klbob
56 -
Berichten die geplaatst zijn door klbob
net vastgelopen. dit staat er als in putty wanneer hij vast zit.
-sh: syntax error: unexpected "("
root@AZBoxHD:~# 21:24:19 5B0050 r localuser emmtype=shared, len=63, idx=11, cnt=1: written (152 m
s) by ziggo
root@AZBoxHD:~# 21:24:35 5B4300 c localuser (0604&000000/00CC/44:E5E5): found (191 ms) by ziggo
root@AZBoxHD:~# 21:24:56 5B4300 c localuser (0604&000000/00CC/44:2173): found (193 ms) by ziggo
root@AZBoxHD:~# 21:25:17 5B4300 c localuser (0604&000000/00CC/44:E291): found (191 ms) by ziggo
root@AZBoxHD:~# 21:25:32 5B0050 r localuser emmtype=shared, len=63, idx=40, cnt=2: written (160 m
s) by ziggo
root@AZBoxHD:~# 21:25:38 5B4300 c localuser (0604&000000/00CC/44:3950): found (191 ms) by ziggo
root@AZBoxHD:~# 21:25:59 5B4300 c localuser (0604&000000/00CC/44:D465): found (192 ms) by ziggo
root@AZBoxHD:~# 21:26:20 5B4300 c localuser (0604&000000/00CC/44:FC2F): found (191 ms) by ziggo
root@AZBoxHD:~# 21:26:29 5B0050 r localuser emmtype=shared, len=63, idx=50, cnt=1: written (152 m
s) by ziggo
root@AZBoxHD:~#
net weer een vastloper met oscam. wanneer ik deze start komt er dit:
root@AZBoxHD:~# /etc/init.d/oscam start &
root@AZBoxHD:~# Starting oscam:.
20:07:48 0 s log_list_thread thread started
20:07:48 0 s >> OSCam << cardserver started, version 1.20-unstable_svn, build #6082 (mips-tuxbox-linux)
20:07:48 0 s version=1.20-unstable_svn, build #6082, system=mips-tuxbox-linux, nice=-1
20:07:48 0 s client max. idle=120 sec, debug level=0
20:07:48 0 s max. logsize=10 Kb, loghistorysize=4096 bytes
20:07:48 0 s client timeout=900 ms, fallback timeout=1500 ms, cache delay=120 ms
20:07:48 0 s WARNING: fallbacktimeout adjusted to 800 ms (must be smaller than clienttimeout (900 ms))
20:07:48 0 s WARNING: fallbacktimeout adjusted to 1600 ms (must be greater than serialreadertimeout (1500 ms))
20:07:48 0 s WARNING: clienttimeout adjusted to 1600 ms (must be greater than serialreadertimeout (1500 ms))
20:07:48 0 s Cannot open file "/var/tuxbox/config/oscam.services" (errno=2 No such file or directory)
20:07:48 0 s userdb reloaded: 1 accounts loaded, 0 expired, 0 disabled
20:07:48 0 s signal handling initialized (type=sysv)
20:07:48 0 s can't open file "/var/tuxbox/config/oscam.srvid" (err=2 No such file or directory), no service-id's loaded
20:07:48 0 s can't open file "/var/tuxbox/config/oscam.tiers" (err=2 No such file or directory), no tier-id's loaded
20:07:48 0 s can't open file "/var/tuxbox/config/oscam.provid" (err=2 No such file or directory), no provids's loaded
20:07:48 0 s can't open file "/var/tuxbox/config/oscam.ird" (errno=2 No such file or directory) irdeto guessing not loaded
20:07:48 0 s Starting listener 0
20:07:48 0 s monitor: disabled
20:07:48 0 s camd35: disabled
20:07:48 0 s cs378x: disabled
20:07:48 0 s newcamd: Bind request failed, waiting another 119 seconds
20:07:49 0 s newcamd: Bind request failed, waiting another 118 seconds
20:07:50 0 s newcamd: Bind request failed, waiting another 117 seconds
enz. ik moet dan rebooten om het te laten werken
heren,
kan iemand bevestigen of dat de volgende CI modules werken met enigma 2
Ziggo CI+ Module Neo of de Ziggo CI+ Module Smit
softcam met ziggo en E2 werken niet meer sinds 1.5.x
alvast bedankt,
klbob
werkt nog steeds niet met ziggo. zowel cccam als oscam lopen regelmatig vast
bij mij blijft softcam problemen geven met RTI.
zowel cccam als oscam hangen regelmatig.
heeft iemand een NEOTION Ziggo CI+ Cam Module in zijn azbox zitten en werkt dit goed?
alvast bedankt,
klbob
Cccam stopt, box reageerd nog wel. De kaart werkt niet meer, ook de share niet.
Webif (:16001) is dan ook niet meer te bereiken. Kortom, ik denk dat de service gewoon stopt.
Overigens blijft cccam wel draaien als er geen kaart in de box zit (dus via Share).
Ik heb hetzelfde probleem, dit is sinds versie 1.5 zoals ik op internet lees is het alleen bij gebruikers met alleen ziggo.
Gebruikers met ziggo en sat hebben dit probleem niet
Met powerboard is het probleem niet, maar werkt de media center niet zo goed.
Enorme audio-sync problemen (al vanaf RTI Core 1.5)! Geluid is er, gok ik, minstens 500ms eerder dan het beeld.
En nog voor ik dit uitgetypt heb, stopt ook cccam er al weer mee. Heb de cccam geïnstalleerd vanonder de blauwe toets.
Het is echt cccam wat ermee gestopt is, want ik kan mijnip:16001 ook niet meer bereiken. Zit iets goed fout vanaf RTI 1.5.
Terug maar weer naar 1.4.
