To modify the flash or flash hardware of a cam you may need some special equipment:
Programmer for the W29C040T-90 (This is a Winbond part Number - Full technical specifications HERE)
A 32 pin SOIC Test Clip
Flash Cam File (this file here is for an Aston cam to Freecam)
Maybe a small tipped soldering iorn (if you remove the IC).
Maybe an adapter for the programmer (if you remove the IC).
Here is a editor for the Free Cam files.
In order to read some of the files below you will need to have installed
This modification to a Viaccess Red Cam does not work on the Echostar 3000 ADP
It works for all Manhattan and Echostar 3600 and Echostar 2200
Now we will look at modifiying an Irdeto / Viaccess cam.
Both these cams have a 32 pin Flash memory chip called AT29C040 (This is a Atmel Code) and this is a 4 Megabit (512 X 8), 5 volt Flash memory (4Mb (512K × 8) CMOS PEROM, 5V only - 120ns Access)
See picture to the right showing position of the 29C040 IC.
Click HERE for the ATMEL Adobe PDF file - The IC is a 32T
(32 Lead - Plastic Thin Small Outline Package . (TSOP))
Irdeto Cam Circuit Diagram 1 & 2 - Viaccess Cam Circuit Diagram 1
To program this flash memory you need a Atmel programmer.
Now if you are going to program a AT29C040 Flash memory you need the IC, the flash file and an adaptor for the programmer.
The IC can be purchased from www.farnell.com and the details are: IC-4MB CMOS PEROM
Order Code 786743
Description Time access 120 ns Voltage programming 5 V Base number 29C040 Case style DIL Memory configuration 512Kx8 Memory type CMOS PEROM Pins number of 32 Memory size 4 M-bit 4Mb (512K8) CMOS PEROM, 5V only - 120ns Access
Manufacturer Atmel
Manufacturer Part Code AT29C040A-12PC
Pack Quantity 1
Catalogue Page Number 2:1177
Price 32.00 UK Pounds (64 Tunisian Dinars)
If you are located outside the UK click HERE to obtain details of your nearest Farnell distribution outlet.
The flash file will need to be read from an existing cam thats been programmed to work as a FREECAM.
If you want to use an adaptor you need to order a 32 TSOP to 32 DIP Clam shell pin to pin converter, this is about $90 US dollers from HERE.
The pdf data sheet for this adapter is HERE. The adaptor can be purchased from: Newark Electronics and the price is $264.34. I also found the manufacture of this adapter at ICE Tech in Sheffield, England.There are many prices for this adapter, so shop around before you buy.
This adapter will work with the following IC's:
AMD (PREFIX AM): 27C010, 27C020, 27C040, 27H010, 27LV010, 2LV010B, 27LV020, 27LV020B, 28F010, 28F010A, 28F020, 28F256, 28F256A, 28F512, 28F512A, 29F002BB, 29F002BT, 29F002NBB, 29F002NBT, 29F004, 29F004BB, 29F004BT, 29F010, 29F010A, 29F010B, 29F040, 29F040B, 29F040T, 29LV001, 29LV001BB, 29LV001BT, 29LV010A, 29LV010B, 29LV040B
ATMEL (PREFIX AT): 27BV010, 27BV020, 27BV040, 27C010, 27C010L, 27C020, 27C040, 27C080, 27LV010, 27LV010A, 27LV010L, 27LV020, 27LV020A, 27LV040, 27LV040A, 27LV080, 28C010, 29BV010, 29BV010, 29BV010A, 29BV040A, 29C257, 29C512, 29C010, 29C020, 29C040, 29LV010A, 29LV020, 29LV040, 29LV040A, 29LV512, 49BV001, 49BV001T, 49BV002T, 49BV001, 49BV010, 49BV020, 49BV040, 49BV040T, 49F001, 49F001N, 49F001NT, 49F001T, 49F002, 49F010, 49F020, 49F040, 49F512, 49HBV010, 49HF010, 49LV010, 49LV001, 49LV001T, 49LV002, 49LV002N, 49LV002T, 49LV010, 49LV020, 49LV040, 49LV040T
