Usb - mount probleem
hey,
ben bezig om dreamflash v1.5bc te installeren, in de readme staat het volgende:
Starting image from USB-Stick:
First,boot box without the Stick.
Once the original image is started, put in the stick.
Enter following by Telnet:
mkfs.ext3 /dev/scsi/host0/bus0/target0/lun0/disc
mount /dev/scsi/host0/bus0/target0/lun0/disc /var/mnt/usb
The Stick is formatted and linked into the system at Mountpoint
"/var/mnt/usb".
Since some USB-Sticks have to be mounted in "/dev/.../part1", the two
commands have to be changed.
PLi« DM7000 Image 01090400
welcome on your dreambox! - Kernel 2.6.8.1 (23:44:42).
dreambox login: root
Password:
BusyBox v1.00-rc3 (2004.08.28-23:28+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
~ > mkfs.ext3 /dev/scsi/host0/bus0/target0/lun0/disc
mke2fs 1.35 (28-Feb-2004)
Could not stat /dev/scsi/host0/bus0/target0/lun0/disc --- No such file or direct
ory
The device apparently does not exist; did you specify it correctly?
krijg alleen na het invoeren de volgende foutmelding :S
hoe krijg het nu toch nog voorelkaar??
groetjes van Peter <img src="/ubbthreads/images/graemlins/loep.gif" alt="" />
Hoi DJ.
Je zou kunnen proberen het laaste deel in /dev/...../disc te veranderen in /dev/....../ part1
Het mount commando veranderen in :
mount /dev/......../part1 /mnt/usb
Magic
The latest Pli in the box. Vu+ Duo,Dm7000, Triax+ Stab en Wavefrontier T55
