[7025] hoe TVV aan de praat krijgen met newcs/evocamd ?
Ik heb reeds gezocht hoe ik een tvv of canal plus kaart aan het werken krijgen op de DM7025
echter is da nog nie gelukt, kan iemand me wat debug info geven.
Ik gebruik evocam/newcs (moet ik nog iets configen?) voorts de onderste card reader met chip down.
manueel starten newcs:
Code:
Reading Config file from /var/tuxbox/config/newcs.xmlTCP-log password is disabled!level: normaltype: initoutput: console,udp,tcplogger config: level 1 type 3 output 7udp log: host 192.168.0.100 port 1000tcp port: 3001[ 17:53:58 ] [ Box detect ] Box type 6[ 17:53:58 ] [ Config ] Option <mhz> for device 0 (lower) not present, defaulting to 357[ 17:53:58 ] [ Config ] Option <sid> for device 0 (lower) not present, no static sids added to filter[ 17:53:58 ] [ Config ] /dev/sci0 ECM priority: round[ 17:53:58 ] [ Config ] Option <mhz> for device 1 (upper) not present, defaulting to 357[ 17:53:58 ] [ Config ] Option <sid> for device 1 (upper) not present, no static sids added to filter[ 17:53:58 ] [ Config ] /dev/sci1 ECM priority: round[ 17:53:58 ] [ Config ] Option <hostname> or <port> not present for User: dummy, DISABLING reverse login[ 17:53:58 ] [ Config ] Option <spider> not present for User: dummy, defaulting to NO[ 17:53:58 ] [ Config ] Option <sidoverride> not present for User: dummy, defaulting to OFF[ 17:53:58 ] [ Config ] Option <readers> not present for User: dummy, NO reader control enabled[ 17:53:58 ] [ EMM Cache ] Initialising Cache with 10 entries[ 17:53:58 ] [ ECM Cache ] Initialising Cache with 10 entries[ NewCS ] Process ID is: 1937[ 17:53:58 ] [ Loader ] Reader type 5 on node /dev/sci0[ 17:53:58 ] [ Sci ] Opening device /dev/sci0[ 17:53:58 ] [ Sci ] CARD_DETECT for sci returned 1[ 17:53:58 ] [ Loader ] Init Seca card[ 17:53:58 ] [ Keyman ] Adding key A07251F type 0 on Provider 0 for caid 0100 ID=0[ 17:53:58 ] [ Keyman ] Adding key 0 type 1 on Provider 0 for caid 0100 ID=0[ 17:53:58 ] [ Keyman ] Adding key 0 type 1 on Provider 6C for caid 0100 ID=3[ 17:53:59 ] [ Keyman ] Adding key 0 type 1 on Provider 6D for caid 0100 ID=4[ 17:53:59 ] [ Loader ] Card 0100 on port  /dev/sci0 ready[ 17:53:59 ] [ Loader ] Starting Newcamd Server on port 34000[ 17:53:59 ] [ Loader ] Reader type 5 on node /dev/sci1[ 17:53:59 ] [ Sci ] Opening device /dev/sci1[ 17:53:59 ] [ Sci ] CARD_DETECT for sci returned 0[ 17:53:59 ] [ Sci ] No card present in reader[ 17:53:59 ] [ Loader ] Reset failed ...[ 17:53:59 ] [ Loader ] Starting Newcamd Server on port 34001[ 17:53:59 ] [ NewCS ] Ready to GO!
Dit ziet er dus goed uit, maar toch krijg ik geen beeld
