[DBOX-II] Bij flashen "chip reports low voltage on erase"
Bij het flashen van mijn Nokia Dbox II krijg ik een foutmelding die aangeeft
" Erasing blocks 1/63 (1%)Chip reports low voltage on erase: status 0xa800a8".
Even erboven wordt ook al aangegeven:
"*** Warning: CPU Core has Silicon Bugs -- Check the Errata ***"
Issie nu echt overleden of ziet iemand nog mogelijkheden?
Bijgaand in de bijlage de capture van Flashing Assistent en hieronder de log van het flashen (met Flashing Assistent":
ôdebug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: BMon V1.0 mID 01
debug: feID 7a gtxID 0b
debug: fpID 5a dsID http://Hallenberg.com
debug: HWrev X5 SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
debug: autoboot aborted from terminal
dbox2:root>
dbox2:root> boot net net net net net net net net net net
debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Got BOOTP reply from Server IP 192.168.123.251, My IP 192.168.123.202
debug: Sending TFTP-request for file D/dboxifa_tmp/tftpboot/u-boot
will verify ELF image, start= 0x800000, size= 140592
verify sig: 263
boot net: boot file has no valid signature
Branching to 0x40000
U-Boot 1.1.2 (Tuxbox) (Mar 28 2005 - 13:54:32)
CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
Board: DBOX2, Nokia, BMon V1.0
Watchdog enabled
I2C: ready
DRAM: 32 MB
FLASH: 8 MB
FB: ready
LCD: ready
In: serial
Out: serial
Err: serial
Net: SCC ETHERNET
BOOTP broadcast 1
Using SCC ETHERNET device
TFTP from server 192.168.123.251; our IP address is 192.168.123.202
Filename 'D/dboxifa_tmp/tftpboot/u-boot'.
Load address: 0x100000
Loading: *Using SCC ETHERNET device
Filename '/tftpboot/logo-lcd'.
Loading: *##
done
Bytes transferred = 7680 (1e00 hex)
BOOTP broadcast 1
Filename '/tftpboot/logo-fb'.
Loading: *####################################
done
Bytes transferred = 179877 (2bea5 hex)
Options:
1: Console on null
2: Console on ttyS0
3: Console on framebuffer
Select option (1-3), other keys to stop autoboot: 0
Bank # 1: INTEL 28F320C3B (32M, bottom boot sect), 32 bit
Size: 8192 kB in 71 Sectors
Sector Start Addresses:
10000000 (RO) 10004000 (RO) 10008000 (RO) 1000C000 (RO)
10010000 (RO) 10014000 (RO) 10018000 (RO) 1001C000 (RO)
10020000 (RO) 10040000 (RO) 10060000 (RO) 10080000 (RO)
100A0000 (RO) 100C0000 (RO) 100E0000 (RO) 10100000 (RO)
10120000 (RO) 10140000 (RO) 10160000 (RO) 10180000 (RO)
101A0000 (RO) 101C0000 (RO) 101E0000 (RO) 10200000 (RO)
10220000 (RO) 10240000 (RO) 10260000 (RO) 10280000 (RO)
102A0000 (RO) 102C0000 (RO) 102E0000 (RO) 10300000 (RO)
10320000 (RO) 10340000 (RO) 10360000 (RO) 10380000 (RO)
103A0000 (RO) 103C0000 (RO) 103E0000 (RO) 10400000 (RO)
10420000 (RO) 10440000 (RO) 10460000 (RO) 10480000 (RO)
104A0000 (RO) 104C0000 (RO) 104E0000 (RO) 10500000 (RO)
10520000 (RO) 10540000 (RO) 10560000 (RO) 10580000 (RO)
105A0000 (RO) 105C0000 (RO) 105E0000 (RO) 10600000 (RO)
10620000 (RO) 10640000 (RO) 10660000 (RO) 10680000 (RO)
106A0000 (RO) 106C0000 (RO) 106E0000 (RO) 10700000 (RO)
10720000 (RO) 10740000 (RO) 10760000 (RO) 10780000 (RO)
107A0000 (RO) 107C0000 (RO) 107E0000 (RO)
Bank # 2: missing or unknown FLASH type
Filename 'kernel-yadd'.
