Ik heb VLC Streaming wel draaiende maar ik heb geen geluid, kan iemand mij daar iets over vertellen? dit is mijn vcl.xml instelling.
<vlc>
<server ip="192.168.2.101" webif-port="8080" stream-port="9090" user="admin" pass="admin" />
<config startdir="d:/movies" cddrive="e:" />
<codec mpeg1="mpgv" mpeg2="mp2v" audio="mpga" />
<setup name="SVCD-Mode" ext="none" Videorate="1000" Videotranscode="0" Videocodec="mpeg2" Videosize="352x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="VCD-Mode" ext="none" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="352x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="DVD-Mode" ext="none" Videorate="1000" Videotranscode="0" Videocodec="mpeg2" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="1" />
<setup name="File-Mode" ext="MPG" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="MPEG" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="M2P" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="MPV" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="DAT" Videorate="1000" Videotranscode="0" Videocodec="mpeg1" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="AVI" Videorate="2048" Videotranscode="1" Videocodec="mpeg2" Videosize="480x576" Audiorate="192" Audiotranscode="1" ac3="0" />
<setup name="File-Mode" ext="TS" Videorate="1000" Videotranscode="0" Videocodec="mpeg2" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
<setup name="File-Mode" ext="VOB" Videorate="1000" Videotranscode="0" Videocodec="mpeg2" Videosize="704x576" Audiorate="192" Audiotranscode="0" ac3="0" />
</vlc>
Het gaat mij om DVD ik heb wel beeld van de dvd op mijn Dreambox.
  • 3 weken later...
Nou, weer een avondje geprobeerd, nu ziet de box wel alle bestanden in de "movie" map maar DivX en AVI wil hij niet weergeven met VLC.
Ik ben nu zo'n beetje uitgeprobeerd.....
HUmax 5100CI, Nokia Mediamaster 9500, Dreambox 7020-S. Disecq 1.2 1,50 meter, 60cm met rotor draaibaar.
  • 2 maanden later...
Met Gemeni 2.8 , dreambox 7000s, VCL frontend en VLC 0.8.4a volgend fenomeen:
VLC op de PC draait mét de webinterface.
Config file op dreambox is ingesteld op IP van PC, en het Path naar de files.
VLC Frontend plugin op Dreambox start en ziet alle files staan.
Als ik een file kies, start ook VLC op de PC te spelen (zonder beeld) en op de dreambox komt de melding : "Going to Streaming Mode ... " <img src="/forums/images/graemlins/mad.gif" alt="" />
Dan duurt het ongeveer 10 seconden waarna de dreambox meldt :
"An error occured while trying to send commands, or receiving the stream. Please ensure that..."
Wat kan hier aan de hand zijn? Zijn de poorten correct? Waar stel ik die in bij VLC versie 0.8.4a (of 0.8.5)
oja, nog dit: Tijdens die 10 seconden gaat de %CPU niet naar omhoog. Het transcoderen werkt dus ook niet, aangezien hier te lezen is dat het nogal wat cpu-power nodig heeft.
alvast bedankt <img src="/forums/images/graemlins/smirk.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
probeer eens versie 0.81 en vul bij interface "http" in.
start vlc op de comp en probeer te starten op db.
Werkt voor mij.
Groeten,
LLGaby
1 DM7000, 1 DM600, 1 DM500, DM500HD, VU+ Duo
Visiosat G4, A1, A2, A3 en HB
Begeren is meer dan het hebben.
waar haal ik die vlc plugin vandaan voor de dreambox 7000 kan dit ding nergens vinden. Ik draai pli en daar zie ik in de webinterface ook al een streaming optie staan alleen werkt deze waarschijnlijk niet kant en klaar..
