Op de DGS site:
[relook 400S] 2.11 version PAL Type.
You should download all attached image(usb_kernel_root.img, usb_db.img) And you should backup channel list using PC editor before download the images.
Please refer to README file before you start downloading the firmware attached above.
To get patch files related to GPL license,please click HERE
version
- boot loader
U-Boot 1.1.1
- application
2.11.
- database
1.15
(A : added, F : bug fixed, M : modified/improved of functions, B : Known Bugs)
- A : Single List EPG display (If want to see Grid type, press EPG again on Single List EPG)
- F : Multifeed, subfeed EPG gathering bug.(Not checked on NTSC image)
- F : Channel name parsing(Some channel) bug fixed on APSTAR 6.
- M : Faster channel scan.(about 40% improved)
- M : Add mp3 plugin as a default plugin.
- M : Add Geckow WebInterface by default.
- B : If you scan TP which are about 4Mhz apart, some channel will be duplicated.
relook400s_2.11_PAL.zip (5.52 MB)
Todays dummy is tomorrows expert!
