[7020S] c+nl en tv vlaanderen loopt vast op ned 1 2 3 help
Hallo ik heb dm 7020 met gbox 2.25
nu heb ik het probleem als ik beide kaarten in de dream heb dat de zenders die op beide kaarten werken zoals ned 123 en animal enz
vastlopen na 20 sec
dit waarschijnlijk omdat gbox niet meer weet welke kaart hij hebben moet
heb al een paar g lijnen aangenaakt met eigen box id en 0100006A zodat die c+ kaart pakt maar helpt niet
dit is mijn gbox_cfg
# gbox config file
# Task type
# 00 ** normal mode gbox mode (no season, use Multicam instead)
# 01 ** Season Emulation in a Irdeto allcam chid 0602 nonZ
# 10 ** Season Emulation in a Irdeto allcam chid 1702 nonZ
# 11 ** Season Emulation in a Irdeto allcam chid 1702 Z
# 12 ** Season Emulation in a Irdeto allcam chid 1722 Z
# 13 ** Season Emulation in a Irdeto allcam chid 1762 Z
# ** *1 Com port to use for season emulatiom (1 or 2)
# ** 0* Use CTS fr RST detection
# ** 1* Use DCD fr RST detection
# ** ** 9600 = Baudrate to be used (working only on dbox2)
W: { 00 00 } 9600
# gbox working mode
# 00 pure Emu
# 01 pure SoftCam (when card inside), Emu (when no card inside)
# 02 pure Net Client
# 03 Mixed mode !!!!! always use this !!!!!
G: { 03 }
# Display ECM messages on Konsole
# 00 don't show any ECM's
# 01 show only valid ECM's
# 02 show valid and bad ECM's with complete data display
C: { 02 }
# Display EMM messages on Konsole
# *0 don't show any EMM's
# *1 show only valid EMM's
# *2 show valid and bad EMM's with complete data display
# 1* Log any tier change on PW-Nagra-17xx cards into /var/keys/pwupdate.log
M: { 01}
# AutoUpdate
# 00 is ignored (default)
# 01 enable AU
# 02 Auto AU !!!!! always use this !!!!!
A: { 02 }
# Key update
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
U: { 02 }
# Hash pids
# 00 hash all pids, DO NOT USE THIS OPTION, IT IS ONLY FOR TESTING STUFF
# 01 hash only pids with implemented algos and available keys !!!!! always use this !!!!!
H: { 01 }
# Key files folder
# 00 keyfiles in /var/keys
# 01 keyfiles in /var/tmp
T: { 00 }
# On Screen Display for the Multysystemcam on com1/com2
# 00 No OSD (default)
# 01 display Smartcard messages in Neutrino
# 02 display Smartcard messages in Neutrino new nhttpd format
# 03 display Smartcard messages in Enigma
# mypass (use user=root and pass=mypass for nhttpd)
O: { 00 } 192.168.1.5
# Logger and NET-mode UDP port Init
# 00 do not init UDP port
# 01 Init UDP port for IP, port, UDP
L: { 01 } 192.168.1.5
# Trace/Debug
# xx yz ; xx=00 no konsole output
# xx yz ; xx=01 konsole output
# xx yz ; y=0 debug output (don't use)
# xx yz ; y=1 no debug output
# xx yz ; z=0 ouput to konsole
# xx yz ; z=1 output to /var/tmp/debug.txt
# xx yz ; z=2 Output to UDP (to capture with gboxt)
Z: { 00 12 } 192.168.1.5 8024
# *x ** ; x = device nummber to be used (0= default)
# D* ** ; force use of /proc/bus/gtx for cw write operations
(in the dbox2 the gbox writes directly the CW's, 00 is the
recommended mode ! No drivers are required) use D* ** ONLY if
you have Problems. 0* ** should be prefered !!!
