BlackBurn
3 -
Berichten die geplaatst zijn door BlackBurn
probeer het eens met alleen
[account]
user = dvbapiau
au = 1
group = 1
dit in Oscam.user
of au niet canaldigitaal maar een 1
Helaas, zelfde resultaat, heb stukje zelfs 1 op 1 overgenomen.
2015/06/01 20:19:27 22C7FD0 c (newcamd) client connected to 52010 port 2015/06/01 20:19:27 22C7FD0 c (client) encrypted newcamd:52010-client 10.10.11.5 granted (dvbapiau, au=auto (1 reader)) 2015/06/01 20:19:27 22C7FD0 c (newcamd) user dvbapiau authenticated successfully (Tvheadend) 2015/06/01 20:19:27 22C7FD0 c (newcamd) AU enabled for user dvbapiau on reader CanalDigitaal 2015/06/01 20:21:13 22C7FD0 c (reader) CanalDigitaal [seca] dvbapiau emmtype=global, len=116, cnt=1: skipped (0 ms) 2015/06/01 20:21:13 22C7FD0 c (-) -- Skipped 1 duplicated log lines -- 2015/06/01 20:21:13 22C7FD0 c (-) -- Skipped 13 duplicated log lines -- 2015/06/01 20:21:13 22C7FD0 c (ecm) dvbapiau (0100&00006A/5C00/17CA/64:F2DC1175DB032AA376F5C5BB20A51BBF): found (341 ms) by CanalDigitaal - SBS 6 HD 2015/06/01 20:21:14 22C7FD0 c (ecm) dvbapiau (0100&00006A/5C00/17CA/64:B93622328658FF17984244B758C56D74): found (325 ms) by CanalDigitaal - SBS 6 HD 2015/06/01 20:21:18 22C7FD0 c (reader) CanalDigitaal [seca] dvbapiau emmtype=global, len=116, cnt=1: skipped (0 ms) 2015/06/01 20:21:24 22C7FD0 c (-) -- Skipped 29 duplicated log lines -- 2015/06/01 20:21:24 22C7FD0 c (ecm) dvbapiau (0100&00006A/5C00/17CA/64:81124FC8A96CE1E554620A2C174B57C0): found (320 ms) by CanalDigitaal - SBS 6 HD 2015/06/01 20:21:26 22C7FD0 c (reader) CanalDigitaal [seca] dvbapiau emmtype=global, len=116, cnt=1: skipped (0 ms) 2015/06/01 20:21:34 22C7FD0 c (-) -- Skipped 44 duplicated log lines -- 2015/06/01 20:21:34 22C7FD0 c (ecm) dvbapiau (0100&00006A/5C00/17CA/64:A530CC998B25B4C19FE1FE5DBB11A4FB): found (321 ms) by CanalDigitaal - SBS 6 HD 2015/06/01 20:21:38 22C7FD0 c (reader) CanalDigitaal [seca] dvbapiau emmtype=global, len=116, cnt=1: skipped (0 ms) 2015/06/01 20:21:44 22C7FD0 c (-) -- Skipped 29 duplicated log lines -- 2015/06/01 20:21:44 22C7FD0 c (ecm) dvbapiau (0100&00006A/5C00/17CA/64:493AAB80721274CBE752159CDF9C3667): found (328 ms) by CanalDigitaal - SBS 6 HD 2015/06/01 20:21:46 22C7FD0 c (reader) CanalDigitaal [seca] dvbapiau emmtype=global, len=116, cnt=1: skipped (0 ms)
Hier ga ik er vanuit, dat deze regel aangeeft, dat er EMM's ontvangen zijn, ik zie de counter ook oplopen in de web-interface.
Onlangs heb ik mijn complete set-up veranderd/geüpdatet, van TV-server Argus-TV naar TVHeadend en ook een nieuwe installatie van Oscam gedaan.
Echter nu heb ik het vermoeden dat mijn CD kaartje niet meer geüpdatet wordt en zou dit graag willen valideren, aangezien er nu nog tijd is om het op te lossen
Mijn huidige status van het kaartje is:
admin: 2015-06-20 - Mediaguard
PBM: 2015-06-18 - Canal Digitaal NL (19E/23E)
Ik had verwacht dat deze datum ondertussen al opgeschoven zou zijn, kan iemand dit verifiëren wat zijn status/datum is?
