[Strong] Fout in firmware satracker 2.0 nl
Elke keer als ik m`n deco flasch dan springt het angstzeet me om mijn oren omdat loader 8000 plots stopt en een foutmelding geeft....Gelukkig gaat de procedure nog na een poosje gewoon door en staat alles er netjes in. <img src="/forums/images/graemlins/smirk.gif" alt="" /> Alleen heb ik geen idee waarom deze foutmelding, want dit is niet goed voor mijn gezondheid <img src="/forums/images/graemlins/loldev.gif" alt="" />
Tekst:
boot_LIBDAT_ECP_1.6.a(DA3NED_VEN_V20.3)
CHARGEMENT PRIORITAIRE
FLASH ADR=bfc00000 M29W800B
FLASH ADR=a1200000 M29W800B
FLASH ADR=a1300000 (90,90) non reconnue
debut de transfert parallele
attente negociation: compatible
rince E2PROM
rince zone BACKUP page_bfc90000
rince zone BACKUP page_bfca0000
rince zone BACKUP page_bfcb0000
rince zone BACKUP page_bfcc0000
rince zone BACKUP page_bfcd0000
rince zone BACKUP page_bfce0000
rince zone BACKUP page_bfcf0000
transfert flash_a1200000
transfert flash_a1210000
transfert flash_a1220000
transfert flash_a1230000
transfert flash_a1240000
transfert flash_a1250000
transfert flash_a1260000
transfert flash_a1270000
transfert flash_a1280000
transfert flash_a1290000
transfert flash_a12a0000
transfert flash_a12b0000
transfert flash_a12c0000
transfert flash_a12d0000
transfert flash_a12e0000
transfert flash_a12f0000
transfert boot protege
transfert flash_bfc10000
transfert flash_bfc20000
transfert flash_bfc30000
transfert flash_bfc40000
transfert flash_bfc50000
transfert flash_bfc60000
transfert flash_bfc70000
transfert flash_bfc80000
transfert flash_bfc90000
transfert flash_bfca0000
transfert flash_bfcb0000
transfert flash_bfcc0000
transfert flash_bfcd0000
transfert flash_bfce0000
transfert flash_bfcf0000
transfert flash_a1300000
impossible determiner boitier
!!!!! ERREUR program flash
flush(100080)
fin de transfert parallele
checksum_flash=0x2721a3a3
checksum_e2prom=0x000036da
!!!!! COUPEZ PUIS REMETTEZ
!!!!! L'ALIMENTATION DU DECODEUR
Zo te zien zetje de firmware voor a1300000 geheugen gebied erin
Als je het geheugen van je strong niet hebt uitgebreid moet je de 2flasch nemen ipv de a1300000 versie.
groetjes martje
Bedankt voor de uitleg!!
Ik was toch zeker van mening dat ik de 2 flasch erin geschoten had (vertaalde sattracker 2.0) maar twijfel nu.. <img src="/forums/images/graemlins/kweetniet.gif" alt="" />. Aan de andere kant kan ik deze er gewoon inzetten, want alles werkt perfect.
Even haperen met FW laden maar loopt gewoon goed door dan met de 3 flasch FW.
Trouwens van dat zweten valt wel mee hooor ... <img src="/forums/images/graemlins/anoniem.gif" alt="" />
Ik heb hem al meer dan 100 keren geflasched <img src="/forums/images/graemlins/biggthumpup.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
Jij hebt bij het leeglezen dat hij meldt over A13000, ofwel de patch is blijven zitten die dat geheugenblok heeft geinitieerd. In computer land is het toch zo, HW aanpassing dan eerst DRIVERS installeren, dan doet hij het pas. En als je dan de HW weghaalt, of de foute Firmware erop zet, dan staat het systeem in het luchtledige te 'pollen'. En dat is denk ik ook bij jou het geval.
kan geen kwaad hoor
