heey,
kan ik een dreambox DM500 flashen vanuit flashwizard pro 5.0??
en evt backup maken en deze weer terug zetten???
groetjes van peter
Dreambox DM800HD PVR, 500GB WD HDD
Dreambox DM600 PVR
TRIAX TDA78, Canal Digitaal DUO LNB
[color:"green"]Dat is wat MusicBob van zijn software zegt:[/color]
FlashWizard PRO History - coded by MusicBob
Release 5.0 PRO 09/02/2005
- Support for images installed on NFS mount, you can install and start multiboot images from your Windows PC (or Linux PC)!!
A NFS server is required running on the PC side (I strongly suggest Microsoft Services For Unix 3.5 for Win XP PRO and Win 2K).
You can install images wherever you want, on USB and/or HDD and/or NFS.
- [color:"red"]Added compatibility with images for DB 500 [/color] and DB 56xx
They are automatically recognized and installed, just drag&drop as ever.
[color:"red"]Now FlashWizard is full compatible [/color] with DB 7000, DB 56xx and [color:"red"]DB 500 images[/color].
These can be installed either in flash and multiboot (on NFS server).
................ etc.
[color:"green"]Dus probeeren.[/color] <img src="/forums/images/graemlins/blush.gif" alt="" />
doet het perfect op allebei de DM500'jes zonder problemen. Jammer dat ie nog niet werkt voor de 7020, om dat ding te flashen is echt irritant
