Is het mogelijk om een magic module 1.o1 met een laptop en windows 98 te programeren heb reeds een aantal pogingen gewaagd ,window drivers bij magic trance gehaald en penta 1.09 maar wat nu
I dream dream dreaming
800 S/C met sundtek Usb stick,8000 2xS /C/T/ Hdd/Nas
Diverse schotels Draaibaar,Vast en Wave Frontier T90 met Emp16/1 switch
Draaibare Deltastar 120 in nieuwstaat met Invertum flens lnb
When you first put your brand new Magic Module into your receiver, their is no software on it. You can check this in the CAM menu of your receiver. In this menu it shows DREAMLOAD.
There are two different procedures for deleting the software in the Magic Module so it switches back to DREAMLOAD mode.
Procedure A:
Switching the receiver OFF and ON three times WITHOUT smartcard.
Procedure B:
Removing and re-inserting the Magic Module three times WITHOUT smartcard.
Also you can to the Cam Menu, and select the "Prepare for loading" option and press OK
Each of these procedures resets the Magic Module to the DREAMLOAD mode and removes the software from the Magic Module. You can check that in the CAM menu of your receiver. Keep in mind that you can only program the Magic Module with new software when it is in Dreamload modes.
You will now be asked to confirm that you wish to blank the CAM and activate the loader. You select "YES" and this will remove the current firmware loaded into the CAM.
When you see the above message you'll need to power off the satellite receiver and then power on again to reset the CAM.
Now Press "Menu" on your satellite remote and select "Common Interface" option. You should now see "Dream Load"
This means the CAM has been successfully cleared and is ready to be re-programmed
Requirements:
- Receiver with Magic Module connected to the lnb !!! of a Notebook
- Magic Module programmer.
- Serial cable (serial port/com port settings: 115200,8,N,1,Xon/Xoff).
- Magic Module Loader program (available in Magic software area).
- Magic Software (available in Magic software area)
Now we can beginning to program the Magic Module
Follow the Instructions
1. Installing the program Magic Loader on your PC And open it.
2. Insert the programmer into the CAM, connect a serial lead from the programmer to a spare COM port on your PC and power on the PC. Both RED & GREEN lights should be lit on the programming unit once PC has booted up - Both PC & Receiver should be switched on at this stage.
3. Now run the Magic Module loader on your PC and click on "Connect"
You should now be connected and the RED light should no longer be lit on the programmer. Only the GREEN light should now be lit. If both RED & GREEN lights are still lit DO NOT continue any further.
The light on the programmer is GREEN - so it's ok to continue....
4. Click on the Program Module button and select the file you wish to load to the CAM. We have Penta101.mbf selected above. Just double-click on the file name to load it.
5. The programming Progress bar shows the module being programmed. Once the progress bar gets to the end it will close the programming window.
6. Now click on the Disconnect button.
Now you can remove the programmer from the Magic Module.
Switch off the Satellite Receiver and eject the Magic Module. Then re-insert Magic Module and power on the Satellite Receiver. The CAM is now programmed and ready to go.
On some receivers you may need to power on the receiver first and then insert the CAM otherwise it won't detect the CAM.
2 x 800HD DVB-C Newnigma2 v3.2.2 CCCam 2.2.1
Debian with Mastera, SMARGO+ CCcam 2.1.4
Sorrie Henant dit is niet wat ik bedoel mijn vraag was of ik de magic met de laptop zonder serieel gedoe kan proggen
Oh Sorry,
Volgens mij wil even de goeie INF laden en kijken onder hardware of je magic=module wordt herkend dan kun je de software starten.
Bedankt Hemant
Ga het vanavond nog eens proberen
Satsean
Kom niet veel verder, laptop de magic module ingezet en magicinf in de hardware.De laptop start op met magicinf
daarin kun je aangeven windows 95 of 98 indien je deze opent krijg je magic98-kladblok met de configuration file for dvb module under win95/98 first version 0.00
Hmm Vreemd,
Moet toch werken, doe je dit via de hardware wizard en dan add new hardware en dat inf file opgeven krijg je de magicmodule te zien, vervolgens volgende en de config wordt weggeschreven.
Klopt helemaal
maar in apparaatbeheer onder smartkaart sub magic moduul
krijg ik een uitroepteken in een geel vierkantje dit geeft aan dat er een konflikt is met direct toegankelijk geheugen als ik dit uitschakel kan ik nog niets naar de magic module schrijven dus nog geen resultaat
ga deze week eens linux op laptop zetten daar kun je wel
rechtstreeks (met de juiste drivers) naar een magic schrijven groetjes satsean
