Hierop draai ik MGCamd 1.31/newcs 1.65 in combinatie met de nieuwe oranje Seca 3 Canal Digitaal kaart. Echter ik krijg MTVND niet aan de gang. Ik krijg de overige HD kanalen werken normaal. Kan iemand mij zeggen wat ik fout doe? Ik heb de settings juist ingevoerd via King of Sat. Wie kan mij helpen hiermee? Ik heb een screenshot toegevoegd van mijn setting voor dit kanaal. Wat wordt bedoeld met PMT-PID? Allen dank!
Ik heb
Ik ben van plan om gebruik te maken van WebEPG icm met mijn IPBox 9000 HD. Ik weet dat het mogelijk is progamma data (EPG) van internet te downloaden en te koppelen aan de kanalen lijst. Is het mogelijk om de gegevens te downloaden van tvgids.nl hiervoor? Ik maak gebruik van NLB image 9047 en wil gebruik maken van Dexters' WebEPG 0.61 plugin. Kan iemand mij uitleggen hoe ik dit moet aanpakken? Dank!
Is deze versie al een beetje stabiel om te installeren? Kun je dit image ook flashen mbv een USB stick. Net zo als de andere images voor de IPBox. Nadat je Enigma 2 geinstalleerd hebt, kun je dan terug naar de orginele images? Dank!
Hallo, Ik vraag me af of Abcom nog officieel uitkomt met een Enigma 2 image voor de IPBOX. Ik weet dat SIFteam een Enigma 2 image heeft, is deze aangepast vanaf een orgineel image. Alleen een beetje omslachtig deze te installeren. Ik vind Enigma toch wat fijner werken als het huidige Abcom image Weet iemand wat de ontwikkelingen op dit moment zijn? Dank!
Problemen met CD Seca 3 kaart. Sommige kanalen doen het wel andere niet. Het gaat hier met name om de RTL's en SBS en NET5
Ik heb nog steeds problemen met het connecten. Ik heb overigens de SECA 3 kaart van CD. Zijn er mensen die hiermee ervaring hebben.
CCCAM GEEFT AAN:
Connected clients: 1
1 ACTIVE CLIENT IN LAST 20 SECONDS
| Username| Host | Connected | Idle time | ECM | EMM | Version| Last used share | Ecm time |
|ipbox |192.168.1.251 |00d 00:00:52|00d 00:00:01|61 (0)|0 (0)|2.0.11 |0100:00006a:07e9 (nok)| 0.0007s |
| Username| Shareinfo |
|ipbox |remote 0100:00006a 61(0) |
Origineel bericht van: blaOrigineel bericht van: CB1Even voor de duidelijkheid,Met het installeren van de nieuwe nlb heb je nog niet de nieuwe incubuscamd.
Deze moet je binnenhengelen via de hotfix.
Toen ik de nieuwe versie gisteren geinstalleerd had werkte incubuscamd wel.
Na vandaag de hotfix binnengehaald te hebben werkte de incubuscamd echter niet meer.
Dus mijn vraag is hetvolgende,
De mensen die dus zeggen dat hun met de nieuwe versie wel beeld hebben , hebben jullie ook de hotfix binnen gehaald?
Ik heb nu nl ook geen beeld meer.
De incubuscamd config file is niets aan veranderd want hier wordt met de hotfix niets aan veranderd.
Dit kan het naar mijn mening dus ook niet aan liggen.
Dus het posten van een incubuscamd.cfg heeft dan ook geen nut.
Groetjes Peter
Of je nu van image bent veranderd,maakt niet uit,je moet zelf je config aanpassen,deze is veranderd!zie opmerkingen v. 0.7!!!
config 0.55 is totaal verschillend van 0.7 _0 moet enkel onderaan weggelaten worden.
De hotfix veranderd de config uiteraard niet, die moet je nl. er zelf opzetten of aanpassen(is ook zo bij cccam trouwens).
Dank voor je antwoord. Zo heb ik ook al geprobeerd. Op andere forums (denkdenk) staan ook al verschillende berichten dat met mensen problemen hebben met Incubuscamd 0.70 en NLB r9047 v1.29. Heb inmiddels v1.25 weer geinstalleerd. Meerdere mensen met dit probleem
Ik heb net NLB r9047 v1.29 geinstalleerd (IPBOX 9000 HD Plus). Ik krijg Incubuscamd niet aan de gang in combinatie met CCCAM. Ik doe iets fout maar weet niet wat. Ik heb het image standaard geinstalleerd en Incubuscamd geselecteerd met de plugin. Zie mijn config hieronder:
# incubusCamd configuration file #
# All configuration options in this file observe the same format: #
# <configuration_name>=<configuration_value> #
# Each section are [<section_name>:<option_1>:<option_x>] like. #
# No matter about white spaces on any place or UNIX/DOS style files #
########################### general configuration ############################
[General]
