toh3.3_hot5.5.zip: 1,021.4 KB Sun Jun 26, 2005 11:51:17 bij de orginele site gelezen.
zijn wel druk nu de boys.
niet getest is wel van ph.
zal hem zo eens testen.
ibby
Humax ToH3.3 HoTplugged v5.5
- PW Portal Fix (by Padawan)
- Nagra optimization
- Spice Fix
No PMCT-Update necessary for normal use !!!
It is recommended that you don't modify that readme or firmware to publish
that work in your own name. So if you don't get along with this little agreement,
HoT will stop the public accessibility of new releases in the future.
So:
DON'T MODIFY FIRMWARE OR MODULES!!! LAST CALL !!!
HoT
Humax ToH3.3 HoTplugged v5.4
not released
Humax ToH3.3 HoTplugged v5.3
- Cabo Fix
- Irdeto Card-Fix
Humax ToH3.3 HoTplugged v5.2
- ORF fix when PW-Card is used
- PK0 AU (Nagra) on Key2+3 (wait some minutes)
- tps crypt optimized
- version 2.1 of CATONE Conditional Access Tool included (thx to that team)
thx also to Humax & D-Mon
HoT
CATone V2.1
- Key Edit select CA system by rcu colors;
- in case current channel is decripted by emu the editor should start showing actual provider
and key in use marked in red (in Irdeto,Beta it only shows 1st Iredto provider);
- Provider name for known providers is shown;
- Fully implemented CAT and PMT parser. 3 views available : compact, full, hex data;
- views and preferences are now stored:
-> possible to use different color schemes for
a-start menu, about and help
b-key editor
c-parser
d-ecm-dw
-> preferred parser view is stored for both CAT and PMT (may be different)
-> at each calling CATone starts recalling last stored views.
-> CATone preferences (and other things <img src="/forums/images/graemlins/smile.gif" alt="" /> ) are resetted when reloading complete setting list.
CATone is free. Nothing may be modified. Neither FW nor Strings.
This readme should accompany any CATone distribution.
Enjoy.
SuD
werkt goed
cabo is traag bij het zappen maar werkt goed.
polsat is goed.
tps +spice is goed.
de c+ ird 2 kaart zapt nu wel snel.
lijkt mij dus beter dan de 5.2.
ibby
<img src="/forums/images/graemlins/xyxthumbs.gif" alt="" /> <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
ook al een nl vertaling te verkrijgen bij josje01
da's snel echt toppie
Hier is dan de door mij vertaalde "ToH3.3-Hot5.5 incl de Nederlandse-vertaling".
Gr, pribo. <img src="/forums/images/graemlins/laugh.gif" alt="" />
Met vriendelijke groet, Leo.
Tja. 2000 kanalen vermeld in de lijst, en 2500 keer L.M. Prins vermeld...
Toch maar weer terug naar de originele Engelse versie.
Ik heb vandaag en gisteren meerdere Humaxen voorzien van de nieuwe HoT5.5, maar geen problemen ondervonden hoor?
Ook niet in mijn Humax.
Gr, pribo. <img src="/forums/images/graemlins/confused.gif" alt="" />
(Zoals wel vaker) pakte mijn humax niet in 1x de kaart en stond die naam steeds voor mijn neus te knipperen. Vind het wel best hoor..... klopt het dat onder het ? nog duits staat?
(Zoals wel vaker) pakte mijn humax niet in 1x de kaart en stond die naam steeds voor mijn neus te knipperen. Vind het wel best hoor..... klopt het dat onder het ? nog duits staat? [color:"red"] Onder het "?" is nog in het Duits, deze Duitse vertaling is niet te vertalen. In de Duitse taal zit waarschijnlijk software verwerkt, als ik die ga vertalen loopt de Humax kompleet vast. Wat ik begrepen heb zijn er al tientallen mensen die zich het hoofd hier over breken en zelfs het HoT-team heeft het nog niet voor elkaar gekregen dit te vertalen. [/color]
Ik hoop je hiermee van dienst te zijn geweest.
Laat toch de orginele versie met rust .
De orginele versie werkt altijd en het best.
PH zegt dit al jaren sinds de eerste patch.
In andere ontvangers patch software zitten ook niet vaak nederlandse vertalingen.
Daar hoor je ook niemand over.
Moet ook eens gezegt worden vind ik.
Problemen zijn vaak de veranderingen in de software patch.
Dit was een kleine hint van mijn kant.
Toch succes gewenst met de humax.
ibby
Sluit me helemaal bij je aan Ibby!!
Als je het nodig vindt de NL vertaling toe te voegen, probeer dan contact met de maker te zoeken (Forums???) It's all about respect!
Cable rules, only for fools...
Hi fooks
heb een probleem met TPS, krijg dit niet meer aan de praat.
heb veel ervaring met installeren op humax 5400.
Is altijd gelukt. TPS wil nu niet lukken. Snap er niks van. Al vanalles uitgeprobeerd.
heb toh 3.3 hot 5.5 de nederlandse versie (Josje)geinstalleerd. ziet er goed uit.
verder alles geinstalleerd zoals altijd (PMC table, key-bin van Mach1, card+emu+s, funcard met laatste mach1, etc)
TPS is verdwenen nadat ik met Humbox een nieuwe zenderlijst heb geinstalleerd.
Vanaf de nieuwe zenderlijst is tps niet meer terug te krijgen.
Wie kan me helpen???
bedankt alvast,
spacemaker
