Hier de vertaling in het Engels:
ToH 3.2 with EMU 1.2 (by HoT)
Following CAS-Systems can be now emulated:
- IRDETO/BC
- SECA mit
- SECA2 für Ident 64
- VIA
- NAGRA mit AU
- CONAX
Before installation please read the following notes:
The HDF-Datei HoTEmu****.HDF derives from the Basis firmware and the TOH-Module, like Emu. The HDF-Data will be installed with the download tool WDN40AK+.
After installation of the HDF in the Humax, input also the EmuKey-File. Also use "DSR 9500 EMU Ed23.exe".
Attention, The Hummy has to be on , and not in standby mode.
To write, use the write button. Please check with 'Read' for the first time if the written keyfile has been uploaded in the Humax.
WIN2000 users might experience problems.
After installation, one should put the Humax in Standby mode.
Now will the keyfile from the RAM be written into the Flash.
Please Note: After uploading of a new channel settings, one must reinstall the EmuKey-File. One can also use as Human from Version 0.9.9.1.
Human was written especially for the HoT-Firmware and doesn't overrule or alter the Basic Parameters any more.
Please Note: A card has always to be present in the CAM, at least untill the Card Initialising stops. It is also possible to use an official Irdeto or Betacrypte Card, which will also be opened in EMU-Mode.
TO access the Emu-Mode, please go via the ToH-Config Menu. Under 'Preselect'the following options are possible:
EMU-K (Emulator and Card):
In this mode the ECM/EMM'S as well as the EMU, go to the Card. The Card contains only ECM/EMM's through which the second known Card Irdeto are determined.
EMU-S (Emulator and Sharingserver for PW):
In this mode, a sharing server will be added in the Communication. The Connection takes place via the Seial port of the Humax.
Instructions:
1. Connect the Cardreader to PC(eg Port 1) and the Humax (eg Port 2)
2. Start CardServer
3. Settings: Add Reader, set IP 0.0.0.0 (für Server and Client am selben PC)
4. Start CardServer afresh
5. Put in the Premiere-Smartcard and check CardServer-Window
6. Start from HSIC: server-ip (=127.0.0.1) tcp-port and com-port install
7. Reset embedded HUMAX-CAM (0-RCL)
EMU (Pure EMU Mode):
This mode is not yet available. In this mode it will be possible, that EMU without inserting a card can take place.
PMCT
In the PMCT can the CAS-Systeme under EMU-K, EMU-S und EMU
serve the EMU, and write down to it. Please do not modify
  • Reacties 339
Vrij vertaald voor de "duitslektischen" onder ons.
ToH 3.2 met EMU 1.2 (by HoT)
Volgende CAS-System worden op ditmoment geemuleerd:
- IRDETO/BC
- SECA mit
- SECA2 voor Ident 64
- VIA
- NAGRA mit AU
- CONAX
Neem voor installatie de volgende regels in acht:
DE HDF-Data HoTEmu****.HDF bestaat uit de basisfirmware en de
ToH-Modules, evenals de Emu. De HDF-Data word zoals gewoolijk met de
Downloadtool WDN40AK+ ingevoerd.
Nadat de HDF in de Humax geladen is, moet ook de
EmuKey-File in de Humax. Gebruik hiervoor "DSR 9500 EMU Ed23.exe".
LET OP!!, de Humi moet hiervoor aan staan, dus NIET in Standby.
Voor het schrijven gebruik je de Button "Write". Vergewis je er bij de eerste keer van met
de button "Read", of de geschreven Key-File ook in de Humax aangekomen is. Met
WIN2000 schijnt het hier Problemen te geven.
Na het laden moet de Humax in Standby worden gezet. Pas dan word de Keyfile
uit de RAM in de Flash geschreven.
LET OP! Na het Laden van een nieuwe settingslijst moet de EmuKey-File opnieuw
geladen worden. Tenzij je Human vanaf Versie 0.9.9.1. gebruikt.
Human werd speciaal voor HoT-Firmware aangepast en overschrijft
geen Basisparameter meer.
