[7000] boot niet meer door: Kernel panic: No init found.
Ik heb hier een DM7000 die met geen mogelijkheid meer wil doorbooten. Allerlei images proberen te flashen (ook de erase.img) met diverse programma's maar hij blijft dezelfde foutmelding geven. Hieronder is de console output gekopieerd. Is er iemand die dit al eens eerder meegemaakt heeft?
Booting from [FLASH] Application in Flash... protocol family 16
loaded at: 00500000 0061C204ed
dri
relocated to: 00400000 0051C204ew driver usbfs
board data at: 00519128 00519174
drivers/usb/core/usb.c: regist
relocated to: 0040546C 004054B8
zimage at: 004059D8 00518FF45/09/08) © 2002-2005 Phillip L
avail ram: 0051D000 02000000
Linux/PPC load: console=ttyS0,115200 root=/dev/mtdblock/0.au)
Uncompressing Linux...done.
DMA zone: 8192 pages, LIFO batch:2
ttyS1 at MMIO 0x0 (irq = 21
Normal zone: 0 pages, LIFO batch:1
ttyS2 at MMIO 0x0 (
HighMem zone: 0 pages, LIFO batch:1
loop: loaded
Built 1 zonelists
Kernel command line: console=ttyS0,115200 root=/dev/mtdblock/0.org>
PID hash table entries: 256 (order 8: 2048 bytes)[nowait]
Console: colour dummy device 80x25 00:09:34:ba:da:dd
Memory: 29712k available (1984k kernel code, 608k data, 80k init, 0k highmem)2
Calibrating delay loop
Using deadline io scheduler
id
POSIX conformance testing by UNIFIXf6 on irq 25
NET: Registered protocol family 16x request size: 128KiB
SCSI subsystem initialized7792 sectors (40027 MB) w/
drivers/usb/core/usb.c: registered new driver usbfs
drivers/usb/core/usb.c: registered new driver hub
dreambox: f
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
DreamBOX rev3+: Found 1 x16 devic
devfs: boot_options: 0x1
JFFS2 version 2.2. © 2001-2003 Red Hat, Inc.xtended Query Table at 0x0
ttyS2 at MMIO 0x0 (irq = 31) is a 16550A
0x00600000-0x0
loop: loaded (max 8 devices)
smc91111.c:v1.0saa 08/22/01 by Daris A Nevil (dnevil@snmc.com)
0x00000000-0x007c0000 : "Dre
eth%d: SMC91C11xFD(r:1) at 0xc306a300 IRQ:28
0x00000000-0x0
MEM:8192b NOWAIT:0 ADDR 00:09:34:ba:da:dd
irq 28 setup to non-criticaleamBOX SquashedFS"
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2 : "DreamBOX Cramfs"
ide: Assuming 50MHz system bus speed for PIO modes; ove00
..Drive spun upializing USB Ma
Probing IDE interface ide0...
Using anticipatory io schedulerb/core/usb.c: registered new dr
dreambox: flash mapping: 800000 at 7f800000
cfi_cmdset_0001: Erase suspend on write enabledrage support registered.ev/mtdblock5 rootfstype
Using buffer write method
disable flash VPP
mi
Creating 6 MTD partitions on "DreamBOX rev3+":
Uncompre
0x00000000-0x00600000 : "DreamBOX cramfs"driver
Now boot
0x00600000-0x007c0000 : "DreamBOX jffs2"
Dr
ibm-iic0: using standard (100 k
0x007c0000-0x00800000 : "DreamB
zimage at: 004058D5 00
USB #0 at 0xe0010000
re
irq 18 setup to non-criticalannot open root device "<NUL
drivers/usb/host/ohci-ocp.c: ohci_hcd (OCP) at 0xe0010000, irq 18
ocp_usb 7: new USB bus registered, assigned bus number 1
zimage at: 00405
usb usb1: Product: OCP OHCIernel panic - not syncing:
usb usb1: Manufacturer: Linux 2.6.5 ohci_hcd(2,0)
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
IBM IIC driver v2.0
irq 9 setup to non-critical
ibm-iic0: clckdiv = 6
ibm-iic0: init
ibm-iic0: using standard (100 kHz) mode
irq 10 setup to non-critical
ibm-iic1: clckdiv = 6
ibm-iic1: init
ibm-iic1: using standard (100 kHz) mode
NET: Registered protocol family 2
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
NET: Registered protocol family 17
Root-NFS: No NFS server available, giving up.
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Mounted root (cramfs filesystem) readonly.
mount_devfs_fs(): unable to mount devfs, err: -2
Freeing unused kernel memory: 80k init
Warning: unable to open an initial console.
Kernel panic: No init found. Try passing init= option to kernel.
<0>Rebooting in 180 seconds..
Gr
BaZ
There is nothing wrong with having a strong opinion... if it comes with an open mind!
lijkt mij dat hij naar een niet gelukte usb mount probeert te schrijven en daarna uiteraard niet hiervan kan lezen
ik zou proberen met afgekoppelde hdd en zonder usb te flashen
grtz
Er zit helaas geen usb stick in..
Alles is eruit en losgekoppeld.
Geen HDD, Geen USB, Geen kaarten.
Dus alleen spanning en seriele kabel.. <img src="/forums/images/graemlins/frown.gif" alt="" />
Hoi,
Wat je kunt proberen is een image er opnieuw inzetten en een flasherase toe te passen.
Zo te zien aan je kernel-log kan hij je flash-rom, waar root zit, niet mounten.
Zet in de bootloader ook alle opties uit zoals booten van nfs, usb of zoiets.
Linux kijkt altijd naar /bin en /sbin of er een init te vinden is. Zoniet dan stopt hij en reboot.
Wat mij vreemd voorkomt is dat hij zelfs het rootfs (ROM) niet kan mounten. Dit wijst, volgens mij erop dat er iets corrupt is.
Hoop dat dit je verder helpt.
Groeten,
Nick
Groeten,
Nick
Astra1, 2 en 3 op triax-schotel 89 cm
Bas als het niet lukt kun je via een jtag of zoals ik al eens gedaan heb via een casinterfase opnieuw van de laatste nieuwe basis flash voorzien
kijk in de FAQ hier hoe ik dat met een paar plaatjes duidelijk maak
Groeten Fred.
AZbox premium , AZbox premium+ , AZbox elite
Dreambox 8000 2maal SAB sky 4800 mini , DVB zelfbouw decoder.
Vaker meegemaakt op het normale i386 PC platform.
Meestal heb ik dan de root parameter vergeten te editen.
Dit gebeurt dus als je root kernel parameter niet geldig is.
In je listing lees ik root=/dev/mtdblock/0.au)
Waar komt die .au) vandaan?
Die moet er in elk geval niet staan.
hoi,,,
Dat heb ik ook al meegemaakt,,
veel gelezen en veel geprobeerd,,
Uiteindelijk lag het aan het programma waarmee ik de nieuwe
image erop wilde zetten ,in mijn geval was dat flashwizzard 6.3 , een verse flashwizzard 6.3 deed wonderen schijnbaar was de vorige versie een beetje de kluts kwijt.
Probeer eens een verse / ander flash-programma ...
bert,,,
