Release 4.0 PRO 01/10/2004
first public release of FW 4.0 PRO
New Features:
- FlashWizard PRO is now a standalone program: you don’t need to install DreamFlash for having images on multiboot. FlashWizard PRO installs multiboot images on /mnt/usb/fwpro/ and /hdd/fwpro/
- ONLY 40K required space on flash image! So, more space free for our emus, plugins and settings... ;-)
- Installs images on Usb Stick and/or Hard Disk, even used together:
the installed images will be automatically recognized at boot time, then loaded from their install devices.
Up to 100 images allowed, both on hdd or usb stick.
- Allow Boot Logo display (the starting picture) also for multiboot images!
To use this feature, you need >= 1.08 image in flash.
- Has his own 256 colors boot menu shown at boot time.
Select an image and press OK to load it: the boot logo (if available) will be displayed.
- Automatically checks and installs his boot menu on flash image (even if you are actually running a multiboot image).
- Activates the VCR SCART output at boot time, allowing display of the boot menu also through the devices connected to it (i. e. a video-sender connected to VCR out)
- FLASH install:
FlashWizard PRO performs a check (verify) of the data written to the flash memory while installing an image (or restoring a flash backup), to make sure the install will come out without errors.
If a data block went bad in writing, FlashWizard PRO automatically rewrite it to flash, until it is stored without errors.
- Widely improved the backup/restore procedure, much more speed up the archiving phase.
Enjoy!
MB
Download bij de maker van deze software: Music.Bob
<img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
  • Reacties 39
Als ik de Boot Menu probeer te installeren krijg ik het volgende foutbericht: 553 Could not create file
Weet iemand waardoor dit komt?
Ik draai de laatste Hydra (Lucius).
Hi Jafu
Ik kreeg deze fout melding ook omdat ik nog dreamflash in de flash image had zitten (WHOOS), deze met ftp verwijderd en toen
met flashwizard 4.0 het boot menu laten installeren .
Geen foutmelding meer en diverse image's geinstalleerd in het multiboot menu via flashwizard 4.0
Cu sparkienl <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Ik heb hem net even uitgetest en hij werkt perfect .
In eerste instantie kreeg ik de melding dat m'n USB-stick vol zat en dat kon wel kloppen met nog steeds die monster image, welke ik er nog een keer op wou zetten.
Maar geen probleem met deze Flashwizard Pro om een kleinere images erbij te zetten.
Ik heb wel een uitgeklede DM image in de flash zitten. heb er zelfs niet eens een settingslijst inzitten om de flash nog meer te sparen.
mooi progje hemertje <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Zoals ze aangeven :
- een prachtig menu
- Ik kom trouwens net tot de ontdekking dat je zowel harddisk als USB door elkaar kunt gebruiken <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
- De logo's die bij de images horen komen bij opstarten netjes op het beeldscherm .
RuKo
Begrijp ik goed dat de MAIN image in flash dan normaal loopt, en de andere images op HDD een hoop HD-spins veroorzaken? Of wordt de gekozen image dan in flash gepompt zodat je geen last krijgt van de HD-spins?
Of praat ik hier nu over toekomstmuziek ? <img src="/ubbthreads/images/graemlins/blush.gif" alt="" />
3x DreamBox 800SE, 78cm Triax, Quad Monoblock
"There are only 10 types of people in the world; Those who understand binary, and those who don't."
Toekomstmuziek ja,
Bij de image die op hd staat spint de harddisk wanneer je gaat zappen, na een paar minuten valt hij wel weer in slaap hoor:)
Ik ben daar dus niet zo kapot van.
Voor mijn gevoel dus beter op USB zetten i.v.m. onnodige slijtage van de harddisk.
gr,
RuKo
Werkt weer lekker.
Van de huidige USB images backups gemaakt.
Dan de dreamflash uit de originele image van dream verwijderd (dreamflash.cfg en dreamflash.so uit de /var/tuxbox/plugins).
Daarna de multiboot van Flashwizard Pro erin.
USB geformateerd
USB backup's weer terug geplaatst en draaien maar.
<img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" /> <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
Groet,
mmeu
RuKo
toch is lezen soms best moeilijk he Ruud <img src="/ubbthreads/images/graemlins/grin.gif" alt="" />
Sat-nerds Moderator
Plinux Member
Hemertje,
Kun je er voor mij nog een iets groter lettertype van maken ?
<img src="/ubbthreads/images/graemlins/loldev.gif" alt="" />
Ruud
Ik heb zojuist de Monster Image op m'n hdd geinstalleerd. Boot Menu en Monster staan erop. Als ik reboot krijg ik geen menu te zien, maar direct het bootlogo van Pli. Monster staat in Flashwizard als 'Boot' gemarkeerd met groene R.
Wat zou ik over het hoofd zien?
Marino.
In eerste instantie werkte het perfect met de originele image in de flash en de laatste Hydra op de HDD. Maar toen ik er nog een bij wilde zetten (SF), blijft FlashWizard hangen bij "install & Init" de balk is doorgelopen tot 100%, maar ik moet dan het programma beëindigen met CTRL/ALT/DEL.
Het lijkt dan in de DB alsof er een Img bijstaat maar deze blijft dan in het boot menu hangen.
Enig idee waardoor dit kan?
DM7020HD, DM500HD, ziggo, sat13/19,2/23,5/28,2
met deze compleet nieuwe opzet van FlashWizard 4.0 is mijn uitleg op Sjerom niet meer actueel!
heeft er iemand interresse om deze uitleg te herzien compleet met aanleveren van de situatieplaatjes?
Sat-nerds Moderator
Plinux Member
Opgelost. Blijkbaar kan Flashwizard niet overweg met het verplaatsen van de var directory. Na het hernoemen van de /hdd/pli werkte het.
Marino.
edit: Helaas kon ik na deze actie de Pli niet meer booten vanuit het Flashwizard menu....
Heb hier ook zoiets, na installatie van de pro4.0
eerst de nieuwe dreamflash erin,daarna de dragon op de
stick, en de Hydra Lucien op hdd.
maar na nieuwe opstart zie ik geen dreamflash pro en ook
geen usb of Hdd staan met dragon of hydra.
Heb de PLI 3009 in de flash staan.
Iemand een idee?
Flash erase gedaan met opstarten.
Bedankt Wermar.
