Jazekere hiep hoi !
Aanwezig op Papagen, te vinden onder Links op onze site van Sammyfilez
Hier de release note:
Samsung DSR9500 EMU v5.3
- Support for nagra2 (1801)
- Nagra1 pk's now stored and autoupdated as key2+3
Samsung DSR9500 EMU v5.2
- Support for Mediapark 30W
No AU, make sure to add opkey for ident 1911
- Support for fixed DW
Using editor, add SID+PMTPID to identify channel
Samsung DSR9500 EMU v5.1
- New TPS AES key
Samsung DSR9500 EMU v5.0
- ck2 nano51 fix
- Sharing tool v1.6a (newcamd v526 support)
Samsung DSR9500 EMU v4.9
- Support for ck nano51, 0064, 0065, 0070
Samsung DSR9500 EMU v4.8
- Support for ck2 0065
- Tps2 fix
- Polsat AU fix
Samsung DSR9500 EMU v4.7
- Support for ck2 0064 table 9x
- Included latest sharing client v1.5 which has support for latest NewCamD
server with DES key encryption.
Samsung DSR9500 EMU v4.6
- Fix for ck2 nano51 Sky Ita
- Improved 0064 ck2 card support
Samsung DSR9500 EMU v4.5
- ECM pid selection banner behaviour is improved. It will not disappear anymore
- Added "NO ECM" selection to ECM pid banner. This means that the internal emu will
not be used on this channel. This is to allow you to use a vxs (or other?) card to decrypt the channel.
Samsung DSR9500 EMU v4.4
- Fix for ck2 SkySport1
- Other minor fix for ck2
Samsung DSR9500 EMU v4.3
- Fix for ck2 Ita, nano 0F/51/tab9x
- Vxs2 support (untested)
- Full nagra emu has been removed. It is not needed anymore
Old nagra emu is used now.
Samsung DSR9500 EMU v4.2
- Support for cnx nano 63
Samsung DSR9500 EMU v4.1
- Fixed freezing on ck2
- ECM support for ck2, 006x (Spa) and 007x (Ita)
No emm support (yet)
So remember to put valid opkeys in keybuffer.
Samsung DSR9500 EMU v3.3
- Added SID and NID to 2x INFO button menu
- Fixed nagra emulater: First release of FULL emu
(But to be honest, I don't think there ever can be a full emu ...)
Explanation for FULL nagra emu:
There is support for Cabo, D+ and Polsat, each using its own eeprom image.
You must upload all 3 images to the following addresses, using JTAG :
0xC07F6000 <- D+ EE
0xC07F8000 <- CABO EE
0xC07FA000 <- POLSAT EE
Remember that the size of the files is 0x2000 and that they are stored
in RAM only (so after power removal the RAM is empty again!)
The included eeprom images are original and old. They will be updated to
the latest revisions (A3E for D+ and Cabo).
You can also read them back again using JTAG
Samsung DSR9500 EMU v3.2
- Fixed bug in nagra emulator
- Added support to use cardshare with dreambox:
Sammy cannot share its own card, but can connect to some server.
Radegast and NewCamD is supported.
You need a pc connected with serial to Sammy, on which you run
the sharing client. Self explanatory.
Samsung DSR9500 EMU v3.1
- Added card support for Cryptoworks (ecm only, not emm)
Samsung DSR9500 EMU v2.1
- Remembers the ecm pid for each channel
- "Hang" bug fixed on FTA/RADIO channels
- Included BK/IRD editor for use with the fw.bin
- Cnx support has been added to the emu (and to editor)
- Some other minor fixes/improvements
Samsung DSR9500 EMU v1
This a firmware for Samsung DSR9500 VIACI boxes, with internal EMU.
It is based on v118 multicas. (And based on Dynamit's emu)
For the EMU to work, you *must* use some cnx (or cwks) card in the box.
This can be official cnx card, or some fun/gold/whatever soft.
(preferably a card without keys or it might interfere with EMU)
The EMU decrypts s*c*, n*gr*, vxs and ird*t*
(cnx support has currently been disabled, and cnx ecms/emms go to card)
The EMU supports AU for n*gr*, vxs, ird*t* (pmk only!)
(s*c* and ird*t* HMK are not supported yet)
Included is an editor (courtesy to Eurocrypt!) which you can use
to read/write keys from/to Sammy.
IMPORTANT FOR FIRST TIME USAGE :
The 1st time you upload this fw to your box, you need to take some special steps!
1) Upload the fw to box (using any tool you like).
2) Powerup box using remote with cnx card inserted, and go to some channel.
3) Now you *MUST* upload valid keybuffer with editor (because it isn't part of fw).
4) Powerdown box again and then keybuffer will be stored in flash.
5) From now on you can use fw as normal ....
Some things you need to know :
*) The EMU will continously do AU.
In case of successfully AU you will NOT be notified in any way.
When the next ecm arrives (which could take some secs) then the image will appear.
*) Only when you powerdown box using remote, then the keys will be stored in flash.
If you powerdown some other way (like switch on back), all newly received keys are lost.
*) Some channels have multiple ecm pids (like TPS).
Sammy will use 1st ecm pid as default.
You can hit EXIT key to show a banner with pmt info (CAID, ECM_PID, IDENT)
You can use PG+ and PG- keys to walk through PMT, and use OK button to select new PID.
This setting will be remembered in ram. Only if you completely remove power (like
switch on back) you will loose this data.
*) Only ENGLISH menu language is supported!
(other languages are overwritten with needed patches)
Enjoy,
H2Deetoo
PS. Thanks to everybody who helped. You know who you are!
PS2. The fw is not perfect, use it as is ...
Altijd vooruitkijken . . .
Nu graag versie 5.4 !!
met Talpa-support via MTV !
Zou mooi zijn maar dit was al kantje boord na die posting van H2Deetoo.
Ik hoop dat hij mocht hij er mee stoppen de source code doorgeeft aan iemand die er mee verder wil.
Rik
Hij kan zich bij mij melden <img src="/forums/images/graemlins/cool.gif" alt="" />