Sattools,
ik heb dit probleem ook in 1.5.x op verschillende manieren cccam geinstalleerd maar altijd het zelfde probleem bij 1.3 (1.4 niet geprobeerd) ook vastlopers maar minder vaak +/- 1x per week
ik heb dit probleem aangekaart bij RTI maar ben geband omdat ik het over cccam (EMU) had
ze maken mooie dingen maar kunnen geen kritiek hebben volgens mij.
klbob
ik heb nu E2 draaiend een aantal dagen.
het tv beeld is heel goed en zappen gaat ook lekker snel.
nu kan ik in de mediacenter alleen 1 nummer afspelen en dan stop hij.
hoe kan ik alles selecteren en deze random afspelen.
als ik op de gele knop (alles selecteren) klik crashed E2.
en hoe kan ik alles random laten afspelen.
alvast bedankt,
marcel.
heren,
hoe kan ik de zenderlijst van ziggo op volgorde krijgen?
is dit een txt bestand wat ik kan wijzigen?
alvast bedankt,
ps:
is er een handleiding hoe E2 werkt, hoe opnemen timeshift enz.
OPGELOST
met de nieuwe ziggo kaart (oranje).
werkt het met cccam 2.2.1.
azbox opstarten zonder kaart
cccam 2.2.1 installeren en activeren
herstarten
naar nederland 1 zappen en wachten tot je beeld hebt.
cccam opnieuw herstarten (blauwe knop)
kaart er in en naar nederland 2 of andere zender gaan
kan iemand mij nog een keer cccam 2.1.4 geven.
ik heb nu een oranje ziggo kaart en wil het nog een keer proberen.
Als iemand een manier heeft dat werkt wil ik het wel proberen.
kaart is 4010 2092....
met multicas werkt deze wel, zit nu op firmware 9.5308 met multicas 1.70D-0B
ik wil iedereen bedanken voor de moeite die jullie er in hebben gestoken mij te helpen.
Het is op dit moment niet mogelijk om met een oranje casema kaart tv te kijken op E2.
geprobeerd met CCcam 2.1.4, 2.2.1 r0 en r1
ben 13 uur bezig geweest en het werkt niet.
ga nog een keer proberen met een nieuwe versie.
marcel
gedaan, maar nog geen beeld op ned 2
op de cccam pagina krijg ik het volgende. de kaart zit er nu in
Current time 17:22:50
NodeID: 31465b96c889e604
Uptime: 4244d 15:21:35
Connected clients: 0
Active clients: 0
Total handled client ecm's: 0
Total handled client emm's: 0
Peak load (max queued requests per workerthread):
de rechten van cccam.cfg moeten toch 644 zijn?
ga vanavond testen
als ik de box opstart met de kaart er in dan start cccam niet.
als ik de kaart er uit haal en cccam herstart dan werkt hij wel.
mogelijk is er een conflict met de kaart
het is een casema irdeto kaart met oranje rand.
alles nog een keer gedaan met de output hieronder
root@AZBox:~# netstat -l | grep 16001
tcp 0 0 0.0.0.0:16001 0.0.0.0:* LISTEN
root@AZBox:~# ps ax | grep CCcam
1869 root 117m S /usr/bin/CCcam_2.2.1
1870 root 117m S /usr/bin/CCcam_2.2.1
1871 root 117m S /usr/bin/CCcam_2.2.1
1872 root 117m S /usr/bin/CCcam_2.2.1
1873 root 117m S /usr/bin/CCcam_2.2.1
1874 root 117m S /usr/bin/CCcam_2.2.1
1875 root 117m S /usr/bin/CCcam_2.2.1
1876 root 117m S /usr/bin/CCcam_2.2.1
1877 root 117m S /usr/bin/CCcam_2.2.1
1878 root 117m S /usr/bin/CCcam_2.2.1
1879 root 117m S /usr/bin/CCcam_2.2.1
1880 root 117m S /usr/bin/CCcam_2.2.1
1881 root 117m S /usr/bin/CCcam_2.2.1
1882 root 117m S /usr/bin/CCcam_2.2.1
1883 root 117m S /usr/bin/CCcam_2.2.1
1902 root 2648 S grep CCcam
root@AZBox:~# ls /tmp/ecm*
/tmp/ecm.info /tmp/ecm0.info
root@AZBox:~# cat /temp/ecm.info
cat: can't open '/temp/ecm.info': No such file or directory
root@AZBox:~#
ja, vanaf het begin doet hij het al goed. dat is nu 1,5 jaar
de melding bij kaart op de pagina is
card reader /dev/sci0
no or unknown card inserted
heb nu wel beeld op de pagina http://192.168.1.10:16001
alleen de rest doet het nog niet
Current time 21:26:37
NodeID: d6e150f96adde844
Uptime: 4243d 19:25:22
Active clients: 0
gedaan wat je aangaf,
opnieuw opgestart zonder kaart
hij stopt bij 100 geen epg info
na het opstarten naar ned 1 gegaan
na 30 sec. kaart er in.
2 min. gewacht maar geen melding cccam is started of wat er op lijkt er staat alleen nederland 1 HD
naar ned 2 gegaan maar geen beeld
cccam herstart maar nog geen beeld
ik heb dit getest, ik krijg geen realy started te zien in beeld of op het scherm. er staat op het laatst 100
dan ga ik naar ned 1
als ik beeld heb stop ik de kaart er in en ga naar ned 2.
het beeld bevriest en na 30sec. nog geen beeld
1 dvb-c tuner voor de rest niets
CI+ module icm Enigma2?
in Overige merken
Het is niet mogelijk om een CI+ module in de AZbox te stoppen. deze word niet ondersteund.
