copy /hdd/music/*.* van dreambox1 naar HDD van dreambox2; hoe in telnet
op beide dreamboxen samba installeren en de volgende dingen doen:
; /var/etc/smb.conf dreambox_1
[global]
load printers = no
guest account = root
log file = /tmp/smb.log
security = share
server string = Dreambox 1
workgroup = DREAM
netbios name = DreamBOX_1
os level = 0
preferred master = no
local master = no
domain master = no
; ipadres dreambox_1
interfaces = 192.168.1.250
; lan iprange
hosts allow = 192.168.1.
name resolve order = lmhosts host bcast
character set = iso8859-1
client code page = 850
[movies]
comment = HDD movies
path = /hdd/movies
read only = no
public = yes
guest ok = yes
; /var/etc/smb.conf dreambox_2
[global]
load printers = no
security = share
server string = Dreambox 2
workgroup = DREAM
netbios name = DreamBOX_2
os level = 0
local master = no
domain master = no
; ipadres dreambox_2
interfaces = 192.168.1.251
; lan iprange
[movies]
path = /hdd/movies
read only = no
public = yes
guest ok = yes
telnet commando's op dreambox_1:
# volgende 2 commandos uitvoeren vóór smbmount commando op dreambox_2
nmbd -D
smbd -D
mkdir /hdd/dreambox_2_movies
chmod 777 /hdd/dreambox_2_movies
echo "192.168.1.251 dreambox_2" >> /var/etc/hosts
smbmount //DreamBOX_2/movies /hdd/dreambox_2_movies
telnet commando's op dreambox_2:
# volgende 2 commandos uitvoeren vóór smbmount commando op dreambox_1
nmbd -D
smbd -D
mkdir /hdd/dreambox_1_movies
chmod 777 /hdd/dreambox_1_movies
echo "192.168.1.250 dreambox_1" >> /var/etc/hosts
smbmount //DreamBOX_1/movies /hdd/dreambox_1_movies
In deze configuratie heb je de movie-directories op /hdd geshared, de mp3-directories gaan op dezelfde manier, regeltje path = /hdd/movies 'movies'-->'music' aanpassen.
Als je nu met de tuxbox commander op dreambox_1 naar map /hdd/dreambox_2_movies gaat zie je de movies op dreambox_2 en andersom. 5=copy doen en klaar...
Bij problemen, check /tmp/smb.log
succes!
dagg.
.: AZBox Me OpenRSI-2.1 | DM 8000HD DM 500HD DMM-GP3 | Emitor Satlook Micro+ G2 | TBS 5925 | TechniSat USB 2 HD CI :.
.: Triax TDS110, Stab HH120/MS220 | Visiosat BiSat G3D A123 HB :.
[edit]
# volgende 3 commandos uitvoeren vóór smbmount commando op dreambox_2
nmbd -D
smbd -D
# volgende 3 commandos uitvoeren vóór smbmount commando op dreambox_1
nmbd -D
smbd -D
[/edit]
Heb net wat anders bedacht. De hdd via een IDE2usb connector op de usb.
Vervolgens in een menu de copy opdracht.
Had alleen music teveel. Hoe nu stoppen? Kill all ofzo;
antw. ps -ef
kill 414
krijg nu /mnt/music/music.
Zo hoort íe denk ik..
<execute name="back-up HDD music to HDD/music on USB"
target="echo copy to: IDE->USB drive? ;echo; cd /hdd/music; cp -arf /hdd/music * /mnt/usb"
confirmation="copy music to IDE->USB drive?" />
Gtz. Martje B
De optie in het PLi menu werkt op zich wel, maar gaf uiteindelijk ook geen goed resultaat. Ik had juist via het menu de copy to IDE-usb opdracht gestart; hierdoor krijg je een soort stand-alone situatie.
Het copieren ging echter erg langzaam en na ca. 10 uren, is de opdracht vanzelf gestopt terwijl hoogstens een tiende gekopieerd was. <img src="/forums/images/graemlins/frown.gif" alt="" />
Ik heb nu via flash-fxp van dream1 naar pc gekopieerd. Dit is zojuist gereed, na ca. 10 uur (130Gig)
Nu is íe bezig van pc naar dream2.
Jammer dat nu alle bestanden en directories een nieuwe datum krijgen.....
Gtz. Martje B
Ik zou in zo'n geval de boel inpakken en verschepen.
cd hdd/music
tar -cvzf muziek.tar.gz *
deze dan oversluizen en op de 2 box:
cd /hdd/music
tar -zxvf muziek.tar.gz
De data en tijden blijven zo ook intakt
Magic
The latest Pli in the box. Vu+ Duo,Dm7000, Triax+ Stab en Wavefrontier T55
Goed tip, maar dan moet je wel de ruimte hebben op je schijven in de dreamboxen.
In mijn geval had ik dat niet:
130 Gig aan mp3+flacs en ca. 140 Gig aan film en back-ups, op een 300Gig disk.
Gtz. Martje B
