Humax ToH3.3 HoTplugged v6.7 - 2006-02-03
-- Version: A --
- TV CABO now works on Nagra2
Because violation of our agreement HoT will not publish public releases
anymore. Only registered users are able to unzip future releases
(private password).
HoT
Humax ToH3.3 HoTplugged v6.6 - 2006-01-24
-- Version: A --
- D+ Fix
Humax ToH3.3 HoTplugged v6.5 - 2006-01-09
-- Version: B/C --
- PMCT adjusted
- bugfixes
Humax ToH3.3 HoTplugged v6.5 - 2006-01-04
-- Version: A --
- D+ Fix
No PMCT-Update necessary for normal use !!!
It is recommended that you don't modify that readme or firmware to publish
that work in your own name. So if you don't get along with this little agreement,
HoT will stop the public accessibility of new releases in the future.
So:
DON'T MODIFY FIRMWARE OR MODULES!!! LAST CALL !!!
HoT
Humax ToH3.3 HoTplugged v6.4 - 2005-12-24
-- Version: A --
- SSSP-Mode (gbox)
Humax ToH3.3 HoTplugged v6.1 - 2005-11-27
-- Version: A --
Humax ToH3.3 HoTplugged v6.2 - 2005-12-04
-- Version: A --
- Nagra AU disabled
- MTV-CW's
-- Version: A --
- Card Blocker included
Use Option ECM/EMM for Dummy-Cards (recommended)
- Portal Fix
- some Bug-Fixes
Humax ToH3.3 HoTplugged v6.0 - 2005-11-20
-- Version: A --
- AES-Fix (Key 3 and 0x13)
- constant CW can be stored by 2 entries via PMCT like
IDENT VPID CAS nnnn nnnn nnnn nnnn 0000 (=CW even)
IDENT VPID CAS nnnn nnnn nnnn nnnn 0000 (=CW Odd)
(untested)
Humax ToH3.3 HoTplugged v5.9 - 2005-10-23
-- Version: A --
- Cabo-AU Fix (Key0+1 OK - Key2+3 NOK)
- BISS included (Discovery dosn't work - don't know why)
use PMCT to modify CWs
IDENT VPID 2600 nnnn nnnn nnnn nnnn 0000
- EPG/PMCT-Menu use white Button to insert line instantly
- included CAToneV23-Parser
- AES-Key now on Key 3 and 0x13
thx to scriptors and GioppyGio
Humax HoTplugged v5.8 - 03.09.2005
-- Version: D+ is back :-) --
- D+ MTV ESP Astra Fix
- DISH Network 61.5°W (ID 0101 - not tested)
Humax ToH3.3 HoTplugged v5.7 - 27.08.2005
- D+ Fix (maybe not for long time)
special thanks to:
humax hdl-Team for the code
st20tp2 for support & some pseudo C porting
siko-SK for firmwares rom & ramdump
remote, Nightshad & all people that help humax to extract algo...
Humax ToH3.3 HoTplugged v5.6 - 20.08.2008
-- Version: Benedikt XVI --
( 20.08.2008 PMCT Bug-Fix because MCM)
- MTV/VH1 on Astra Hack
(006A without Nano 5105)
Humax ToH3.3 HoTplugged v5.5 B
- Mediapark Fix
- PW Portal Fix (by Padawan)
- Nagra optimization
- Spice Fix
Humax ToH3.3 HoTplugged v5.4
not released
Humax ToH3.3 HoTplugged v5.3
- Cabo Fix
- Irdeto Card-Fix
Humax ToH3.3 HoTplugged v5.2
- ORF fix when PW-Card is used
- PK0 AU (Nagra) on Key2+3 (wait some minutes)
- tps crypt optimized
- version 2.1 of CATONE Conditional Access Tool included (thx to that team)
thx also to Humax & D-Mon
HoT
CATone V2.1
- Key Edit select CA system by rcu colors;
- in case current channel is decripted by emu the editor should start showing actual provider
and key in use marked in red (in Irdeto,Beta it only shows 1st Iredto provider);
- Provider name for known providers is shown;
- Fully implemented CAT and PMT parser. 3 views available : compact, full, hex data;
- views and preferences are now stored:
-> possible to use different color schemes for
a-start menu, about and help
b-key editor
c-parser
d-ecm-dw
-> preferred parser view is stored for both CAT and PMT (may be different)
-> at each calling CATone starts recalling last stored views.
-> CATone preferences (and other things <img src="/forums/images/graemlins/smile.gif" alt="" /> ) are resetted when reloading complete setting list.
CATone is free. Nothing may be modified. Neither FW nor Strings.
This readme should accompany any CATone distribution.
Enjoy.
SuD
Dit is wat Crazysat er voorlopg over te zeggen heeft:
Hi,
as I already told at my board:
I think it is more as a sort of April Fool's day joke rather a real ToH/HoT firmware instead
But since all is possible, I will make deeper research about this new file and report here if anything new is found.
(Baby snake van het hot team zou gepost hebben dat het Geen fake is.)Maar diverse mods denken dat het een fake is.Maar afwachten <img src="/forums/images/graemlins/confused.gif" alt="" />Groeten
7-2-2006 17:24:12 ----
welcome to HDF parser v2.3
init.......
opening file: ToH3_3_HoT6_4.hdf
file CRC: 57979EC4
file MD5: cae29b8f4bd8da8c56fe5ec0e97b4b9c
Deze Hot 6.4 werkt heb hem weer verwijderd wand er zaten k*s in.groeten
Vreemd, ik lees zojuist op het forum waar Crazysat administrator is het volgende citaat van Crazysat:
Not original by PH and ToH/HoT
Het blijft dus allemaal even vaag smirk
Hiermee draait video on demand weer als vanouds.
alleen arabisch menu is even vogelen om dit weer in het engels te krijgen maar het werkt
Bijlage te groot om te posten
staat ongeveer hier :h**p://www.s*tscreenteam.com/forum/showthread.php?p=6150#post6150
Groetjes Edwardje <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
Op deze versie draait alles weer, inclusief video on demand(daar draait nu Crash op ) van Cabo.
ToH3_3_HoT6_4.zip
all fix tv cabo nagra2 ok 100%... anonim 184 1019KB 2006-02-07 12:34:11
file CRC: 57979EC4
Je kunt ook de >>Cabo nagra2 fix gebruiken kan erzo over heen gezet worden 127kb.<<zie bijlage
Staat ook op de site van jos01 6.4 Cabo Nagra2 <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
1083991-HoTTvcabo_n2fix.zip
Maar ja wie krijgt hem open ?
Kan wel even duren: Mijn PC doet zo'n 24 psw/s.
Alle mogelijkheden van 3 Chars duurt 10 uur!
Azbox Elite, SAB explorer PVR SC
Er is wel een toh 6.7 Van een zekere ahmad 2002 (niet org)met een hdf file van 2.195kb (erg groot)die werkt. Wat eigenlijk ook een 6,4 blijkt te zijn maar met Russiche menus, Verder zijn er veel fakes!! ps:Gelezen (" Hnaga " >>don't worry , when you lose more chanels you'll find the fix << <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />)Eindelijk eens een ++ bericht. Bijlage: xamuh pmc hot6.4a 7/2/06. Groeten
