user2705
8 -
Berichten die geplaatst zijn door user2705
werkt ook niet niet, heel of en toe krijgt hij 1 ecm goed en heb je 10 sec beeld maar daarna weer steeds not found.
oscam.config
# oscam.conf generated automatically by Streamboard OSCAM 1.20-unstable_svn SVN r11107 # Read more: http://www.streamboard.tv/svn/oscam/trunk/Distribution/doc/txt/oscam.conf.txt [global] logfile = stdout;/var/keys/oscam.log disableuserfile = 0 usrfileflag = 1 clienttimeout = 6000 fallbacktimeout = 1500 unlockparental = 1 nice = -1 maxlogsize = 256 waitforcards = 0 preferlocalcards = 1 dropdups = 1 usrfile = stdout;/var/keys/usr.log cwlogdir = stdout;/var/keys/cw.log emmlogdir = stdout;/var/keys/emm.log lb_save = 100 lb_stat_cleanup = 24 lb_savepath = /tmp/.oscam/stat [cache] max_time = 10 [dvbapi] enabled = 1 au = 1 pmt_mode = 1 request_mode = 1 delayer = 60 user = localuser boxtype = dreambox [webif] httpport = 9999 httpuser = xxx httppwd = xxx httprefresh = 5 httppollrefresh = 5 httpshowmeminfo = 1 httpshowuserinfo = 1 httpshowcacheexinfo = 1 httpshowecminfo = 1 httpshowloadinfo = 1 httpallowed = 0.0.0.0-255.255.255.255 aulow = 1 hideclient_to = 1 http_status_log = 1
oscam.user
[account] user = localuser au = 1 emmreassembly = 0 group = 1,2,3,4
oscam.server
[reader] label = canal_digitaal2 protocol = internal device = /dev/sci0 ident = 0100:000000,00006A group = 1 [reader] label = canal_digitaal protocol = internal device = /dev/sci0 enable = 0 services = basis_canal_digitaal autospeed = 0 caid = 0100 detect = cd mhz = 540 cardmhz = 2700 ident = 0100:000000,00006A group = 3 emmcache = 1,1,0,0 disablecrccws = 1 ratelimitecm = 4 ratelimittime = 9000 ecmunique = 1 srvidholdtime = 2000 cooldown = 30,600 [reader] label = ziggo enable = 0 protocol = internal device = /dev/sci0 caid = 0604 boxkey = 1122334455667788 rsakey = 3C8633AAC0D367533DEC7BB2EEEDEB8CA3ADA52E58B99BB34672783277A1DAAC3B6106AD0909774E031B2A6E30195B437683AD0FC599B87D08CEA47BE1B6C76A ecmwhitelist = 0604:44 detect = cd mhz = 500 cardmhz = 600 ident = 0604:000000 chid = 0604:000000,00000B,007FFD,000385,0003E4,000384,00FFE0,00FFD8 group = 1 emmcache = 1,1,0,0 blockemm-unknown = 1 blockemm-g = 1 lb_weight = 300 dropbadcws = 1 auprovid = 0BA1F6
zonder services en met de versie 11164 ook geen succes hmm...
17D1 is tegenwoordig discovery.
maar ook met geen services is het geen succes.
zal even andere versie oscam proberen van de week.
ja ook al, en kastje opnieuw gestart.
ik denk dat het met dit te maken heeft "(reader) canal_digitaal [seca] Error processing ecm for caid 0100, provid 00006A, srvid 17D1, servicename: 0100@00006A:17D1 unknown"
weten jullie hoe je oscam voor android can compilen stap voor stap?
dan kan ik verschillende versies maken ik heb zelf een server draaien met centos6.
services weg gehaald maar nog steeds hetzelfde.
Ik heb een Amiko A3 Combo ism Ziggo en CDNL.
Op deze box draaid oscam R11107 voor android.
Met ziggo werkt alles goed, ook de interne cardlezer.
Maar met Cdnl ziet hij de kaart wel maar geeft "not found" aan
deze zender staat wel in mijn pakket. met een cccam lijntje van andere box werkt deze wel goed.
het goed dus om de interne kaartlezer en dat het mis gaat met het verwerken van de ecm..
Weten jullie nog raad voor mij?
