Hieronder de changelog, firm is te downloaden op de site van DGS
relook400s software release
released version : 1.23
released date : Wed Feb 8 19:02:34 KST 2006
released by : parkhw00
Version
- boot loader
U-Boot 1.1.1 (Feb 8 2006 - 18:55:42)
- application
1.23
- database
1.11
usb_uboot.img
To update bootloader. Download this file first.
usb_db.img
To update the database only via USB cable.
usb_kernel_root.img
To update the applications only via USB cable(db will remain as it is).
Changes
1.23 official version
- When recording is set from EPG menu, wrong message appears on top
of TV, right before the recording is amost up.: Fixed.
- TDT is added and selectable in local time menu: Added.
- When you proceed network upgrade,if the info file contains space
or is DOS format, network upgrade didn't work properly.: Fixed.
- When software panic occured, LED flashes faster.: Added.
- When hdd format is chosen by the users, it gets formatted without
going through rebooting the receiver. Right before the hdd forma-
tting without requestioning the users,HDD starts formatting.: Fixed.
- When hdd export is done in main menu, the STB rarelly froze: Fixed.
- The stream format is set to 4:3 or 16:9, TV output settings shows
and works unproperly.: Fixed.
- Without finishing LNB settings, uslas/diseqc1.2 setting can be don-
e.: Added.
- When power is turned off, panic rarely appears: Fixed.
- If it is reserved recording from EPG menu, recording starts one
minutes before the program starts.: Fixed.
- In PIG mode,when channel are shifted from one to another which ha-
ppen to be different screen ratio from the other, PIG mode goes
off itself.: Fixed.
- In network upgrade menu, plugins, radio background and program pa-
ckage can be downloaded and installed.: Added.
- Spanish, Swedish and Portugues are added to muiltilanguage menu.:
Added.
- In some channels' alter audio mode, left mono, right mono were not
activated to be selectable: Fixed.
- TV out put was set to 4:3LB,TV screen's letf and right end was cu-
tted.: Fixed.
- Enables the end users to change the radio background as they wis-
h.: Added.
- Bug resulting an after image when the pulldown list is closed: Fixed.
- Automatic channel switching when the reserved time is up.: Function
Added.
- Left and right key moves page up/down direction on the pulldown lis-
t.: Added.
- TP data for North America: Updated.
- Bev EPG.: Improved.
CDS: Wij bieden goede beeldkwaliteit, dat u geen goed beeld heeft ligt niet aan onze bandbreedte.
  • Reacties 32
Das mooi, het begon angstig stil te worden in ontwikkelland
Maaruh... ik zie niks over het niet synchroon lopen bij opname op zowel sbs als nl2. Dat is eigenlijk mijn grootste ergernis.
Nu maar hopen dat Ronaldd ook weer iets moois uitbrengt. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
NIET IN DE BOX PLAASTEN, onstabiel.
Werd verweiderd van de download.
DGS heeft veel werk verricht maar volgens mij niet genoeg getest en de betatesters ook niet ingelicht, dus wachten op verbeteringen.
De rudbox versie 1.24 blijkt er nu ook al te zijn.
Dit heb ik gevonden:
* cvs 2006/02/14 DB 1.11
2in1:
usb with boot or
usb no boot
PAL: for European members
NTSC: for North American members
Changes:
* some bug fixed
* UPC EPG fixed
* password-protected telnet,ftp
* ssh/sftp server
* root password: relook
* /var/etc/init script for starting custom things
* /var/scripts/menuX.sh scripts, called as menu -> numeric buttons 0-9 excluding '7'
* as default use allready in image : 1 mgcamd, 2 evocamd, 4 _newcs restart_, 0 restart current camd
* lzma squashfs
* thx Jirka for publishing squash patches for kernel
pribo. <img src="/forums/images/graemlins/laugh.gif" alt="" />
Met vriendelijke groet, Leo.
****De rudbox versie 1.24 blijkt er nu ook al te zijn.
Zit erin en werk correct. Geen panic of andere foutmeldingen.
Import gedaan van de kanalen uit db1.10 .Dat ging goed alleen de kanalen staan niet meer in de juiste volgorde. ( wie weet er een goede db converter 1.10 > 1.11)
Moet zeggen dat hij wel weer een stukje sneller zapt.
Opnemen zonder problemen , geen blokvorming oid.
Tot nu toe loopt 1.24 met db 1.11 goed
Omvorming van 1.10 naar 1.11 zou gebeuren bij het flashen via usb en PC Editor (volgens melding op onze www)
Het omtoveren kan zeker via Sqlite browser maaer dan moet je weten wat er juiste veranderd is en dat staat nergens beschreven.
Flashen van favorieten via ftp lukt met PcEditor 1.2.28 indien je eerst je database bewaard, PcEditor afsluit en dan terug opstart alvorens door te sturen.
zenderlijst lukt niet met de nieuwe rudream heb de nieuwste editor van john doe
Krijg de zenderlijst er niet in telkens geeft die eror saving.
kan jij mij uitleggen wat ik fout doe
gr ppaap
Rudream erin is geen probleem...Settings is een groter probleem!!
Laatste Denktenk settings voor 1.11 opend de Editor niet eens..error bla bla en word afgesloten.
Advies?
Info
Ik was dus na img_noboot al mijn kanalen kwijt. En moest dus eerst de 1.11db uitlezen en daarna een import .csv doen. Alleen de kanalen volgorde was niet juist.
In het kort..
Maakt een export van de kanalen inl fav. vanuit 1.10 naar een *.cvs file
Connect de 400S na de configuratie job ( lnb ect ) en download de databas 1.11
Importeer de cvs file en sla de boel op
Upload de 1.11 db naar de 400s ( kijk evnt in /tmp )
Reboot
Hoe plaats jij de db dan ?
Ps. Pcedit plaats na upload de database in /temp/db.dat.edited
(dit voor de mensen die twijfelen aan hun ftp upload )
Ron
Advies?
Info
Mag er vanuit gaan dat je de juiste versie hebt van de editor .1.28 ?
Beton, je legt het goed uit, dit is een oplossing maar in dit geval spreken wij niet over CVS maar wel over Comma Separated Value, een gekende export voor bvb excel. <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/blush.gif" alt="" /> ( en reeds ook weer aangepast )
