sysEH
12 -
Berichten die geplaatst zijn door sysEH
nee, nog niet geprobeerd, ben nu met de tweede Zero bezig, zal eens zien wat er nu in de webif tevoorschijn komt
@ theparasol,
alles met kabels aangesloten en dezelfde oscam via OpenPli ingeladen, is ook in de webif interface terug te vinden
Sorry, beetje dubbel allemaal, geen idee hoe dit kan gebeuren
Kijkje in de glazen bol:
# oscam.conf generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10656[global]loghistorysize = 1024serverip = 192.168.1.25logfile = /etc/tuxbox/config/log/logfile.logdisableuserfile = 0maxlogsize = 1024usrfile = /etc/tuxbox/config/log/usr.logemmlogdir = /etc/tuxbox/config/log[cache][cs378x]port = 33333suppresscmd08 = 1[dvbapi]enabled = 1au = Canal_Digitaalpmt_mode = 6user = DCG_Duo2_localboxtype = dreambox[webif]httpport = 8081httpallowed = 192.168.1.0-192.168.1.255,127.0.0.1------------------------------------------------------------------------------------# oscam.user generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10656[account]user = DCG_Duo2_localpwd = Duo2description = VuDuo2 woonkamer E&Vhostname = 192.168.1.25au = Canal_Digitaalgroup = 1[account]user = DCG_Zero01pwd = Zero01description = VuZero keuken E&Vhostname = 192.168.1.26au = Canal_Digitaalgroup = 1[account]user = DCG_Zero02pwd = Zero02description = VuZero Slaapkamer E&Vhostname = 192.168.1.27au = Canal_Digitaalgroup = 1[account]user = DCG_Solo2pwd = Solo2description = VuSolo2 M&Mhostname = 192.168.1.28au = Canal_Digitaalgroup = 1[account]user = DCG_Zero03pwd = Zero03description = VuZero Hangarhostname = 192.168.1.29au = Canal_Digitaalgroup = 1------------------------------------------------------------------------------------# oscam.server generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r10656[reader]label = Canal_Digitaaldescription = CanalDigitaal Familiepakketprotocol = internaldevice = /dev/sci0detect = cdmhz = 450cardmhz = 2700group = 1emmcache = 1,3,15,0ratelimitecm = 4ratelimittime = 9000ecmunique = 1srvidholdtime = 2000[reader]label = upper_card_Spareprotocol = internaldevice = /dev/sci1detect = cdmhz = 450cardmhz = 2700group = 2emmcache = 1,3,15,0ratelimitecm = 4ratelimittime = 9000ecmunique = 1srvidholdtime = 2000Nu staan er weer verschillende waarden in het AU veld, maar het belangrijkste is dat het werkt -
Ziehier een kijkje in de glazen bol, je had gelijk, dit is een screenshot van mijn Duo2. Ik ben nog bezig met de rest (nog 2 Zero's te gaan) maar dat zal denk ik wel lukken.
Bedankt voor het meedenken.
Ik heb ook nog wat vragen over de oscam instellingen, ik ben inmiddels zover dat de boxen werken maar op de solo2 duurt het vrij lang voordat er beeld komt na het zappen en soms bevriest het beeld. Dit gebeurd eigenlijk niet op de zero die dezelfde instellingen heeft.
Daarnaast staat er in de Oscam interface onder de kolom AU bij de clients OFF, dat zie ik niet in het screenshot van Mimisiku, vindt het vreemd.
@ Jürgen, vreemd, ik heb op de solo2 al bijna een jaar OpenPli draaien en er ook wel eens mee opgenomen maar bij mijn weten heb ik nooit PAU erop gezet maar dat is misschien mee geinstalleerd, geen idee. Zal er in ieder geval op letten bij de neiuwe installatie dat de plugin erbij staat om irritatie wbt opnemen te voorkomen, denk er overigens over om een nieuwe "schone" Pli op de solo2 te zetten en de VTI op de duo2 en dan op de zero's zowel Pli als VTI, kan ik op twee verschillende en twee dezelfde apparaten het verschil zien.
Laat het hier wel weten.
Thnx
Beste mensen, heb e.e.a nog een nagelezen en de diverse meningen naast elkaar gelegd maar uiteindelijk komt het er dus op neer dat je voor jezelf moet kiezen wat je het makkelijkste en/of beste vindt. Ik heb inmiddels voor de Duo2, de Solo2 en de Zero de images van zowel OpenPli en VTI opgehaald en ga beide images installeren op de diverse modellen, zal dat minstens een maand gebruiken en daarna beslissen welke ik dan op alle boxen zal gaan draaien.
Zal beslist de opmerkingen en aanwijzingen van Tonskidutch volgen, een ieder bedankt voor de commentaren, ik ben wel van plan om na die maand van uitproberen, mijn bevindingen hier te vermelden.
Thnx & Grtz vanuit la douce France
@Drs. IJzerbout,
ik heb geen moeite met aanmelden, maar heb ook al eens een enigma2 voor een topfield opgehaald en krijg nu om de haverklap mail van die duitse site met vragen of ik niet een of andere image wil aanschaffen. Heb hier al een poosje een Solo2 met OPENPli draaien en dat bevalt ook wel maar heb inmiddels een probleem met de Webif interface en wil straks 5 VU boxen koppelen en daar een mediaplayer op de Duo2 bij draaien en eigenlijk zo min mogelijk problemen hebben.
heb ik het goed begrepen dat je voor VTI jezelf moet registreren voordat je de image kan downloaden?
Ik ben al een poosje diverse fora aan het doorlezen en kom hier regelmatig 3 verschillende images voor de VU+ tegen. Meestal wordt er met OPENPli gewerkt, maar ik zie ook VTI en OpenATV.
Ik wil hier een Duo2, een Solo2 en drie Zero's installeren, moet me nog wel verder inlezen in oscam, maar dat is een ander verhaal, wat ik graag zou willen weten is wat ik het beste als image kan installeren,uiteraard op alle VU's dezelfde.
Hoor graag, bij voorbaat dank.
Welke software op VU+
in Vu Plus
Ik heb op onze Solo2 en Duo2 eens gekeken en daar staat de app niet in de lijst te downloaden plugins, in de Zero staat het wel in de lijst.
Misschien omdat zowel in de Solo2 en de Duo2 een vaste schijf zitten en tijdens de installatie dat wordt herkend en automatisch wordt geladen. Het kan zijn dat het standaard in de images van de Duo en Solo zit, de images zijn niet voor niets verschillend pper apparaat, zal allemaal het de hardware en de mogelijkheden te maken hebben.
@Tonskidutch, heb inmiddels op 4 boxen de laatste OpenPli geladen, had op de Solo2 al OpenPli staan en heb dat vernieuwd, op de Duo2 in eerste instantie de laatste VTI maar bij het installeren van Oscam kreeg ik geen beeld, verschillende versies van Oscam geprobeerd zonder resultaat, heb toen OpenPli 4 erop geladen, Oscam gedownload en onmiddelijk beeld.
Ben nu bezig om alle boxen via Oscam in ons netwerk te sharen, is best nog een klus overigens.
Grtz.