# F* ** ; write CW's in both devices (used for PVR in STB04xxx devices)
# ** y* ; y=0001b (0x1*) use slot1 as Multicam (only on STB04xxx)
# ** y* ; y=0010b (0x2*) use slot2 as Multicam (only on STB04xxx)
# ** y* ; y=0011b (0x3*) use slot1 and slot2 as Multicams (only on STB04xxx)
# ** *z ; z=0001b (0x*1) use com1 as Multicam
# ** *z ; z=0010b (0x*2) use com2 as Multicam
# ** *z ; z=0011b (0x*3) use com1 and com2 as Multicams
# ** yz ; yz=00110011b (0x33) use slot1+slot2+com1+com2 as Multicams
# ** *z ; z=0100b (0x*4) invert CTS detection on com1
# ** *z ; z=1000b (0x*8) invert CTS detection on com2
# example: yz = 0x0A = 00001010 (use com2 with inverted CTS detection line)
V: { F0 37 }
en dit mijn cwshare heb de m en dlijnen weg gehaald daar gaat het ook niet om
I: { 2 }
N: { 01 01 03 1F 5000 7000 }
# : { 00 01 03 03 4000 6000 }
X: { 10 }
#W: { 01 02 05 } 1022 100A 100B 102B 1009 101D 1029 1014 1011 101B 0d00 0d03
Denk haast niet dat dit je probleem oplost maar je V regel zou volgens mij met V: { F0 30 } voldoende moeten zijn. Moet achter je L regel ook niet de poort staan? L: { 01 } 192.168.1.5 8024. Ik had bij de L regel trouwens 00 en niet 01 staan. Gebruik nu CCcam maar toen ik gbox gebruikte had ik deze instellingen vandaar de opmerking.
mijn cwshare.cfg :
Code:
M: { 192.168.1.13 { 12345670 }}D: { 192.168.1.6 { 1000 1001 { 07654321 { A5 A5 }}}}I: { 05 }X: { 10 }W: { 01 01 01 } 1FFFN: { 00 01 03 1F 4000 6000 }
en m'n gbox_cfg :
Code:
# gbox config fileZ: { 01 10 } 192.168.1.6 1001W: { 00 00 } 9600G: { 03 }C: { 00 }M: { 00 }A: { 01 }U: { 02 }H: { 01 }T: { 00 }O: { 02 } 192.168.1.13 user=root pass=dreamboxV: { F0 33 }R: { 00 }
werkt prima hier, met zowel een seca2 kaart als een irdeto2 kaart.
merDe
deze ruimte is te huur
ook met beide kaarten tegelijk dan werkt wel goed alleen op 1 2 3 vtmenzo doet allenmaal goed
heb in de bovenste c+NL en in de onderste tv vlaanderen ook al gewisseld maar maakt niks uit ja je probeert alles he
rene
als ik die instelling gebruik komt gbox niet terug gebruik nabilo met gb 2.25
  • 2 weken later...
heeft dan niemand een tvv en c+nl kaartje in 1 box zitten????
Jawel, maar dan met een goed werkende emu: CCcam.
Oke, ik ben geen Gbox van, maar dit terzijde. <img src="/forums/images/graemlins/laugh.gif" alt="" />
Member of the PLi team
Ik ook, maar gebruik ook cccam
DM8000 1Tb 2,5"HDD (Openpli2.1)
2xGigaBlue HD Quad Plus 1Tb (Openmips 4.2)
Wavefield T90(Astra1-2-3 Hotbird)
Synology DS214+
oke heb verder geen problemen met gbox bevalt me wel is net als met cc cam als je goede peers hebt heb je stabiel beeld
Gbox is erg gevoelig, en ligt bij de minste fout snel op z'n gat. Als je kunt, stap over op CCcam. Die is erg stabiel en werkt direct zonder een configuratie direct met een TV-Vlaanderen en CDS kaart in beide kaartlezers.
Waarom gebruik je geen s-lines om aan te geven welke zenders met welke kaart gebruikt moeten worden?
Daarmee verminder je ook meteen drastisch het aantal aanvragen op de kaarten.Omdat op beide kaarten beide providers aanwezig zijn, maar niet voor alle zenders, zal er veel onnodig verkeer naar de kaarten gaan.
oke s lines heb ik nog nooit van gehoord eigenlijk Hoe werkt het precies gaat erom dat hij bijv nl 1 2 3 of anaimal planet via kaart 0100006A pakt
