[DBOX-II] Flashen van D-Box lukt niet in Debug mode, andere box lukt wel
Heb hier een box staan welke een nieuwe image weigert terwijl andere boxen wel goed gaan.
onderstaand een dump van de log ;
debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
debug: WATCHDOG RESET
debug: BMon V1.0 mID 01
debug: feID 7a gtxID 0b
debug: fpID 5a dsID 01-2a.46.80.07.00.00-92
debug: HWrev X5 SWrev 0.81
debug: B/Ex/Fl(MB) 32/00/08
WATCHDOG reset enabled
dbox2:root> debug:
BOOTP/TFTP bootstrap loader (v0.3)
debug:
debug: Transmitting BOOTP request via broadcast
debug: Got BOOTP reply from Server IP 192.168.0.10, My IP 192.168.0.11
debug: Sending TFTP-request for file C/PROGRAM FILES/DBOXBOOT/ppcboot_writeflash
will verify ELF image, start= 0x800000, size= 201596
verify sig: 262
boot net: boot file has no valid signature
Branching to 0x40000
ppcboot 0.6.4 (Apr 11 2002 - 16:10:44)
Initializing...
CPU: PPC823ZTnnB2 at 67 MHz: 2 kB I-Cache 1 kB D-Cache
Board: ### No HW ID - assuming TQM8xxL
DRAM: (faked) 32 MB
Ethernet: 00-50-9c-43-81-f1
FLASH: 8 MB
LCD driver (KS0713) initialized
BOOTP broadcast 1
TFTP from server 192.168.0.10; our IP address is 192.168.0.11
Filename 'C/PROGRAM FILES/tftpboot/logo-lcd'.
Load address: 0x130000
Loading: ##
done
LCD logo at: 0x130000 (0x1F9FFC0 bytes)
BOOTP broadcast 1
Filename 'C/PROGRAM FILES/tftpboot/logo-fb'.
Load address: 0x120000
Loading: #########
done
FB logo at: 0x0 (0x1FC0000 bytes)
AVIA Frambuffer
Input: serial
Output: serial
1: Console on ttyS0
2: Console on null
3: Console on framebuffer
Select (1-3), other keys to stop autoboot: 0
dbox2-ppcboot> bootp 120000 /C/2xKabelImage.img
BOOTP broadcast 1
Filename '/C/2xKabelImage.img'.
Loading: #######################################################################
done
dbox2-ppcboot> protect off 10020000 107fffff
Un-Protected 63 sectors
dbox2-ppcboot> erase 10020000 107fffff
Erase Flash from 0x10020000 to 0x107fffff
sector 66 .... done
Erased 63 sectors
dbox2-ppcboot> cp.l 120000 10020000 1F8000
Copy to Flash... Flash not Erased
dbox2-ppcboot>
Ziet er naar uit dat de flash niet erased wordt, het is een Nokia met 2x intel waarvan de write protect uitstaat.
Iemand enige suggestie??.
Heb je rechtstreeks geprobeerd te flashen? Dus de image in het tmp folder doen.
Geld maakt niet gelukkig maar geluk is onbetaalbaar
Hoe gek het ook mag klinken, maar op deze box staat nog betasoft o.s. terwijl hij wel in debug staat, kan dan ook de tmp folder niet bereiken.
na enige tijd verschijnt errorcode ud04 op het display waarna ik met de ok toets de hele opstart cyclus opnieuw kan opstarten.
debug scherm in display en na enige tijd betaresearch.
@Offshore,
Als eerste moet je ppcboot opnieuw installeren.
Verdere opmerkingen:
dbox2-ppcboot> cp.l 120000 10020000 1F8000 moet cp 120000 10020000 1F8000 ( of is dit slechts een type-fout?)
(Ik weet zo niet uit mijn hoofd of de 10020000 vooraan moet staan.)
Je zou evt. nog een een md (memory display) kunnen doen, voordat je de cp doet.
succes,
vdkolk989
