[7025] Elektro Power Save 2.0 + 2.1 by gutemine
1) Prerequisites
Any Image should work, but the DreamboxHardware.py
is replaced, so be aware that this could cause
Troubles !
But original DreamboxHardware.py is now saved,
so ipkg remove will bring back the original state.
Power Save should be compatible to the Sleeptimers
available, but don't take this for sure !
2) Installation
First copy the elektro*.ipk file from elektro*.zip
to /tmp with ftp (TCP/IP must be working already).
If you have flashed an image that offer in Blue
Pannel Manual Addon Install you can use this
functionality to install the ipk file.
If not, then install Elektro by entering the
following commands in a Telnet session:
cd /
ipkg install /tmp/elektro*.ipk
The ipkg install will also restart enigma for
you to get the Elektro Plugin shown in addons
menu. If it doesn't show up try to reboot
manually.
3) Usage
In the addons menu of Elektro you can specifiy
the Time at which the box should go into
Deepstandby and the time when it should wakeup.
Currently only full hours are supported and the
default suggested time is 23h for Deepstandby
and 7h for wakeup.
Be aware that if you enable the Standby on
boot feature with Elektro, that after
wakeup/boot the box will go to Standby
- short Press of the Power Button 2x will
get it fully awake.
The Elektro Power save should be able to
handle that the box awakes properly if there
is a timer planned during the Power Save Time
(this is the reason why DreamboxHardware.py
is patched).
When you plan Timers during the Powersave
time don't forget to plan them with Standby
after Recording, or Dreambox will stay online.
If there is a timers/recording running when
Sleeptime occures the Elektro Plugin will do
a normal Standby instead of Deepstandby
to prevent harming the recording.
After this recording is finished NO delayed
Deepstandby will occure, unless you have
planned your timer with Deepstandby when
finished.
Have Fun to let Elektro Save Power and the
Environment with your Dreambox 7025 !!!!
Download NOW from gutemine's Kitchen
Of van IHAD elektro-2.0.0.zip
Have Fun ! elektro_2.0.0-r2.zip
DM8000 1TB HDD - ICVS + GP3
DM7025+ SC 300GB HDD/4GB CF + Dumbo - ICVS + GP3
Visiosat BIG Bisat |15°W|5°W|0.8°W|4.8°E|9°E|13°E|19.2°E|23.5°E|
