deniz2005
7 -
Berichten die geplaatst zijn door deniz2005
RC8 - version ok for all models
This Enigma 2 Image is for DOM Install !!!
USE AzUP 2.1 to Install this Image in Your device
- EXPERIMENTAL - TWIN SUPPORT - ofcourse only on P+
- Ultra model now work fine
- STC Prebuffering - only for test , added in A/V Settings
- Scart/RCA - Composite out fixed
- Aspect Ratio and Scalling added in A/V Settings
MultiMedia imrove and fixs :
- fixing packed avi support for gstreamer (finally solved most sync issues)
- been playing 1080p dts through mediacenter from nfs
NOTE : STC Prebuffering is only for test, pls play with this and report on forum what is your experiances , and what is best combination and compromise between fast zap and stable zap
RTi core RC8 Enigma 2
Beste Lamko,
Dankt voor je antwoord.
het is mijn niet gelukt om te mouten.
Welke regel moet ik nemen in /jffs/etc/config/usb.startup
heb verschillende geprobeerd, zonder succes.
Als ik usb-stick uithaal en in doe wordt het wel gezien.
http://www.dd-wrt.com/wiki/index.php/USB_storage#Mounting
router gegevens:
/dev/scsi/host1/bus0/target0/lun0: p1 p2 p3 p4
/dev/scsi
/dev/scsi/host0
/dev/scsi/host0/bus0
/dev/scsi/host0/bus0/target0
/dev/scsi/host1
/dev/scsi/host1/bus0/target0/lun0/disc
/dev/scsi/host1/bus0/target0/lun0/part1
/dev/scsi/host1/bus0/target0/lun0/part2
/dev/scsi/host1/bus0/target0/lun0/part3
/dev/scsi/host1/bus0/target0/lun0/part4
Automatische Schijf Moun: Activeer
Run-on-mount Script Naam: /mnt/mount.sh
Schijf Mount Point: /mnt
Schijf Informatie
--- /dev/discs/disc0/disc
Block device, size 482 MiB (505413632 bytes)
DOS/MBR partition map
Partition 1: 256 MiB (268435456 bytes, 524288 sectors from 2048)
Type 0x83 (Linux)
Ext3 file system
Volume name "opt"
UUID 9329A0DD-4380-4DF2-9D6F-B275A18F85DE (DCE, v4)
Volume size 256 MiB (268435456 bytes, 262144 blocks of 1 KiB)
Partition 2: 32 MiB (33554432 bytes, 65536 sectors from 526336)
Type 0x82 (Linux swap / Solaris)
Linux swap, version 2, subversion 1, 4 KiB pages, little-endian
Swap size 31.99 MiB (33546240 bytes, 8190 pages of 4 KiB)
Partition 3: 125.5 MiB (131604480 bytes, 257040 sectors from 594405)
Type 0x83 (Linux)
Ext3 file system
UUID 4C45878F-2A63-4CE5-B586-62464E8E859A (DCE, v4)
Volume size 125.5 MiB (131604480 bytes, 128520 blocks of 1 KiB)
Partition 4: 66 MiB (69206016 bytes, 135168 sectors from 851968)
Type 0x83 (Linux)
Ext3 file system
Volume name "Data"
UUID 5E087A06-DC8F-434C-892B-5867D98BA35C (DCE, v4)
Volume size 66 MiB (69206016 bytes, 67584 blocks of 1 KiB)
Status: Mounted on /mnt
Beste satelliet hobbyisten,
Ik heb netgear wndr3700 met dd-wrt
Bij het rebooten van de router wordt de usb-stick niet gemount.
zie info hieronder.
Kunnen jullie mij helpen?
En nog een vraag hoe kan ik zien of cccam server werkt?
192.168.1.1:16001(WEBINFO LISTEN PORT : 16001} ?
Schijf Informatie
Type 0x83 (Linux)
Ext3 file system
Volume name "opt"
Type 0x83 (Linux)
Ext3 file system
Type 0x83 (Linux)
Ext3 file system
Volume name "Data"
[Enigma2] Nieuwe RTI core RC8 is uit
in DVB-receivers
Ik krijg nog steeds net als bij RC6 "tune failed" als foutmelding tijdens zappen.
( steeds de melding "Afstemmen mislukt!" )
Ook met een schone instal geprobeerd.
Zet altijd vinkje bij "Format Extented partition"
en bij "Copy kenel"
Als in naar ander satelliet schakel heb ik helemaal geen beeld. (Eutelsat W3A 7.0°E)
Signaal blijf op 0%
Met RTi core RC5 werkt mij settings goed.
Weet iemand oplossing?
AZbox HD Premium+ DVB-S2 + DVB-C2
HDMI 1080p 50hz / Samsung 46"
FW RTi Core RC7
DiSeqC switch 4/1
