apella
48 -
Berichten die geplaatst zijn door apella
Is de USB stick fat32 geformateerd?
Deze werkt niet bij mij, ik draai Extreme Edition rc1 0.7.5. Weer terug naar 0.96.
Uitpakken met bijv winrar of 7zip, je krijgt dan een flash bestand die je nog een keer moet uitpakken om het img bestand te krijgen.
De flash versie voor de 910 gaf een error 5. Nu gedownload bij sat heelal, die doet het wel.
Interested image based on Tideglo rev.0.7.5 with some interested solution about pasnel-cam menagement, and predefined cams, and much more...Easy to install. Whats new?
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
SWF MOD :
- eigenes SWF-Panel
- Bootlogo geändert
- cardreader support
- swf-panel installierbar (script-executer)
- Enigma2.mo angepasst auf vizyon
- Telnet-login überarbeitet (root / vizyon)
- Videotext auf Wunsch nun Vollbild
- png im Webinterface getauscht (webtv)
- Web-Interface Style geändert
- incubus 0.96, mbox , camd3 mgcamd sind bereits enthalten ( Blue Panel )
Te downloaden op de bekende site
Ik heb alleen de USB versie kunnen vinden, waar heb je de flash versie vandaan gehaald?
Iemand de Enigma2 versie draaien? Bij mij start die nl. niet (rechten staan goed).
Als IncubusCamd niet draait misschien de rechten vergeten aan te passen? Je kan m dan niet starten omdat de execute permissies ontbreken.
Zoek op internet naar "joske dreambox settings", download de settingslijst. Met Dreamboxedit 3.0 kun je deze lijst in je ipbox zetten.
Hierna zou je ook de astra 23,4 moeten kunnen toevoegen.
Ik gebruik dreamboxedit voor het aanpassen van zenderlijsten/favorieten.
Ik wacht even op de versie met blue (PKT) panel.
Ik heb een tijdje naar MTV HD gekeken, bij mij crasht hij niet. Het zal nog wel even duren voordat echt alle bugs eruit zijn maar deze versie ziet er veelbelovend uit. Ik blijf m voorlopig gebruiken.
Inderdaad dreamboxedit, ik zal je een settinglijst sturen.
Ik heb DHCP ook niet aanstaan.
Gebruik interface ja
DHCP nee
Ipadres, SM en gateway invullen.
Probeer netwerk herstarten.
De eerste boot duurde iets langer. Heb je de mogelijkheid om je ipbox via een seriele kabel aan te sluiten op een laptop? Kun je het bootproces volgen.
Kies je het juiste nummer?
ik heb dit multiboot image gebruikt:
http://www.sateliti.info/showthread.php?p=55681
putting these file on your box you will be able to start when your box boots choosing the image you want
about buttons...following Tideglo's choices(he is the enigma2 developer for sifteam images on ipbox hd) you can:
-pressing 1 =NFS
-pressing 2= USB (without internal hd /dev/sda1)
-pressing 3= USB (with internal hd /dev/sda1)
-pressing 4=Flash
De flash heb ik ook geprobeerd maar kreeg schrijf problemen naar bepaalde bestanden. Bovendien zit er in de flash versie geen blue panel van PKT.
Gewoon de USB gebruiken dan heb je ook geen ruimte gebrek. Voordeel is dat je altijd terug kan naar je eigen image die de flash staat.
Ik heb enigma2 nu 2 dagen draaien, werkt prima. Enige probleem dat ik heb is wanneer de receiver uitstaat hij op booting blijft staan zodra ik m aanzet. Nog een keer uit- en aanzetten dan loopt hij wel door.
Ik heb de PKT versie gedownload vanaf het sifteam forum en deze draait nu vanaf USB. Draait prima...
Even kort de stappen die je moet doorlopen:
1. USB stick formatteren EXT2 filesystem (kun je eenvoudig doen vanuit je huidige nlb of sifteam image) Als het goed is staat er nu alleen een map "lost and found" op je stick
2. Upload enigma file naar je USB stick
3. Via een telnet sessie naar de usb map gaan (cd mnt en cd usb) met "ls" kun je zien of je goed zit
4. pak het bestand uit (tar xzf *.gz)
5. Herstarten en multiboot image laden
6. Herstarten en meteen bij het booten 1 of 2 even ingedrukt houden
7. Enigma wordt nu geladen en kan verder geconfigureerd worden. Je kan vanuit het blue panel incubuscamd en vervolgens de .conf/.prio downloaden.
Succes!
Release info:
release 0.3.3:
- fixed a bug on cuberevo-2000hd that caused no audio on all channels
- fixed many bugs on channels scan (hope now it's ok on all sat)
- first try to fix continue freezes bug after a real freeze happens
- fixed some wrong autoresolution bug on many channels (like BBC, csat fr, etc)
- new kernel version (2.6.17 p0041)
- new implementation for CI cams (still needs to use upper slot for first tuner and lower slot for second tuner, this will be fixed soon),
now CI cams should use less cpu time and should rallenty less the enigma2 execution
Ik heb m op een USB stick staan, je kan multiboot gebruiken op de ipbox. Ik moet nog wel een Incubuscamd erin zetten.
Je kan de flash versie rustig uitproberen, bevalt E2 niet kun je de NLB versie er weer opzetten.
Klaar, ik heb nu astra 1,2,3 en Hotbird. Wel een probleem met de Astra 3 (23,5), ik heb in het menu bij de satelliet configuratie geen signaal (0,0). Dit verbaasde me want bij de andere 3 satellieten had ik wel een goed signaal. Met de Visiosat B5 houder hoef je dan alleen nog de LNB iets naar beneden of boven bij te stellen. Echter bij het kiezen van een Astra 3 zender heb ik wel goed signaal en beeld....erg vreemd maar alles werkt nu tenminste.
Ik heb ook de 910, gaat prima. Heb de Astra1 en Hotbird via diseqc geconfigureerd. Morgen het dak op voor de Astra3.
Verwacht dat Sifteam binnenkort wel weer met een nieuwe versie uitkomt. Ik zou gewoon nog even afwachten...
Ik heb deze ontvanger nu ongeveer 2 maanden en ben er tot dusver tevreden over. Momenteel staat er bij mij de laatste release van Sifteam op en deze draait stabiel.
De eerste software releases zorgden voor nogal wat vastlopers in combinatie met incubusCamd, nu echter nog zelden. Ik heb er een externe schijf op aangesloten (esata) en opnemen/afspelen werkt ook prima.
Ik vind het nu al een goede HD ontvanger met ook nog veel potentie voor de toekomst.
ipbox 910hd niet meer te flashen
in Overige merken
Heb je al een andere stick geprobeerd? Je moet overigens geen usb verlengkabel gebruiken.
