[7025] Blijft rebooten met blue screen (opgelost: timer issue)
Ondanks een hele poos met een zeer stabiele image gedaan te hebben, wil de 7025 nu niet meer doorstarten.
Net aan het einde van de opstartfase wordt het gevreesde blue screen (lijkt wel Windows) getoond met melding:
Code:
enigma2 crashed on Sat Jan  1 01:01:54 2000enigma2 CVS TAG: D2006.11.22.23.00.00enigma2 checked out from :pserver:anonymous@dreamboxupdate.com:/cvsplease email this file to crashlog@dream-multimedia-tv.de+ (1) Background File Eraser+ (8) graphics acceleration manager+ (9) gLCDDC+ (9) GFBDC10240k video mem - double buffering available!6928kB available for acceleration surfaces.+ (9) Font Render Class[font] initializing lib...[font] loading fonts...[font] Intializing font cache, using max. 4MB...+ (10) gRCRC thread created successfully+ (15) eWindowStyleManager+ (20) DVB-CI UI+ (20) UHF Modulator+ (20) AVSwitch Driver+ (20) RC Input layer+ (21) Console RC Driver+ (21) input device driverInput device "dreambox front panel" is not a keyboard.Input device "dreambox remote control (native)" is not a keyboard.Input device "dreambox ir keyboard" is a keyboard.Input device "dreambox ir mouse" is not a keyboard.Found 4 input devices!+ (30) eActionMap+ (35) CI Slotsscanning for common interfaces..eDVBCISlot has fd 16done, found 1 common interface slots+ (40) eServiceCentersettings instance.+ (41) eServiceFactoryFS+ (41) eServiceFactoryDVB+ (41) eServiceFactoryMP3reached rl 70---- opening lame channel dbreading servicesloaded 1257 servicesscanning for frontends..opening frontend 0detected satellite frontendclose frontend 0opening frontend 1detected satellite frontendclose frontend 1found 1 adapter, 2 frontends and 4 demux[EPGC] Initialized EPGCachebefore: 1after: 1setIoPrio best-effort level 3 okReading satellites.xmlsec config clearedlink tuner 1 to tuner 0slot: 0 configmode: simplediseqcmode:  simpleslot: 1 configmode: loopthroughdiseqcmode:  loopthroughsec config completedloading bouquet... /etc/enigma2/bouquets.tvloading bouquet... /etc/enigma2/userbouquet.dbe0d.tv24 entries in Bouquet userbouquet.dbe0d.tvloading bouquet... /etc/enigma2/userbouquet.976ab.tv12 entries in Bouquet userbouquet.976ab.tvloading bouquet... /etc/enigma2/userbouquet.dbe04.tv16 entries in Bouquet userbouquet.dbe04.tvloading bouquet... /etc/enigma2/userbouquet.dbe0f.tv17 entries in Bouquet userbouquet.dbe0f.tvloading bouquet... /etc/enigma2/userbouquet.33fc5.tv44 entries in Bouquet userbouquet.33fc5.tvloading bouquet... /etc/enigma2/userbouquet.dbe00.tv33 entries in Bouquet userbouquet.dbe00.tvloading bouquet... /etc/enigma2/userbouquet.dbe05.tv1 entries in Bouquet userbouquet.dbe05.tvloading bouquet... /etc/enigma2/userbouquet.dbe06.tv5 entries in Bouquet userbouquet.dbe06.tvloading bouquet... /etc/enigma2/userbouquet.dbe0c.tv7 entries in Bouquet userbouquet.dbe0c.tvloading bouquet... /etc/enigma2/userbouquet.dbe13.tv11 entries in Bouquet userbouquet.dbe13.tvloading bouquet... /etc/enigma2/userbouquet.dbe02.tv12 entries in Bouquet userbouquet.dbe02.tvloading bouquet... /etc/enigma2/userbouquet.dbe0a.tv15 entries in Bouquet userbouquet.dbe0a.tvloading bouquet... /etc/enigma2/userbouquet.dbe0b.tv48 entries in Bouquet userbouquet.dbe0b.tvloading bouquet... /etc/enigma2/userbouquet.dbe0e.tv126 entries in Bouquet userbouquet.dbe0e.tvloading bouquet... /etc/enigma2/userbouquet.favourites.tv120 entries in Bouquet userbouquet.favourites.tv15 entries in Bouquet bouquets.tvloading bouquet... /etc/enigma2/bouquets.radioloading bouquet... /etc/enigma2/userbouquet.94b4c.radio2 entries in Bouquet userbouquet.94b4c.radioloading bouquet... /etc/enigma2/userbouquet.favourites.radio0 entries in Bouquet userbouquet.favourites.radio2 entries in Bouquet bouquets.radio[font] adding font /usr/share/fonts/lcd.ttf...OK (LCD)[font] adding font /usr/share/fonts/md_khmurabi_10.ttf...OK (Regular)[font] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)recalced border size for 0: 0:41 0:0recalced border size for 0: 0:41 0:0recalced border size for 0: 0:41 0:0recalced border size for 0: 11:41 0:0recalced border size for 0: 11:41 11:0recalced border size for 0: 11:41 11:11recalced border size for 0: 11:41 11:11recalced border size for 0: 11:41 11:11[Network.py] got ip [192, 168, 1, 245]NOT using DHCPActivating language Dutchlanguage set to nl_NLIt's now  Sat Jan  1 01:01:54 2000[timer.py] next activation: 946685014 (in 99844 ms)EXCEPTION IN PYTHON STARTUP CODE:------------------------------------------------------------Traceback (most recent call last):  File "/usr/lib/enigma2/python/mytest.py", line 547, in ?    runScreenTest()  File "/usr/lib/enigma2/python/mytest.py", line 460, in runScreenTest    session = Session(desktop = getDesktop(0), summary_desktop = getDesktop(1), navigation = Navigation())  File "/usr/lib/enigma2/python/Navigation.py", line 30, in __init__    self.RecordTimer = RecordTimer.RecordTimer()  File "/usr/lib/enigma2/python/RecordTimer.py", line 271, in __init__    self.loadTimer()  File "/usr/lib/enigma2/python/RecordTimer.py", line 284, in loadTimer    doc = xml.dom.minidom.parse(self.Filename)  File "/usr/lib/python2.4/xml/dom/minidom.py", line 1915, in parse    return expatbuilder.parse(file)  File "/usr/lib/python2.4/xml/dom/expatbuilder.py", line 924, in parse    result = builder.parseFile(fp)  File "/usr/lib/python2.4/xml/dom/expatbuilder.py", line 207, in parseFile    parser.Parse(buffer, 0)ExpatError: not well-formed (invalid token): line 9, column 128------------------------------------------------------------
Iemand een idee of wordt het zetten van een nieuwe image de oplossing ?
DM7000s, DM7025 (320GB, quad lnb) & DM8000 (1TB, Multytenne twin). Newnigma2 images. Samsung 65".
Ik heb het bericht doorgestuurd naar het Gemini project en kreeg net de vraag om eens naar de /etc/emigma2/timers.xml te kijken.
Ik heb de timers opgeschoond en opnieuw opgeslagen. Alles werkt nu weer als normaal.