Dit is een stukje logging binnen Oscam, connectie van TVHeadend.
2015/05/30 19:28:50 80ABA0 c (newcamd) client connected to 52010 port 2015/05/30 19:28:50 80ABA0 c (client) anonymous disconnected from 10.10.11.5 2015/05/30 19:28:50 80B240 c (newcamd) client connected to 52010 port 2015/05/30 19:28:50 80B240 c (client) encrypted newcamd:52010-client 10.10.11.5 granted (tv1, au=on (1 reader)) 2015/05/30 19:28:50 80B240 c (newcamd) user tv1 authenticated successfully (Tvheadend) 2015/05/30 19:28:50 80B240 c (newcamd) AU enabled for user tv1 on reader CanalDigitaal 2015/05/30 19:29:07 80B240 c (ecm) tv1 (0100&00006A/5C00/17CA/64:F9E053258DFBFD7C1F94E1BDD6655CDF): found (336 ms) by CanalDigitaal - SBS 6 HD 2015/05/30 19:29:09 80B240 c (reader) CanalDigitaal [seca] tv1 emmtype=global, len=116, cnt=1: skipped (0 ms) 2015/05/30 19:29:10 80B240 c (-) -- Skipped 10 duplicated log lines -- 2015/05/30 19:29:10 80B240 c (ecm) tv1 (0100&00006A/5C00/17CA/64:ED53F8ABF13FE138E1C71307ACD9B8AA): found (322 ms) by CanalDigitaal - SBS 6 HD 2015/05/30 19:29:13 80B240 c (reader) CanalDigitaal [seca] tv1 emmtype=global, len=116, cnt=1: skipped (0 ms)
Mijn config.
oscam.server
[reader] label = CanalDigitaal description = CanalDigitaal NL Lokaal protocol = smargo device = /dev/ttyUSB0 caid = 0100 detect = cd mhz = 480 cardmhz = 369 ident = 0100:000000,00006A,00006 smargopatch = 1 group = 1 emmcache = 1,1,15,0 ratelimitecm = 4 ratelimittime = 9000 srvidholdtime = 2000
oscam.user[account] user = tv1 pwd = ***** description = TVHeadend caid = 0100 keepalive = 1 au = CanalDigitaal group = 1 cccmaxhops = 5 cccignorereshare = 1 cccstealth = 0
oscam.config[global] logfile = /var/log/oscam.log pidfile = /tmp/oscam.pid disableuserfile = 0 fallbacktimeout = 2600 nice = -1 maxlogsize = 1024 preferlocalcards = 1 block_same_ip = 0 block_same_name = 0 usrfile = /var/log/oscam.userlog lb_mode = 10 lb_save = 100 lb_savepath = /var/log/stat [cache] [cs357x] port = 24110 [newcamd] port = 52010@0100:00006A key = 0102030405060708091011121314 mgclient = 1 [cccam] port = 12345 nodeid = BA79345A1017141C version = 2.3.0 reshare = 3 forward_origin_card = 1 [monitor] port = 988 aulow = 120 hideclient_to = 45 [webif] httpport = 80 httpuser = Rob httppwd = ***** httprefresh = 5 httpallowed = 0.0.0.0-255.255.255.255 aulow = 120 hideclient_to = 45
Mijn versie van Oscam is relatief nieuw: OSCam: 1.20-unstable_svn Build: r10660Ik heb ook even geüpdatet naar build r10665, maar met hetzelfde resultaat, alleen gingen sommige ECM requests hier fout, vandaar weer even terug naar een iets oudere build.Iemand enig idee hoe ik dit verder kan troubleshooten of iemand die iets raars ziet in de config.Alvast bedankt!
Oscam - CD kaart will niet updaten
in CI, CI+, (soft)cams en smartcards
Thanks!!!
Voel me even stom, dat ik hier zelf niet aan gedacht heb.
Had al expres 's nachts wat recordings gestart in de hoop goede EMM(s) te ontvangen, maar dit is natuurlijk de makkelijkste manier om het te testen, drie dagen helemaal verkeerd gefocussed. Overigens nu is de datum 2015/08/02, dus de configuratie werkt