Loading: *#################################################################
done
Bytes transferred = 763552 (ba6a0 hex)
Un-Protected 63 sectors
## Booting image at 00100000 ...
Image Name: dbox2
Image Type: PowerPC Linux Kernel Image (gzip compressed)
Data Size: 763488 Bytes = 745.6 kB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
init started: BusyBox v0.60.2 (2002.02.26-14:29+0000) multi-call
dbox2miniroot zum Flashen
- Hallenberg.com -
Wilkommen auf ihrer dbox2
Der Flashprozess wird nun gestartet...
While erasing blocks 0x00000000-0x00020000 on /dev/mtd/4: Input/output error
Flashen abgeschlossen.
Sie können die dbox jetzt ausschalten.
Please press Enter to activate this console.
------ Zusatzinformationen ------
Gewählter Netzwerkadapter: Broadcom 570x Gigabit Integrated Controller (0)
IP-Adresse des Netzwerkadapters: 192.168.123.251
IP-Adresse die die dbox bekommt: 192.168.123.202
Betriebssystem: Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DBOX-IFA Version: 1.7.0.2
Dateiname des Images: TVHomeCompleet070605.img
Imagetyp: Zwei Flashs
------ Powered by http://www.dboxservice-hallenberg.de ------
HELP! ;-)
Alvast bedankt voor de evt. input,
Henk.
Huh,
zie je dat als je gewoon een IMG flasht? Ik gebruik zelf altijd de "speciale ppcboot" methode met de "13.IMG" maar dan zie ik dat soort meldingen helemaal niet.
Of ftp de nieuwe IMG een snaar /var/tmp en dan vanad de dbox2 zelf software updaten. Kijk maar eens of 't dan wel goed gaat.
suc6,
Pekka
Dit lijkt me ook niet goed of wel !!
Code:
Wat voor een box heb 1* Intel of 2* Intel
Dan moet je wel het goede image pakken anders gaat het fout
heb een Nokia Dbox II, 2x intel.
Ik weet zeker dat het image goed is, gebruik ik op andere boxen ook. Maar ook andere images werken niet.
Wat voor 13.img bedoel je? Is dat een speciaal image? Waar vind ik die 9en de ppcboot) bestanden? gebruik wel al een pccboot, maar wellicht dat je een andere hebt...
Uploaden naar de box en dan flashen gaat niet, want hij start niet meer op merkte ik nu.
Moeten we het niet meer in de richtingvan een harware-error zoeken? is er dan wellicht een handige electronicus die een oplosing heeft?
bedankt voor de input zover,
henk.
Super, dank je!
Waar vind ik dan de juiste bestanden? is het een speciaal image of ppcboot bestand? of kan ik gewoon de gangbaar verkrijgbare nemen..? met een gewoon image en de normale ppcboot lukt het dus niet.
Kun je anders degene linken 9of url geven) die jij gebruikt?
Iemand anders nog een idee?
Cammy misschien? Die lijkt nogal verstand te hebben van de hardware van de box... ;-)
even googlen en je vind alles wat je nodig hebt en de ppc boot weet eigelijk niet of ik hem er bij mag zetten als bijlage
groeten Fred
Bedankt!
Ga het nog es proberen met deze ppcboot.
Maar jullie denken allemaal niet aan een hardwware-error dus?
Lijkt mij nl wel voor de hand liggend, aangezien hij een hardware-error lijkt aan de duiden...
ok suc6.
Je kan ook gewoon de image uploaden in je dbox2 tmp folder en vanuit de box in expert menu gewoon flashen.
Je moet dan wel kiezen voor image flashen zonder bootloader!
Zie ook mijn sticky hierbovenaan dit forum..
Geld maakt niet gelukkig maar geluk is onbetaalbaar
ok suc6.
Zoals ik hierboven al aangaf:
"Uploaden naar de box en dan flashen gaat niet, want hij start niet meer op merkte ik nu."
<img src="/forums/images/graemlins/ooo.gif" alt="" />
Gr, Henk.