LET OP! Destijds moest er altijd een Kaart in de interne CAM voorhande zijn,
die tenmindste de Kaarteinitalisatie bevatte. Het kan echter ook een
officiele Irdeto of Betacryptkaart gebruikt worden, die ook in EMU-Mode
voor ontsleuteling gebruikt word.
In de Emu-Mode beschikt men over ToH-Config Menu. Bij
"Preselect" zijn de volgende instellingen mogelijk:
EMU-K (Emulator en Kaart):
In deze Mode zitten ECM/EMM's zowel aan de EMU als ook
aan de Kaart. De Kaart bevat alleen ECM/EMM's die door de 2.
Irdetoherkenning van de Kaart bestemd zijn.
EMU-S (Emulator en Sharingserver voor PW):
In deze Mode word ook nog een Sharing-Server in de
communikatie betrokken. De Verbinding vind plaats via de
seriele aansluiting op de Humax.
Ga als volgt te werk:
1. Vebind Cardreader a dean PC (bijv. COM1) en Humax aan bijv. COM2
2. Start CardServer
3. Settings: Add Reader, set IP 0.0.0.0 (voor Server en Client aan de zelfde PC)
4. Start CardServer opnieuw
5. Premiere-Smartcard insteken en CardServer-Window testen
6. Starten van HSIC: server-ip (=127.0.0.1) tcp-port en com-port instellen
EMU (Pur EMU Mode):
Deze Mode is ng niet omgezet. Hier zal het mogelijk zijn, de EMU zonder dat het insteken
van een Kaart nodig is om te activeren.
PMCT
In de PMCT kan het CAS-Systeem onder EMU-K, EMU-S en EMU
die de EMU bedienen moet, ingevoerd worden. Gewoon zo laten.
HoT-Team wenst je veel plezier
Verdomme,
Kan ik mijn notebook over een paar weekjes weer mee naar Kreta nemen om daar mijn Humax weer te updaten <img src="/ubbthreads/images/graemlins/loldev.gif" alt="" />
Vandaag niets te vernaggelen aan de Dreambox, nemen wij morgen gewoon een Humax <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Grtz,
Hmm. Ik heb de ToH + EMU+K draaiend, maar krijg verder niks open ofzo (Tequila/Astra && Kiosk/Thor geprobeerd).
Weet niet helemaal 100% wat ik met m'n Fun4 moet doen ... staat een 6in1 van een paar dagen geleden op, wellicht dat dit aangepast moet worden ?
Anyone ?
Yeah, dat was ik aanvankelijk vergeten, maar toen kreeg ik ook die CAID opties niet.
Weird.
Bij nader inzien denk ik dat ik niet helemaal doorheb hoe/wat ik met die PMC tool moet doen.
Er zit een CSV bij, maar is dat de enige die je moet 'downloaden', of moet je zelf de sats in een list pleuren en die gebruiken ?
Ciao,
LAng gewacht maar toch gekregen!
hulde voor de makers!!!!!!!!!!!!!
taquilla op de astra werkt bij mij, maar kiosk op de thor niet. <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
iemand enig idee?
Vu duo2 met pli
Maak niet uit als er maar een kaart inzit voor de initalisatie
van de cam.....
En beeld op Irdeto Seca1 en 2 ID0064 viaccess en Conax..
Nagravison is AU na +/- 1 Min. beeld op de Hispasat...
Werkt als een speer.... <img src="/ubbthreads/images/graemlins/xyxthumbs.gif" alt="" />
Dreambox 7000s Moteck SG-2100, 88cm Triax.
Kan iemand via pm mij de link sturen?
Alvast bedankt
Groet
Bob
Ik heb nu kiosk ook aan de praat! zelf private gold werkt... <img src="/ubbthreads/images/graemlins/blush.gif" alt="" />
misschien belangrijk detail:
ik heb het progje emukeys 5x gedraaid, dus voor elke codering,
hierna heb ik wel beeld op de thor!
Vu duo2 met pli
