[5620S] db wil niet meer opstarten na Hydra-flash
Hoi,
Zet automatic boot eens op enabled. (toggle 7) Save (S)en daarna herstart.
DM8O0 - WF T90
DM600 - WF T90
DM7025 DVBS/DVBC - WF T90
DM500 - WF T90 en draaibaar op de caravan
jezus waar heb ie dat vandaan.
maar nu staan er 4 streepjes
Configuration has been saved
--- Device Configuration ---
Power-On Test Devices:
000 Disabled System Memory [RAM]
002 Disabled Ethernet [ENET]
Boot Sources:
001 Enabled Application in Flash [FLASH]
local=0.0.0.0 remote=255.255.255.255 hwaddr=0009341ed902
003 Disabled Serial Port 1 [s1]
Baud = 115200
Automatic Boot: Enabled
1 - Toggle Power-On Tests
2 - Change a Boot Device
3 - Change IP Addresses
4 - Ping test
5 - Change Baud Rate for S1 Boo
7 - Toggle Automatic Boot
D - Display Configuration
S - Save Changes
0 - Exit Menu and Boot Application
Dreambox DM5620
loaded at: 00500000 005B31F8
relocated to: 00400000 004B31F8
board data at: 004B0128 004B0168
relocated to: 00404C14 00404C54
zimage at: 00405150 004AF237
avail ram: 004B4000 02000000
Linux/PPC load: console=null root=/dev/mtdblock0 rootfstype=cramfs ro
Uncompressing Linux...done.
Now booting the kernel
Welcome to the enigma serial access.
you may start a HTTP session now if you send a "break ".
HTTP/1.0 200 OK
Connection: close
Content-Type: text/plain
[ENIGMA] ok, beginning mainloop
+ (54) wizard: tv system
creating new font color cache entry ff000000 .. 00ffffff
[DHCPC] info, udhcpc (v0.9.9-pre) started
debug, Sending discover...
creating new font color cache entry 33294a6b .. 00ffffff
creating new font color cache entry 225b7395 .. 00ffffff
[DHCPC] debug, Sending discover...
Volgens mij is de box geboot nu alle instellingen gaan doen. Dus aan de TV hangen en verder.
DM8O0 - WF T90
DM600 - WF T90
kan ik er niet eerst de hydra img opzetten, nu staat er denk ik de rel106.img op.
maar ik heb denk ik geen juiste hydra img.
bedankt geweldig <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Hoi,
Natuurlijk is dat mogelijk, daarna wel even een flash erase uitvoeren.
Dus image erop, reboot, gelijk na reboot bovenste knoppie indrukken en vasthouden tot je een getal ziet, loslaten en klaar. Daarna alles instellen.
Het kan zijn dat je de hyperterminal procedure weer moet herhalen. Dat is dan het enige om de box weer te laten booten. Hydra staat er dan al op. Veel succes !!!! <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
DM8O0 - WF T90
DM600 - WF T90
  • 1 jaar later...
Hoi,
ik heb hier hetzelfde probleem met een 5620s
na iedere reboot moet ik hem met hyperterminal opstarten, is deze box nu defect of .... : <img src="/forums/images/graemlins/confused.gif" alt="" />
Een beetje van mezelf en een beetje van jullie....