# Enable or disable background execution of the cam
# 0 - Disable
# 1 - Enable
background_execution=1
# First release don't use this, you can delete it
# Used to set the priority where first try to get the current Ecm's DW
# divide each option by comma, options are card protocol name or "emu" (for the internal emulator)
# mode=newcamd,emu,cccam,gbox,camdX,radegast,aroureos
############################ caid configuration ##############################
# First of all the cam use the incubusCamd.prio file, then use the
# configuration below.
# Sections are defined by the value of the CaID.
# You can choose the default ecm table used by the codify, this means that
# you can choose the first byte of the raw ecm that is downloaded from sat.
# If you don't know what value to insert, use "80". (all value are in hex)
# Default value for ecm_table is 0x80.
# The option "priority" tells if one caid should be selected before try
# another one with a priority value greater.
# The less is the value the greatest is the priority. Choose from "0" to any value,
# priority value is decimal.
[CaID:0100]
ecm_table=80
priority=1
[CaID:0500]
ecm_table=80
priority=1
[CaID:0600]
ecm_table=80
priority=1
[CaID:0919]
ecm_table=80
priority=1
[CaID:093B]
ecm_table=80
priority=1
[CaID:0B00]
ecm_table=80
priority=1
[CaID:0D00]
ecm_table=80
priority=1
[CaID:1700]
ecm_table=80
priority=1
[CaID:1800]
ecm_table=80
priority=1
[CaID:2600]
ecm_table=80
priority=1
########################### provider configuration ###########################
# All parameters are in hexadecimal notation.
# Each section is defined by the provider id value.
# If you don't know the provider id value then use the provider id "FF00".
# On provider FF00 goes all provider wich are not declared. If the provider
# is declared then the cam will use the provider founded.
[Prov:0501]
# URL of card-server to use, formats are as follows:
# newcamd://<username>:<password>@<hostname>:<port>/<des_key>
# aroureos://@<hostname>:<port>
# radegast://@<hostname>:<port>
# Example:
# newcamd://foo:bar@192.168.0.100:12345/0CE3476FF2E1C9D9A0A109B371E3
# Multiple card-server url's can be specified for server fail-over.
# If the emu fails to connect or fails to get valid CW's, it will try to
# connect to other servers in a round-robin fashion.
# Up to 16 servers can be added from index 0 to 15.
# You can choose also to select a cccam or gbox server, but they must be declared
# in the "servers configuration" section ( [servers] ).
# e.g. : if you want to use a cccam server for a provider you must put it on
# the parameter card_server_url_0=cccam://
# NO MATTER the value after the double slash because server configuration is
# made in the section [servers].
# Only for newcamd, radegast and aroureos is usefull to put correct connection
# parameters because they are provider dependent.
#card_server_url_0=newcamd://username:password@192.168.0.100:10550/0102030405060708091011121314
#card_server_url_1=radegast://@<hostname>:<port>
[Prov:FF00]
# this provider is a stand-in for all providers not declared------------------
# For example i choose to use gbox protocol on all other provider.
#card_server_url_0=gbox://
#card_server_url_0=cccam://test:test@192.168.1.6:12000
card_server_url_0=cccam://dream500:prive@192.168.1.253:12000
########################### servers configuration ############################
# This is the section for the multi-server configuration.
# First release use this only to connect on ONE cccam server and on ONE gbox
# server.
# gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
# cccam://<username>:<password>@<hostname>:<port>
card_server_url_0=newcamd://ip9000:nlbimage@127.0.0.1:32100/1112131415161718191011121314
# Incubus can only work with 1 url line in this release
# activate line below when new update is out, that support it
#card_server_url_1=newcamd://ip9002:nlbimage@127.0.0.1:32101/1112131415161718191011121314
[servers]
#card_server_url_0=newcamd://ip9000:nlbimage@127.0.0.1:32100/1112131415161718191011121314
#card_server_url_1=gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
Ik heb de toegevoegde regels dik gedrukt.
Wie kan mij helpen?
Dank !
Zie hiervoor het Strong forum alhier. Er is alternatieve firmware voor de Strong 8000, echter is deze software volgens mij wniet door de Strong beschikbaar gesteld. Lijkt me goed eerst het forum goed te door te lezen.
http://www.sat4all.com/forums/ubbthreads.php/topics/1635233/1
Origineel bericht van: Prins hansHallo,Mijn Strong 8000 doet het ook niet met de nieuwe kaart, na telefonisch contact met CD werd mij verteld dat ik nieuwe software nodig heb en dat moet laten doen bij een erkende dealer.
Is er een mogelijkheid om dit zelf aan te passen?
Greetz Hans
Aangekondigd IP-BOX release 0.5.0 AAF-MOD
in Overige merken
Hierbij de links om hem te downloaden:
9000/900/910 versie
http://rapidshare.com/files/257597116/IP-Box-AAF-SummerDream-USB.tar.gz
AAF:
+ AAF-Panel V4.1
+ MediaCenter
+ VFD-Standby V0.1
+ Automount
+ Cifs,Samba
+ Permanent Clock
+ SetstartChannel
+ Network Browser
Hope this is good!
