[all/niet 7025] nieuwe firmware beschikbaar: Gemini 3.30 is uit!!!
Gemini v3.30:
Technical Infos:
* Enigma of: 14.12.2006
* GCC 3.4.4 Original CVS
* Web Interface: 5.9.7-Expert
* Busybox 1.2.2
* Tuxtxt V1.99
Function Buttons:
* BLUE - Blue Panel (BP)
* 2x BLUE - BP -> Extras/Settings
* YELLOW - Quick-Button (can be configured via BP)
* RED - EPG list for active channel
* 2x RED - EPG style menu
* GREEN - subservices
Features:
* Own addon server via internet.
* AutoCam: Emu can be linked to channels/provider
* Cam settings: For example emu renaming,
multichannel patch switchable ( >=7000 )
* OSD: EMM- and ECM- Display switchable
* Download and installation of additional features
via Internet from Gemini server
* System Info: Many extra box infos (for example
harddisk-temperature or all Enigma settings)
* Gemini news loaded in background
* JPEGs can be rotated and the EXIF tags can be
displayed ( >=7000 )
* Support for OGG/Vorbis
* Random function for MP3 and OGG
* Quick-Button-Menu: Many extra features for the
yellow button
* smbmount
* Support for CDROM/DVD, no matter if IDE or USB
(>=7000 )
* Record CIFS/NFS: Record to a CIFS or NFS mounted
harddisk (only working without internal hard
drive, mountpoint set to "var/mnt/hdd" and at
least 3GB disk space)
* Extra menu: Settings for many features like
Inadyn, HTTPD, EPG-Cache, "/var" swap-out and many
more
* Backup function
* Dreamnetcast: inclusive Shoutcast TOP(100)
* Background pictures for Radio, MP3 and SCAN can
be changed via Blue Panel
* Own scripts can be started via Blue Panel
* Calender including reminder (can be changed via
.../calendar.conf)
* MVI's can be converted and tested (from JPG,
BMP, GIF or PNG)
* Bootlogo for 7020 can be changed via menu
* New font and libfribidi for arabic language
* EPG for Dishnetwork
* 2 new root entries for music and pictures can be
created in the filemenu
(BP->Extras/Settings->Root-Entry)
* Create your own Satellites.xml
* Dreambox can be used as printserver
(BP->Extras/Settings->Printer (LPD), FAQ can be
found in the database
* Alarm clock with volume offset adjustable
playing your own WAV-files.
* Display of current channel stream rates
(>=7000)
* Multisocket second camd socket (cam1.socket)
switchable.
* Register an own addon server (useraddon.xml)
* Provider, Frequency, symbol rate and FEC
displayed on infobar (dependent on skin)
* Picon already integrated in Gemini
* "real" automount, Examples in the
/var/etc/automount.conf. Devices, NFS or Cifs
will be mounted automatically (Editor in
BP-Menu)
* dropbear active in all Images (SSH - Daemon)
* cifs-1.44
New:
* new Standar[color:"red"]d[/color]-Skin in the Gemini
* Preview Screenshots in the SkinMenu
* new function with eLabels, you can use
3D-Text in a Skin
* new Widget in Enigma (gProgr[color:"red"]e[/color]ss), works like
the original eProgress, but you can use PNG's
(if you want to know how to use gProgress and
3D-T[color:"red"]e[/color]xt, search in the "Gemini-Blueline" Skin for
"gProgress" or "Shadow"
Fix + Update:
* Remote-Control in the WebIf
* see CVS
Interfaces WebIF:
http://127.0.0.1/cgi-bin/GeminiInfo
http://127.0.0.1/cgi-bin/StopCam?ZAHL (ZAHL =
number of cam)
http://127.0.0.1/cgi-bin/StartCam?ZAHL (ZAHL =
number of cam)
http://127.0.0.1/cgi-bin/InitCam
http://127.0.0.1/cgi-bin/ResetCam
We'd like to thank everybody who paricipated in
the "Gemini suggestion" thread. Unfortunatly many
things can not be realized from our side.
This images doesn't contain any keys or softcams.
Backups or other modified Images are not from us
and won't be supported!
Recommendation:
If you don't install the Image in flash memory,
the flash image shouldn't be of a old version. A
swap file/partition (>= 16MB) should be present
if several processes running in background.
Thanks a lot and have fun
Your Gemini-Team
DM8000 1TB HDD - ICVS + GP3
DM7025+ SC 300GB HDD/4GB CF + Dumbo - ICVS + GP3
Visiosat BIG Bisat |15°W|5°W|0.8°W|4.8°E|9°E|13°E|19.2°E|23.5°E|
Ehhhhh, geen enkele link doet het hier....
* VU+ Duo 2 sat/kabel - Amiko A3 combo - Coolstream Trinity - Dreambox 800 HD SE - Xsarius Fusion HD SE - Mag254 iptv *
* LG 65inch smart 3D tv - Playstation 4 *
Ziet er weer mooi uit,nu zelfs met dag datum en maand aanduiding en nog veel meer nieuws <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
Niet zo vreemd natuurlijk als je probeert naar je localhost te connecten <img src="/forums/images/graemlins/cool.gif" alt="" />
De release zal ook pas vanaf vandaag beschikbaar zijn <img src="/forums/images/graemlins/grin.gif" alt="" />
Am kommenden Montag, dem 18.12.2006 wird es wieder ein Release des Gemini in der Version 3.30 geben.
ACHTUNG: Es werden NUR die Enigma 1 Boxen (DM500, DM56x0, DM7000, DM7020) released, NICHT die Enigma 2 Box (DM7025).
groeten pepper
2 x VU+ duo - 1 x Dream 800 - 1 x Dream7000 - 1 x Dream 500
Wavefrontier T90
Vanavond komen ook de Images voor de andere Dreamboxen online. Ben benieuwd, draai nu nog 3.20, die eerlijk gezegd slecht werkt, aangezien die vaak zeer traag reageerd & pas na 'n reboot 'n dag of 3 redelijk snel loopt (heeft trouwens niks met de var te maken)
Ik hoop iig dat 't automount probleem nu opgelost is...
Alle enigma 1 images zijn sinds afgelopen nacht al beschikbaar hoor <img src="/forums/images/graemlins/confused.gif" alt="" />
Ze zijn te vinden op een ander nederlands SATboard waarvan ik de naam hier niet mag noemen daar ik ook een LORD ben.
Ik zie 't nu ook ja, ik ga vanavond als ik thuis ben 's ff stoeien met deze Image, hoop dat die beter werkt! Over 't algemeen werken de Images van Gemini goed, met zeer veel funktionaliteit.
Weer een zoveelste skinversie van die van Enigma2... En die 3D... Dat zijn simpele schaduwrandjes...
PLi heeft al lang png's in progressiebars... Alleen heet het bij "ons" gewoon eProgress.... en kun je de png gewoon aan toevoegen.
Binnenkort is bijna alles in MPEG4 bij CanalDigitaal... je SD ontvanger kan dus in de Kliko
Nou als je hem niet mooi vind,zet je toch PLI erop.
Niks moet alles mag <img src="/forums/images/graemlins/grin.gif" alt="" />
heeft gemini ook zoiets als een MV plugin waarmee makkelijk door de epg kan bladereb zonder van zender te wisselen?
Dreambox 8000 & VU+ Duo
Synology DS201 NAS
ITV van KPN + digitenne
LG55B6V Oled TV