ik heb hier een stukje log ervan
2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] cardreader_do_checkhealth: reader->card_status = 2, ret = 1 2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] IFD: Receive size 1 bytes, delay 0 us, timeout=9920000 us 2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] IFD: Receive succesful 2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] IFD: Setting timeout to 13 ETU (895 us) 2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit size 92 bytes, expected len 2 bytes, delay 0 us, timeout=895 us 2015/11/23 18:46:00 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit: 2015/11/23 18:46:00 2E012700 r (reader) 00 82 37 B6 4E 3F 65 76 8B 74 BB 5C FA 20 CB 33 2015/11/23 18:46:00 2E012700 r (reader) A3 4E D0 20 66 97 24 95 FE 97 29 19 4F 7A 3F 30 2015/11/23 18:46:00 2E012700 r (reader) A8 87 B5 5D 0B 58 CF 99 60 8F 31 EF 92 65 13 2A 2015/11/23 18:46:00 2E012700 r (reader) 44 2B C1 D5 5C 2C E0 3D 29 42 CA 17 4A 07 92 C5 2015/11/23 18:46:00 2E012700 r (reader) AC A9 CE A3 9B 09 4C 96 A8 13 F3 BA 91 67 0C DF 2015/11/23 18:46:00 2E012700 r (reader) 85 61 F2 B7 59 C0 13 04 B9 52 15 47 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit succesful 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Setting timeout to 144000 ETU (9920000 us) 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Receive size 1 bytes, delay 0 us, timeout=9920000 us 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Setting timeout to 13 ETU (895 us) 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit size 5 bytes, expected len 1 bytes, delay 0 us, timeout=895 us 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit: 2015/11/23 18:46:01 2E012700 r (reader) C1 3C 01 5C 5C 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Transmit succesful 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Setting timeout to 144000 ETU (9920000 us) 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] IFD: Receive size 1 bytes, delay 0 us, timeout=9920000 us 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] cardreader_do_ecm: after csystem->do_ecm rc=0 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] cardreader_do_ecm: ret rc=0 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] cardreader_process_ecm: cardreader_do_ecm returned rc=0 (ERROR=0) 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] Error processing ecm for caid 0100, provid 00006A, srvid 17D1, servicename: 0100@00006A:17D1 unknown 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] ecm hash: 5D496FAF6638C13ADEEB0E11BA4CDA8C real time: 378 ms 2015/11/23 18:46:01 35CCB084 c (ecm) localuser (0100@00006A/5C00/17D1/64:5D496FAF6638C13ADEEB0E11BA4CDA8C): not found (379 ms) by canal_digitaal 2015/11/23 18:46:01 35CCB084 c (dvbapi) Demuxer 0 restarting decodingrequests after 2 ms with 1 enabled and 5 disabled ecmpids! 2015/11/23 18:46:01 35CCB084 c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0100 PROVID 00006A ECMPID 072D ANY CHID PMTPID 09C1 VPID 0219 2015/11/23 18:46:01 2E012700 r (reader) canal_digitaal [seca] cardreader_do_checkhealth: reader->card_status = 2, ret = 1 2015/11/23 18:46:01 35CCB084 c (ecm) localuser (0100@00006A/5C00/17D1/64:5D496FAF6638C13ADEEB0E11BA4CDA8C): not found (3 ms) by canal_digitaal 2015/11/23 18:46:02 35CCB084 c (dvbapi) Demuxer 0 restarting decodingrequests after 2 ms with 1 enabled and 5 disabled ecmpids! 2015/11/23 18:46:02 35CCB084 c (dvbapi) Demuxer 0 trying to descramble PID 2 CAID 0100 PROVID 00006A ECMPID 072D ANY CHID PMTPID 09C1 VPID 0219 2015/11/23 18:46:02 2E012700 r (reader) canal_digitaal [seca] cardreader_do_checkhealth: reader->card_status = 2, ret = 1 2015/11/23 18:46:02 35CCB084 c (ecm) localuser (0100@00006A/5C00/17D1/64:5D496FAF6638C13ADEEB0E11BA4CDA8C): not found (1 ms) by canal_digitaal
Unix starttime: 1448287039 Starttime: 23.11.2015 14:57:19 Version: oscam-1.20-unstable_svn-r11107 Compiler: arm-linux-androideabi Box type: generic (generic) PID: 3684 TempDir: /tmp/.oscam ConfigDir: /var/tuxbox/config/ WebifPort: 9999 Web interface support: yes LiveLog support: yes jQuery support intern: yes Touch interface support: yes SSL support: no DVB API support: yes DVB API with AZBOX support: no DVB API with MCA support: no DVB API with COOLAPI support: no DVB API with COOLAPI2 support: no DVB API with STAPI support: no DVB API with STAPI5 support: no DVB API read-sdt charsets: yes Irdeto guessing: yes Anti-cascading support: yes Debug mode: yes Monitor: yes Loadbalancing support: yes Cache exchange support: yes CW Cycle Check support: yes LCD support: no LED support: no Clockfix with realtime clock: yes IPv6 support: no camd 3.3x: no camd 3.5 UDP: yes camd 3.5 TCP: yes newcamd: yes CCcam: yes CCcam share: yes gbox: yes radegast: yes scam: yes serial: yes constant CW: yes Pandora: yes ghttp: yes Reader support: yes Nagra: yes Irdeto: yes Conax: yes Cryptoworks: yes Seca: yes Viaccess: yes NDS Videoguard: yes DRE Crypt: yes TONGFANG: yes Bulcrypt: yes Griffin: yes DGCrypt: yes cardreader_phoenix: yes cardreader_internal_azbox: no cardreader_internal_coolapi: no cardreader_internal_coolapi2: no cardreader_internal_sci: yes cardreader_sc8in1: yes cardreader_mp35: yes cardreader_smargo: yes cardreader_pcsc: no cardreader_smartreader: no cardreader_db2com: yes cardreader_stapi: no cardreader_stapi5: no cardreader_stinger: yes
[reader] label = canal_digitaal protocol = internal device = /dev/sci0 services = cdnl autospeed = 0 caid = 0100 detect = cd mhz = 540 cardmhz = 2700 ident = 0100:000000,00006A group = 1 emmcache = 1,1,0,0 disablecrccws = 1 ratelimitecm = 4 ratelimittime = 9000 ecmunique = 1 srvidholdtime = 2000 cooldown = 30,600
ik heb dit en dit werkt bij mij goed
[reader] label = ziggo protocol = internal device = /dev/sci0 caid = 0604 rsakey = 3C8633AAC0D367533DEC7BB2EEEDEB8CA3ADA52E58B99BB34672783277A1DAAC3B6106AD0909774E031B2A6E30195B437683AD0FC599B87D08CEA47BE1B6C76A boxkey = 1122334455667788 detect = cd mhz = 600 cardmhz = 600 ident = 0604:000000 group = 1 emmcache = 1,3,2 saveemm-u = 1 saveemm-s = 1 saveemm-g = 1
Oscam android en canal digitaal
in CI, CI+, (soft)cams en smartcards
deze staan ook uit met enable = 0
gebruik ziggo als ik niet aan het testen ben met cdnl, ziggo kaart werkt top in deze ontvanger.
cdnl kaart werkt ook wel maar alleen met mcas maar niet met oscam nog.