CSI(Catalyst): (PREFIX CAT) 28F010, 28F020, 28F256, 28F512
FAIRCHILD (PREFIX NM OR FM): 27C010, 27C020, 27C040
FUJITSU (PREFIX MBM): 27C010,1001
HITACHI (PREFIX HN): 27C101G, 27C301G
HYNIX (PREFIX HY): 29F002TT, 29F040AT-90
HYUNDAI (PREFIX HY): 29F002TT, 29F040AT
INTEL (PREFIX E FOR TSOP): 27C010, 27C020, 27C040, 28F010, 28F001BX-B, 28F001BX-T, 28F010, 28F020, 28F256, 28F512
ISSI (PREFIX IS): 27C010, 28F010
MACRONIX (PREFIX MX): 27C100, 27C1001, 27L100, 29F001B, 29F001B, 29F001T, 29F002, 29F004B, 29F004T, 29F040
MOSEL-VITALEC (PREFIX V): 29C51000T, 29C51001T, 29C51002T, 29C51004T, 29LC51000, 29LC51001
NATIONAL (PREFIX NM): 27C010, 27C020, 27C040
NEXFLASH (PREFIX NX): 29F010A
SST: 27SF010, 27SF020, 27VF040, 28SLF040A, 28SF040, 29EE010, 29EE020, 37VF010, 37VF020, 37VF040, 37VF512, 39SF010, 39SF020, 39SF040, 39SF512, 39VF010, 39VF020, 39VF040, 39VF512, 49LF002, 49LF002A, 49LF004, 49LF004A, 49LF020, 49LF040, 49LF080
ST MICROELECTRONICS FORMERLY SGS-THOMSON (PREFIX ST or M): 27C1000, 27C1001, 27C2000, 27C2001, 274001, 27C801, 27V101, 27V201, 27V401, 28F101, 28F201, 28F256, 28F256A, 28F512, 28F512A, 29F002BB, 29F010B, 29F040
TEXAS INSTRUMENTS (PREFIX TMM): 27C010, 27C010A, 27C020, 27C040, 28F010A, 28F020A, 28F256A, 28F512A
TOSHIBA (PREFIX TC): 57C1000, 57C1001
WINBOND (PREFIX W OR BM): 27C010, 27C020, 27E010, 27E020, 27E040, 27E512, 27L010, 27L020, 27L040, 29EE512, 29EE010, 29EE011, 29C020, 29C040, 49F020, 49V002, 49V002F
XICOR (PREFIX X): 28C010, 28C040, 28C513
You could re program the Flash memory without removing the memory or without buying the expensive 32 TSOP to 32 DIP adapter.
You will require a 32 pin SOIC test clip - Click HERE for the Adobe PDF file. See below for further details.
Farnell Order Code 517940
Description Material contact Gold plated beryllium copper Plating contact Gold Case style PLCC Ways number of 32
Manufacturer HIRSCHMANN
Manufacturer Part Code 933087001
Pack Quantity 1
Catalogue Page Number 2:470
Price 20.25 UK Pounds (40.50 Tunisian Dinars)
Now to use this 32 pin SOIC with the above programmer you need to solder some wires from the test clip to a 32 pin socket (see below) that can be inserted in the above MICRO PRO programmer. So below is the pin numbers of the TSOP IC thats fitted in the Cam and to the right are the pin numbers of a standard DIP package that will work with the above programmer. So you solder from the 32 pin dil socket to the above test clip 32 wires. then you can insert the dil socket into the programmer and program the 29C040 TSOP on board.
The below item can be purchased from Farnell Components, Part number:355-0771 Price: 0.51 pence (1 TDN), data sheet can be downloaded HERE.
voor grafische details -> http://www.maxking.com/smartcardcamapation.htm
Als de link alsnog verwijdert wordt...vraag hem maar op via PM
Bovenstaand is alleen van toepassing voor een gewone CI,
De magic en aanverwante ci's zijn voorzien van een 2MB flash welke in een tsop48 behuizing zit !
