COLOSSEUM TEAM IMAGES
powered by
EINSTEIN DREAMBOX GROUP (EDG)
HOME SITE:
http://www.dreamboxonline.com
HOME FORUM:
http://www.dreamboxonline.com/forums/index.php
COLOSSEUM DM500 1.0 MAX VAR IMAGE
Released 25.09.2006
Image for FLASH
Warning:
This image MAX VAR is useful only if installed on FLASH memory, and for that reason it was tested only on FLASH of dm500.
- Enigma 1.09 - CVS updated 25/09/2006, mod. CTEAM
- Linux version 2.6.9 (tux@linux) (gcc version 3.4.4) #1 Tue Aug 22 18:55:53 CEST 2006
- Firmware release 1.1.0, 25.09.2006
- busybox v1.01
- WebIf 5.9.7-Expert-Enhanced (CTEAM)
- Tuxtxt v. 1.98
News Colosseum 1.0
DM500 MaxVar:
- MAXVAR
- Over 2,8 Megabytes of free memory space available on /var for addons install!
- automatic Flash Erase
- the image will automatically perform the Flash Erase on the first booting, setting up its defaults, even if you previously load a different image.
You further can do a Flash Erase at any time, by selecting the enigma menu "Expert setup" -> "Factory reset".
- You can use DM7000 Remote Control
- Colosseum 500 image allow to use the 7000's remote control on the dm500, just like you would do on 7000.
To activate this option, go to Extras window on CCC panel, and select "OSD/RC setup"
- Capability to use a programmable remote control (i.e.: Philips Pronto)
- You optionally can use a programmable remote control with Colosseum images, go to Extras window on CCC panel, and select "OSD/RC setup" -> "Use alternate RC keymap"
For aletrnate RC codes programming tips, you can ask on our home forum:
- EPG WIzard with /nfs downloading capability.
On this dm500 image, EPG Wizard is provided and setup to download epg data on a /nfs mounted share (optional).
Other Colosseum features:
- Indipendent start of Cardserver and/or emu
A new emu manager capable of managing cardservers and emus with indipendent start.
Emus can start without the need of restarting cardserver, with less time needed in emu switching, and without breaking down the connection.
It's a smart option: the image will provide itself for the best starting/restarting operation.
Also the channel/provider binding of CCC panel will be performed with the same automatic smart cardserver/emu start/restart.
- A new powerful WEB INTERFACE, never seen on other images before!
You can easily edit from your browser ALL the config files of the current running softcam, and then save them back to image with just a mouse click!!
First select the config file you want to edit, then edit it, and save it, with just a few mouse clicks.
- New skin from Army, the beautiful Army-Nemesis.
New infos on OSD, direct from 7025's Enigma2: current date (complete) and hours:minutes:seconds time display.
Look to the great amount ofTOSD infos, that make Colosseum image one of the most complete images ever.
- New Inadyn setup panel, more powerful
- aMule ready (setup panel included in CCC panel)
Need an external plugin, not present by default into image.
- New file with links for addons download.
The generic addons download link is provided into image (plugins, skins, settings, games, locales...)
The emu download link is NOT PROVIDED into image, and must be entered by the user on file: /var/CTEAM/downloads.url
- new custom scripts, with NewCS infos and smartcards infos.
!!! WARNING - IMPORTANT DISCLAIMER:
!!! THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
!!! EDG IS NOT RESPONSIBLE IN ANY WAY FOR WHAT THE USERS WILL DO WITH THIS FIRMWARE
DOWNLOAD
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
