OPNEMEN MET DM600PVR MET GEMINI 430
ALS IK EEN PROGRAMMA OPNEEM KAN IK OP DEZELFDE TRANSPONDER
GEEN ANDER PROGAMMA BEKIJKEN.
BIJ PLI LOLITE GING DAT WEL.
IS DAAR EEN OPLOSSING VOOR.
Caps lock vastgelijmd zitten?
Member of the PLi team
Origineel bericht van: florien
DAN MOET JE DE OPTIE "CAN HANDLE 2 SERVICES" AANVINKEN. ONDER PLI ZAT DAT ONDER SOFTCAM SETUP, MAAR IK DENK IN GEMINI BIJ COMMON INTERFACE SETUP.
KLIK
DM8000SSSC | Popcorn Hour C-200 | Synology DS1512+ | Visiosat BigSat: 28-23-19-13-9-5-1w-5w | Panasonic TH-46PZ85
Control4 Home Automation
IK HEB ALLES AANGEVINKT IN HET CAM MENU
EN HET WERKT.BEDANKT VOOR DE SNELLE REACTIE.
HIJ KAN DICHT.
Gast
