Pace Puma TD450 & Sony DVD Recorder HX710s Sync Record Issues
Please accpet my appologies for wirtting this in english. I do speak Dutch and can read it (still have to learn writting). If anyone will reply, please feel free to answer in Dutch. I hope this will not disturb any forum policies.
Main Issue: Sync recording between Tuner and DVD recorder.
Tuner: Pace Puma TD450.
Just downloaded the latest software 1.8.7. The tuner has EPG fucntionality and you can choose programs to record with timer function, so it will send a signal to the recorder or VCR to start recording on a chosen program and time. You can choose to record via the Scart to TV or Scart to TV2/VCR. I have two Scart cables connected (GOLD) to TV and DVD Recorder. The TV Scart is set to RGB (can also composite) and the TV2/VCR Scart is set to Scart/S-Video (can also composite). RF Module is set on TV and TV2/VCR. The audio is PCM.
DVD Recorder: Sony HX710s.
This recorder has a Sync Rec option which you need to activate as well as have the channel chosen to record from (L3 Scart TV2/VCR) chosen. I have followed all instrcutions to set this up correctly.
Detail of issues:
DVD Recorder and Tuner set up to "communicate to eachother". I have practically followed all scenarious by choosing different video defintions etc. I only use Scart cables. I do though can play DVD and record any film I have on the present moment I choose to record (so instant recording). I can see TV channel through the L3 line on the DVD recorder. Now I am not sure that I am recording instantly from TV or directly from tuner. So it seems that I can see the second channel from Tuner to DVD recorder, but not record. When choosing the Syn Rec option I loose the view of channel.
Anyone who can help?
Thanks in advance
Krgds
Eric
Our policy is to have all topics in Dutch.. If you can't write Dutch you better use an international forum.
Regards,
Murdock
moderator.
Receiver: VU+ Solo 4K
Gast
