[7000] SKY freezes met CCcam 1.6.1 weer terug
Hoi,
In het verleden heb ik met de 1.2 serie erg veel problemen gehad met regelmatige freezes van SKY (lokale smartcard). Na de intro van 1.3, en later met 1.4 had ik er geen problemen mee, maar nu met 1.6.0 en 1.6.1 zijn ze weer terug.
Een debug log laat zien:
Code:
21:35:21.350 CCcam: cam[0] ecm even ok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.1818 seconds)21:35:29.276 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:31.442 CCcam: local ecm <- card /dev/sci0 error21:35:31.442 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:31.442 CCcam: local ecm <- card /dev/sci0 failure from cache21:35:31.443 CCcam: cam[0] ecm odd nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 2.1673 seconds)21:35:31.478 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:31.478 CCcam: local ecm <- card /dev/sci0 failure from cache21:35:31.479 CCcam: cam[0] ecm odd nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.0010 seconds)21:35:31.584 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:31.584 CCcam: local ecm <- card /dev/sci0 failure from cache21:35:31.585 CCcam: cam[0] ecm odd nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.0010 seconds)21:35:32.447 CCcam: nds card found21:35:32.940 CCcam: nds: using boxkey ********21:35:34.315 CCcam: card added to broker with caid 96121:35:34.316 CCcam: start EMM21:35:34.641 CCcam: EMM demux 1 set21:35:34.642 CCcam: EMM: not interested in 0960:00000021:35:34.643 CCcam: EMM: start filter on nds emmpid: 0xc0 caid: 0x961 id: 0x021:35:37.392 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:37.572 CCcam: local ecm <- card /dev/sci0 error21:35:37.573 CCcam: cam[0] ecm even nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.1812 seconds)21:35:37.591 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:37.592 CCcam: local ecm <- card /dev/sci0 failure from cache21:35:37.592 CCcam: cam[0] ecm even nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.0010 seconds)21:35:37.692 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:37.692 CCcam: local ecm <- card /dev/sci0 failure from cache21:35:37.692 CCcam: cam[0] ecm even nok caid:0x961 id:0x0 pid:0x501 BSkyB (28E) (NDS) (took 0.0010 seconds)21:35:45.510 CCcam: local ecm -> card /dev/sci0 0x961(0x000)21:35:45.690 CCcam: local ecm <- card /dev/sci0 ok
Blijkbaar crashed er een proces, om 21:35:32 start er blijkbaar een nieuw proces, die de kaart weer opnieuw benaderd en dan werkt 't weer voor een half uur tot een uur. Ik moet nu elke dag CCcam preventief herstarten, omdat 't ding nu maar processen blijft bijstarten...
Iemand enig idee (of contacten met de makers <img src="/forums/images/graemlins/wink.gif" alt="" />)?
CU,
WanWizard
Hoi,
CU,
WanWizard
Geen enkel probleem hier met de CCcam 1.6.1 in dreambox 500 en 7020 (PLi Garnet)
Groetjes, Mobieltje
Af en toe blokjes is net zo ongezond. Met een locale card?
@mobieltje,
Je kaart zit dan in de 7020? En een LAN share?
Ik denk persoonlijk dat 't 'm zit in een tcp probleem, icm met een niet stabiele LAN share (wireless die vrij zwak is, en af en toe pakketten dropt).
