[alle] PLi® Iolite "2008 Edition" Images Suite 20071230 Rev.4014
A new PLi® Dreambox release is available for download.
This image release fixes some bugs and annoyances found in the initial Iolite release.
The Original PLi® Iolite 2008 suite contains the following images:
PLi®-Iolite-DM500
PLi®-Iolite-DM500-Old-Framebuffer
PLi®-Iolite-DM500Plus
PLi®-Iolite-DM56x0
PLi®-Iolite-DM600
PLi®-Iolite-DM7000
PLi®-Iolite-DM7020
PLi®-Iolite-DM7025
Use the download URL below to be sure to download our original PLi® images.
PLi® Iolite images...
See below for what's New, Fixed & Features since the initial PLi® Iolite release
Enigma1:
- CVS Repository 21 Nov 2007
- PLi® Repository 30 Dec 2007
- DVB subtitling: utterly revamped page composition handling. It is even improved upin in relation to the Helenite version!
- EPG: Don't mark all services 'seen', after receiving an MHW update. This allows us to still receive now/next EIT for those services. Now/next is usually more detailed than MHW
- Softcam Setup: don't restart cardserver when 'restart cam' is pressed (cardserver has its own restart button)
- Softcam setup: wait 5secs between starting Cardserver and Softcam
- Rotor WebIf: goto and store require hexadecimal position
- Remove all 'new found' flags fixed
- Softcam script fix. Make it more readable and less error prone
- Various packages installed in /boot: only remount /boot if it is a separate partition (should fix problems with multiboot situations)
- Fixed NFS server (No download needed anymore)
- Old mountpoints /mnt/... are automatically translated to the new mountpoint /media/...
- Compact flash and USB devices as recording media added
- Smaller network mount descriptions
- Movie directory is automatically created if it didn't exist
- Enigma EPG 5MB filesize limit can be disabled now
Enigma1 OpenEmbedded:
- Compatibility symlink /dev/fb0 for the DM7020 added
- Don't show 'swap' menu, swap is not actually created / used
- Don't show cron in 'services' setup
- Stbup & config file added
- Fixed software management for DM500+, DM600 and DM7020
- Fixed PPanel recovery for the DM600
- You can update from the initial Iolite to this Iolite '2008 editon' via telnet:
Code:
ipkg updateipkg upgrade
and reboot your box
Enigma2:
- CVS Repository 25 Dec 2007
- 20071128 drivers for DM7025
- IE fix for WebIf
- Setting to disable the 'spinner' added (busy animation)
- PPanels:
- 'condition' attribute fixed
- implemented (basic) 'tarball' element support
- SoftwareUpdate plugin: added confirmation messagebox before starting the update
- Mountmanager: default share 'hdd' instead of '/media/hdd'
- 'Preferred tuner' setting implemented
Enigma 1& 2 Plugins:
- Softcam downloads: use our own newcs.xml and newcamd.conf so they work out of the box
Enigma2 Plugins:
- MovieRetitle plugin added
- Emailclient added
- Opencam SoftCam added
- Lastfm seems to be fixed
- Dyndns added
Skins Enigma2:
- Default picon size 70x53
- Updated picons: Canvas, Veronica, Animal Planet, Eurosport added
- Nemesis.BlackBox added
- Orbital position convertor added
Mounts:
- Smaller "long description" for network mounts
- Mountmanager now translates each mount point to a recommended mount point (/media/...)
Support:
- Online update support (IPKG feed) for OpenEmbedded boxes (DM500Plus/DM600/DM7020/DM7025)
- Global satellites.xml 22 Nov 2007
Many low level changes fixes and other updates...
Detailed info, Wiki, FAQ's, HowTo's, TechNotes and information about this and the previous PLi® releases can be found on the PLi® Website:
http://www.pli-images.org
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
  • Reacties 276
waarom nu al weer een nieuwe versie? Ben net de upgrade-problemen op mijn dm500 te boven....
anyway thanks voor de moeite..
't Hoeft niet <img src="/forums/images/graemlins/wink.gif" alt="" />
Maar in de eerste Iolite-versie zaten gewoon wat bugs die we niet meer via de downloads konden fixen.
Moet ik er nog bij zeggen: de "oude" Iolite blijft gewoon werken en blijft ondersteund worden.
Dan weet je nu hoe 't moet, en kan deze geen probleem meer zijn... <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
We willen jullie alléén tegemoet komen door gelijk de bugs aan te pakken.
Member of the PLi team
Als je geen problemen hebt, zou ik die 500 niet flashen als ik je was.
Maar op een OE box zou ik wel gewoon een ipkg update && ipkg upgrade doen, kleine moeite en je bent weer uptodate <img src="/forums/images/graemlins/wink.gif" alt="" />
Ik heb bij deze versie problemen met opnemen op m'n externe NFS mount.
Zodra ik record doe dan maakt hij wel de file aan maar krijg direkt een error:
RECORD FAILED DUE TO A WRITE ERROR DURING RECORDING.
CHECK FOR FILESYSTEM CORRUPTION.
Vorige images geen problemen...Afspelen van oudere opnames gaat prima.
Wat is de beste setting in OPTIONS om mee te geven met een NFS mount? rw,nolock?
super update thnx en keep up the good work <img src="/forums/images/graemlins/smile.gif" alt="" />
Ik heb met pijn en moeite gbox draaiende gekregen. Moet ik alles opnieuw instellen als ik Iolite update met telnet? Oftewel, moet ik alle files weer erop zetten enzo? Dan pas ik er even voor.
Lijkt me van niet. In de image zit nu de juiste gbox script.
<img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> Thx, heb hem onmiddelijk voorzien zonder problemen ! <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
Dreambox DM800HD met de laatste Nabilo
Visiosat Big Bisat - Astra 28.2E / Astra 23.5E / Astra 19.2E / Hotbird 13E / Eurobird 9E / Sirius 4.8E / Thor 0.8W / AB3 5W
Default opties (via webif gedaan) zouden goed moeten zijn. Ik heb hier opgenomen op m'n laptop (Ubuntu) via NFS en wifi.
Hmm...had de mounts weggegooid en opnieuw aangemaakt via webif maar zelfde probleem.
Na een restart van de dreambox was het probleem verholpen....raar.
Bedankt iig!
BiTRiP
Vanavond zelf nog mijn mounts hier gemaakt, deden het gelijk.
Dat is inderdaad zo en de 7020 staat nu inderdaad op versie 20071230 na bovenstaande commando's.
De dm500c laat ik maar ff met rust.....
