Self-auto-installing addon for NBC CVSplus images.
You find on attached zip files an emu addon (no k*ys inside!) that can be installed into CVSplus image (compatible starting from last NBC CVSplus 02.10 image):
ee_camd3.808 (with cardserver, MULTI enabled)
NOTE: will work only on latest NBC CVSplus:
The NBC CVSplus from today has the MULTI-PATCH by Doz21 already compiled in enigma
You must enable "handle two services" on Common Interface setup window (Dream/Menu -> 6 -> 4).
Then you can record a channel (encrypted too) and watch another channel (encrypted too!) at the same time, on the same transponder of course.
Thanks to Doz21 for this release.
DOWNLOAD NBC CVS PLUS 07/10
This procedure installs automatically the addon on the image (even in flash or multiboot is ok), plus an emu manager, called "NBC EasyEmu", which you will find into enigma Plugins window (blue key) after the install.
To select/change emus, just do it thru the EasyEmu plugin.
You can install just one emu or both, and then remove one or both: you will find always automatically updated the available list on EasyEmu plugin.
How to install into NBC CVSplus image:
It never been as easy...!
1) FTP the extracted file to dreambox /tmp directory
2) from Telnet:
cd /tmp
chmod 755 ee*
3) To install:
./ee* install
4) To remove installed addon:
./ee* remove
5) that's all
Enjoy!
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
