hasoo
4 -
Berichten die geplaatst zijn door hasoo
Origineel bericht van: Diddendigiturk zou wel werken met een cw modulle. zelf heb ik het niet getest.
greetz
i2 kaart met een cw module ?
vreemd? -
je hoeft geen prio lijst nodig heb als je laatste cam gebruikt toch?
ik denk dat je deze toevogen
SERVER LISTEN PORT: 12000
C: 10.0.0.6 12000 tv kijken yes
[plugin] multi-mediathek plugin v 2.3
in Vu Plus
wat je zelf gebruikt voor kidslock?
hier
Weet iemand trouwens wat de default pin code is?
Version 2.9 [19.04.2011]
* Hide "Caching Video Window" with blue-button.
* Show finished downloads in Download-List and play them directly from there.
* If Gstreamer FLV and/or AVI not installed, ask if you want to install it through image-feeds.
* Create a .meta file when saving movie.
* Fixed too many linebreaks in bookmark file.
Version 2.8 [09.04.2011]
* Improved function that checks if cache-folder is inside flash-memory.
* /tmp and /media/ba folders can now be used as cache-folder.
* Download-Location for Movies can now get changed in plugin-settings.
* Delete downloaded file when aborting download-task.
* Check-For-Update on Startup can not get disabled anymore.
* Added Image-Scaler Selection to Settings Menu:
Please note: getThumbnai()l is faster but should only be used on enigma2 >08.04.2011 due to a mem-/fd-leak!
Version 2.7 [06.04.2011]
* Support for Next/Previous Page links included in some feeds.
* Fixed Search Function having problems when entering multiple search terms.
Version 2.6 [04.04.2011]
* Check if Cache-Folder is on a external device and has write-permissions.
* Added a Download-Overview to Options-Menu to show current running downloads
* Use startDecode() instead getThumbnail() to create thumbnails. This is to avoid a mem/fd leak in enigma2's DecodeExif function.
* Use Mozilla as UserAgent when downloading thumbnails.
Version 2.5 [31.03.2011]
* Fix download external pages on box.
Version 2.4 [27.03.2011]
* Added VLC Support for cached-playback
* Make it possible to change UserAgent via feeds
Version 2.3 [23.03.2011]
* Improved Error-Handling and Resume-Support for downloading files ...
* Bugfix: Fixed bad calculation of filesize when downloading rtmp:// streams
Version 2.2 [18.03.2011]
* Changes: Mapped MENU Button to a list of different options like add/delete bookmarks, view settings ect.
* Changes: Show Error Message with some informations when download failed (cached-playback)
* Changes: Replaced rtmpdump-tool by an older version with less bugs.
* Bugfix: Fixed possible Greenscreen in calculating download-progress.
* Bugfix: Fixed possible Greenscreen in movielist when error in feeds.
Version 2.1 [15.03.2011]
* Started to improve Bookmark System.
* Replaced FLVStreamer by RTMPDump to support rtmpe:// and rtmpte:// streams.
Version 2.0 [13.03.2011]
* Added support for search functions for several feeds.
Version 1.9 [13.03.2011]
* Changes: Improved Download Function and use TaskManager to download multiple files.
* Changes: Improved Error-Handling a little bit.
* Changes: Improved Image Cache a little bit.
* Changes: Ask if you want to use cached-play when direct-play not working.
* Changes: Use Moviename as filename when saving movie on HDD.
* Changes: FLVStreamer Binary is now part of the plugin package.
* Bugfix: Download Progress was not working with FLV Streams.
* Bugfix: Old Settings were not restored when leaving Settings-Menu with red or exit.
* Bugfix: Aborting Cached-Playback also aborted download-tasks running in background
Version 1.8 [12.03.2011]
* Changes: Improved Error-Handling and Error-Messages for cached-playback.
* Changes: Show Moviename instead Filename in infobar when using cached-playback.
* Bugfix: Fixed temp-files getting stored in /home/root instead /mediathek/tmp folder sometimes when using cached-playback.
Version 1.7 [11.03.2011]
* Changes: Added VLC-Player Support for cached-playback.
* Bugfix: Fixed possible greenscreen introduced in last version.
Version 1.6 [11.03.2011]
* Added Support for rtmp:// streams (cached-playback from only)
Note: The FLVStreamer Plugin needs to be installed for this!
Version 1.5 [10.03.2011]
* Changes: Experimental VLC-Support for "direct-play" function.
If dreambox does not support video-codec, it will ask you if you want to stream it via VLC Server on PC.
* Changes: Show Plugin Version in Title of Settings-Screen.
* Changes: Show error-message when trying to save movie on HDD which does not use http or ftp format.
* Bugfix: Fixed GreenScreen when entering wrong parentel-control PIN 3 times.
Version 1.4 [08.03.2011]
* Changes: When changing cache-folder in settings, delete old folder and directly create new one.
* Bugfix: Fixed GreenScreen when leaving plugin after changing cache-folder.
Version 1.3 [08.03.2011]
* Changes: Improved Image-Cache functions.
* Changes: Refresh Page when leaving Settings-Menu.
* Changes: Settings-Menu only accessable from mainpage.
* Changes: Started to work on SD Skin Support (not finished yet!)
* Changes: Asking for Setup-PIN when enable Adult-Content and youth-protection activated.
Version 1.2 [06.03.2011]
* Changes: Check for plugin-updates on startup.
Version 1.1 [06.03.2011]
* Changes: Use E2 TaskManager to save movies on HDD.
* Changes: Started to implement bookmark function (not finished yet)
* Changes: Show Eventname instead filename in Infobar when playing movie
* Changes: Page-Forwarding to let box download html-page and submit it to webserver for parsing (for youtube)
* Bugfix: Don't stop download-task when leaving movie-info
Version 1.0 [03.03.2011]
* Changes: Back to Movie-Info Screen when playback stopped.
* Changes: Set a Screentitle (for OLED Display)
* Bugfix: Fixed Skin-Transparency Problems.
* Bugfix: Fixed Page Counter.
Version 0.9 [02.03.2011]
* Changes: Added Adult Content Filter to Settings Menu.
* Bugfix: Fixed another possible GreenScreen.
Version 0.8 [02.03.2011]
* Bugfix: Fixed possible GreenScreen.
* Bugfix: Fixed length of cache-folder was limited
Version 0.7 [02.03.2011]
* Changes: Show Error Message when missing Gstreamer addons or video- / audio-codecs not supported
* Changes: Added Settings Menu (mapped to MENU Button) to change some settings and cache-folder
* Bugfix: Only delete image cache when leaving plugin, not category/screen.
Version 0.6 [01.03.2011]
* Changes: Some Skin Changes
* Changes: Clean Image Cache when leaving plugin
* Changes: Show Error message when no supported videos found instead empty list
* Changes: When only 1 video/media available, play it directly instead showing list of available videos
* Bugfix: Really cancel downloading when aborting file-transfer(cached-playback)
Version 0.5 [27.02.2011]
* Bugfix: Fixed GreenScreen when MediaPlayer plugin not installed
Version 0.4 [27.02.2011]
* Changes: Use Alternate-UserAgent to fix direct-playback of Apple Movies
* Changes: Small Skin-Improvements on Movie-Info Screen
Version 0.3 [27.02.2011]
* Bugfix: Fixed GreenScreen when pressing OK when nothing selected
Version 0.2 [26.02.2011]
* Bugfix: Fixed GreenScreen caused by missing background image
