Ter info : HB9 / W2M launch transmission / feed
Gast Marcel Sledsens
Launch of HB9 + W2M [color:#FF0000]IN THE CLEAR on Atlantic Bird 3, next Saterday 20 December.
The launch window (according to what I know) is 21:40 to 22:40 UTC (22:40 to 23:40 Paris time).
The Rx parameters are as follows:
Satellite : AB 3 @ 5°West
Frequency : 12543 MHz
Polarisation: Horizontal
SR : 27.500 Msymbol/s
FEC : ¾ - Pal - MPEG-2 DVB
Transmissions will start at (H-3hours), where H is the opening of the window.
Therefore a signal should arrive from Kourou at: 18:40 UTC (19:40 Paris time).
there is a turn-around from AB3 (or IS-901 in C-band) to
Hot Bird (Trsp 117) at: 10.853 MHz
SR: 27.500 Msymbol/s
FEC 3/4 - PAL - MPEG-2 DVB-S
Met vriendelijke groet
Marcel
[/color]
ARIANESPACE FLIGHT - HOT BIRD™ 9 and W2M
The 186th Ariane mission will launch two communications satellites, primarily intended for direct TV broadcast services and data networks: HOT BIRD™ 9 and W2M, both for Eutelsat.
This will be the 42nd Ariane 5 launch.
The launcher will be carrying a total payload of 9,220 kg, including 8,340 kg for the two satellites, which will be released separately into their targeted orbits.
The launch will be from Ariane Launch Complex No. 3 (ELA 3) in Kourou, French Guiana.
The lift-off is scheduled on the night of december 20, 2008 as soon as possible within the following launch window:
UTC >> From 9:51 p.m. to 10:50 p.m. on December 20, 2008
PARIS >> From 10:51 p.m. to 11:50 p.m. on December 20, 2008
KOUROU >> From 6:51 p.m. to 7:50 p.m. on December 20, 2008
WASHINGTON >> From 4:51 p.m. to 5:50 p.m. on December 20, 2008
