Download
1. IRD Status
(1) System ID : 406
(2) Loader Version : L4.06
(3) Device Version : v5.2.66
(4) Application Version : TF-NCPC 5.11.55/TF-NPC 5.11.55
(5) Last Update : Mar 24 2005
2. Improvements of this version
(1) The recording problem in Hotbird 11.054H and 11.604H is fixed.
But, the file with empty name from the previous beta version still cannot be deleted.
We will release the temporary firmware only to delete these files within next weekend.
(2) The timer setting with "Record Off" did not function correctly in case of changing the wakeup service.
It is fixed.
(3) Some german string is modified.
(4) There were some problems in the extended EPG of the recording info window which is shown
by pressing "rec" button while recording.
They are partly fixed. A little(?) problem is still left.
(5) The text splitting in the extended EPG window is enhanced at this version.
(6) Some bugs in the TAP were fixed and some TAP functions were added.
We will release new TAP document soon.
TF5000 PVR - 250 GB - FW Mrt. 2008
Schijnt wat problemen te hebben met opnemen.
Vaak geel symbool i.p.v. groen.
Ook Jag EPG werkt niet goed met deze firmware.
Is deze firmware ook voor de kale 5000CI, of is dit een andere versie.
Is de updata ook via sat te downloaden?
