Relook 400 met wavefrontier switch 8/1 probleem
Hallo allemaal
Heb net een relook gekocht met een wavefrontier 90 schotel
Nu heb ik 5 0,3 db lnb's laten monteren met een vantage VT-DS8/1 switch
Nu vertikt de relook alle zenders en satelieten te pakken
Hoe moet ik de DiSEqC settings instellen of lukt dat niet ???
Heb al vanalles geprobeerd krijg soms op verschillende codes dezelfde zenders binnen.
Om deze satelieten gaat het
Eutelsat 16.0
Hotbird 13.0
Astra 19.2
Astra 3A 23.5
Astra 2A 28.2
Nu heb ik dus 5 lnb's ga er dus vanuit dat de astra 19.2 in het midden zit deze zit op de switch op inp 5
zie hier de tekst van de switch beschrijving
1. Connection of cables
The switch includes 8 input connectors and 1 output connector. Coaxial cables from particular LNBs (satellite
converters) shall be connected to input connectors (INP1 to INP8). It is advisable to note down assignment of the inputs. The
output connector (OUT) shall be interconnected through a coaxial cable with a satellite receiver.
For a long-lasting operation of the switch it is advisable to use high-quality coaxial cables designed for frequencies up to approx. 2
GHz.
2. Receiver setting
The receiver setting method differs depending on the control mode of the switch , and on the DiSEqC protocol version
supported by your receiver.
A/ Setting according to DiSEqC 1.1 protocol
If your receiver supports DiSEqC 1.1 protocol, set correct data in the fields for “committed switch” and “uncommitted switch” for
each of the connected LNBs in the configuration menu . Set values A to D (i.e. 1 to 4) for “committed switch” and values A or B (i.e.
1 or 2) for “uncommitted switch”.
The values for particular inputs are stated in the following table:
INP1committed A (1) uncommitted A (1)
INP2committed B (2) uncommitted A (1)
INP3committed C (3) uncommitted A (1)
INP4committed D (4) uncommitted A (1)
INP5committed A (1) uncommitted B (2)
INP6committed B (2) uncommitted B (2)
INP7committed C (3) uncommitted B (2)
INP8committed D (4) uncommitted B (2)
B/ Setting according to DiSEqC 1.2 protocol
If your receiver does not support DiSEqC 1.1 version, but supports DiSEqC 1.2, receiver setting shall be carried out as if you had
a DiSEqC motor. One of the satellites to be received shall be selected along with continuous holding of the push-button for motor
rotation depressed (East or West) until the signal of respective satellite appears in a sufficient intensity and quality. Then stop the
rotation immediately and save the found position. Repeat the search for all connected LNBs.
C/ Setting according to DiSEqC 1.0 protocol
If your receiver only supports the basic version of DiSEqC standard, i.e. 1.0, then it is only possible to select the first four inputs of
the switch (INP1 to INP4). In this case the receiver shall be set in the same way as for a common four-input DiSEqC relay, i.e. one
of positions A, B, C, D, (1 to 4) shall be defined for each connected converter.
Note: The configuration procedures for particular receivers can differ. The instructions included in the operating manual of your
receiver shall be followed.
Dus imp5 is AB als ik die in de reciever zet dat krijg ik geen signaal...
Maar ga ik nu op de astra zoeken krijg ik keurig alle zenders van de astra en de goeie ook nog rara hoe kan dat ??
Wie kan mij hier bij helpen ??
Heb ook zo'n switch en het lukt ook hier niet, 1.1 schijnt nog niet goed te werken.
Zelf heb ik een 4/1 switch gekocht en werkte direct goed.
Grt.
Sako
hmmm met een 4/1 gaat dus niet met 5 lnb's dan zou ik dus al 1 extra switch 4/1 en dan heb ik nog een tussen kasje nodig om van 2 switchen naar 1 te gaan word lekker duur zo <img src="/forums/images/graemlins/biggthumpdown.gif" alt="" />
Probeer het eens op deze manier ik heb er 14 LNB's op zitten en werkt perfect.
Lnb.1 DiSeqC.1.0 A---Uncommend.DiseqC.1.1 A
Lnb.2 DiSeqC.1.0 B---Uncommend.DiseqC.1.1 A
Lnb.3 1.0 C--- 1.1 A
Lnb.4 1.0 D--- 1.1 A
Lnb.5 1.0 A 1.1 B
Zo moet het lukken mits je de goede volgorde met de lnb's hebt.
M.V.G.TerranoIII
Lnb.5 1.0 A 1.1 B
M.V.G.TerranoIII
dankje wel voor de info TerranoIII
Deze settings heb ik ook gebruikt...
Heb jij dan ook geen signaal bij sommige satelieten als je die gaat toevoegen in de lnb settings ??
Want als jij dat niet hebt denk ik dus dat de switch niet geschikt is voor deze ontvanger
Wat voor merk switch heb jij dan ??
Ik gebruik 4in1 Switches van het merk titanium maar van interstar zijn ook goed.De uncommend switch is van het merk spaun en de sur420F.
Een tip:als je een satelliet of lnb hebt toegewezen zap dan even naar een
andere satelliet of start hem opnieuw op.De spaun moet ook tijd krijgen om te schakelen.
M.V.G.TerranoIII
