hemertje Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 MusicBob heeft weer wat moois gemaakt! FlashWizard PRO 5.0 released 09/02/2005 Idea and Programming by MusicBob FlashWizard official Forum: FlashWizard discussion forum ...making dreambox easy... What's new from 4.x? * Support for images installed on NFS mount, you can install and start multiboot images from your Windows PC (or Linux PC)!! A NFS server is required running on the PC side (I strongly suggest Microsoft Services For Unix 3.5 for Win XP PRO and Win 2K). You can install images wherever you want, on USB and/or HDD and/or NFS. * Added compatibility with images for DB 500 and DB 56xx They are automatically recognized and installed, just drag&drop as ever. Now FlashWizard is full compatible with DB 7000, DB 56xx and DB 500 images. These can be installed either in flash and multiboot (on NFS server). * Added Advanced SmartCopy A powerful option that allows to full copy a list of file and/or folders from the active image to the new one being installed. As for SmartSettings, it is full working also with images that have a compressed /var folder at install time. WARNING_1: be careful with this option, use wildcards in filenames only if you actually know what you are doing. WARNING_2: To avoid image malfunction, do not try to copy special dir/files (like /var/etc/init) between images developed by different Teams: every developer use these files to configure their images in a different way each one from the others. If you're not an advanced user, limit the use of Advanced SmartCopy to plugins files and other useful addons ;-) * New FlashWizard bootmenu (v1.4): - automount NFS device at boot; - display which devices are connected (USB-HDD-NFS); - display where is installed the currently selected image (USB-HDD-NFS); * If NFS server is down, FW will automatically boot-up from other available images, or from flash image. * various improvements and fixes. Download op Sjerom... DM8000 + DM800SE + VU+DUO + Wavefrontier T90 + 10LNBs Hemertje.Dreambox Webmaster Sat-nerds Moderator Plinux Member
Gast Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Download verwijst echter naar de zojuist door mij gemelde "FLASHWIZARD_PRO_NFS_BetaMKII". Er is vast een site-update aan de gang <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
Gast Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Je kunt ook met het FLASHWIZARD_PRO_beta5.0_RC1 de updtae binnen halen in configuatie and Utilities --->FlashWizzard update. gr, RuKo
Markve Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Ook met deze versie van flashWizard pro krijg ik het dezelfde problemen. Als ik een image op de hdd van de PC (NFS) wil zetten met flashwizard krijg ik de fout melding bij het installeren "550 failed to open file" weet iemand hoe dit komt. De image is dan al verzonden en moet worden geinstalleerd. Mark
Gast Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Markve , Heb je de voorgaande FlashWizard uit je opstart image verwijderd ? Bij utilities "remove FlashWizard Pro" . Daarna met de FINAL versie "Install a firmware in Multiboot" doen. Sommige files schijnen een andere plaats te hebben gekregen. <img src="/ubbthreads/images/graemlins/smile.gif" alt="" /> gr, RuKo
Markve Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Ja dat heb ik gedaan. Het blijft gewoon allemaal hetzelfde.Ik lees ook ergens dat je de dreambox iedere keer moet resetten. Dat heb ik nog niet gedaan. Dit ga ik zo eens proberen maar ik geloof er niet in. Mark
Tomd Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Vraagje....het heeft geen zin om uit versie 4.5 de file nederlands.locale in 5.0 te zetten toch.?? want deze heeft dus de aanpassingen nog niet in zich, komt er nog wel zo'n file denken jullie..?? DM 7000S, Open PLi®, West Dig 160GB HD,1 USB 160Mb, CD Abo, Maxplus 2100+ TechniSat Multytenne 45cm 28.2E --> 13.0E
Gast Geplaatst: 9 februari 2005 Geplaatst: 9 februari 2005 Je kan dit doen en dan zelf de nieuwigheden(uit het engels) bij zetten en dan vertalen. Of je neemt deze file in de bijlage. Deze is klaar voor de FlashWizzard PRO 5.0. 809430-nederlands.locale.fwpro.txt
Gast Geplaatst: 10 februari 2005 Geplaatst: 10 februari 2005 Voor de mensen die problemen hebben met het installeren van SFU hier een engelstalige HOWTO. How to Install and configure NFS Server for DreamBox & FlashWizard gr, RuKo
Gast Geplaatst: 10 februari 2005 Geplaatst: 10 februari 2005 ik krijg het allemaal niet aan de praat op mijn dreambox 500. ik gebruikte eerst omni nfs server maar daarmee bleef hij hangen nadat hij klaar was met "sending image" dus geen error hij bleef gewoon hangen. toen een andere nfs server gebruikt de nfs server van microsoft die in SFU35SEL_EN.exe zit . die helemaal goed geconfigureerd eerst met de poolse handleiding toen kreeg ik de error 553 could not create file toen hij bij "sending image" aankwam. TOen heb ik de nfs server geconfigureerd met de engelse manual kreeg ik precies hetzelfde dus de 553 could not create file error. ik heb nu Gemini_500_102.img er op staan en ik probeerde voor de multiboot die Gemini_500_102.img er nog een keer op te krijgen alleen dan voor nfs. ik heb ook hydra500_zeus.img geprobeerd maar dat resulteerd in hetzelfde. heeft iemand een idee van wat ik misschien fout doe?
Gast Geplaatst: 10 februari 2005 Geplaatst: 10 februari 2005 Sorry mijn fout, had eerst ff verder moeten kijken dan mn neus lang is <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> tijdens de install moet je de passwrd en group ingeven...en die kun je halen uit je DB of ergens anders? Citaat: Voor de mensen die problemen hebben met het installeren van SFU hier een engelstalige HOWTO. How to Install and configure NFS Server for DreamBox & FlashWizard gr, RuKo
Gast Geplaatst: 10 februari 2005 Geplaatst: 10 februari 2005 Nou het is me allemaal gelukt maar ook ik krijg de melding 553 could not create file. Iemand hier ervaring mee, en het al op kunnen lossen?
Gast Geplaatst: 10 februari 2005 Geplaatst: 10 februari 2005 Citaat: Nou het is me allemaal gelukt maar ook ik krijg de melding 553 could not create file. Iemand hier ervaring mee, en het al op kunnen lossen? ik heb precies hetzelfde <img src="/ubbthreads/images/graemlins/frown.gif" alt="" /> welke nfs server gebruik jij?
Markve Geplaatst: 11 februari 2005 Geplaatst: 11 februari 2005 Ik ben gelukkig niet de enige dus met die fout melding. Ik heb nu windows service for unix draaien. het enigste verschil is dat ik nu de fout 553 krijg in plaats van 550. Schiet lekker op dus. Is er misschien een goeroe die een oplossing weet? Mark
