[Strong] Sattracker 1.3 EMU firmware
Hier is de release sattracker 1.3 EMU beta firmware met weer verbeteringen in deze firmware <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
BrOther wrote:
NEW CHARACTERISTICS And BUGS CORRECTED IN THIS VERSION
- the publisher of keys for system conax already works perfectly.
- Publisher of keys for Skycrypt system in case in a future the routines in the HDL were implemented.
- the publisher of keys viaccess also publishes keys of 16 bits for viaccess2
- EMU supports to the systems seca1, nagravision1, nagravision1 $2, irdeto, betacrypt, tpscrypt, viaccess1, viaccess2 (without testear), conax, and seca2 tables 9x prov. 0070, 0071, 0072, Bx tables in prov. 0064
- pilot DVB now shows correctly the bar of progress, as well as the hours of beginning and end of a session.
- For minidiseqc+motor also new routines have been added.
- precise Movement but in degrees for motors STAB HH100/STAB HH120.
- the EPG of Sky Italy returns to work perfectly after I complete change of SID and TID that has undergone channel EPG of this platform.
- Multilenguaje added to the Publisher emu keys (Menu-9).
- Some obsolete frequencies have been changed by other but recent ones to obtain level of signal in certain satellites. Astra 1D also has been added to the menu of configuration of antennas.
- Bug corrected in the option search of channels "To leave and To record"
- Bug corrected in the option search of channels ordered by dry supplier.
- it is recommended to deactivate the Virtual Card (Menu-4-0) using original cards DRY.
- So far it is not possible To program Recordings. In next versions it will be solved. To program a recording will cause that the receiver is made unusable until returning to load firmware again, or a list of channels.
NOTE: Not to use lists of channels of others firmwares.
The list including contains the new routines emu to work well with this
firmware.
We can create our personal list of channels from this, is possible
to copy and to stick channels of a list of another one firmware (single SatTracker versions)
to this list with the publisher for PC ED Strong 5.5F
Keep on the good work Brother!! <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/ubbthreads/images/graemlins/biggthumpup.gif" alt="" />
Jammer dat ik geen 8000 heb anders had ik hem wel willen bekijken.
mooi dan kunnen we weer een nieuwe lijst maken
ik had net sky in mijn lijst gezet.
Eerste Strong 8000 en 8100 van NL & BE met
: Motor sm3uni 28-12-03,
: Spdif (AC3) 30-10-04,
: 3x8 mb Flash 07-02-05
Tja, ook hier aan deze kant. Nou ja je bent van de straat zullen we maar zeggen.
LS
Beter als naar het Nederlands elftal kijken. <img src="/ubbthreads/images/graemlins/loldev.gif" alt="" />
Ga het deze week uitproberen eens kijken of sky patch nu niet meer nodig is.
VU Duo 4K se pli 8.1 dvb-c + s / ET 8000 pli 8.1 dvb-c + s / Vu+ Uno 4k se pli 8.1
zo en hier is dan de nieuwe (vreeswijk-v1.3-emu)kanalenlijst voor de motor
suc6
Zo, jij bent snel, ik gaat hem gelijk proberen,
gr. LS
domme vraag dat mag toch niet
je moet wel de sky patch laden na dat je de lijst erin gezet heb
ps: niet de conax patch in de deco zetten dan word hij traag conax werkt ook met de sky patch
werkt als speer, nog nooit zo snel de boel draaiend gehad.
Bedankt voor de lijst Vreeswijk.
LS
