FlashWizard PRO History - coded by MusicBob
Release 5.1 PRO 29/08/2005
- Advanced Secure Install procedure for multiboot images.
This powerful procedure checks automatically the reliability of all copied files when doing a multiboot install.
If one or more files are found corrupted, then a popup window will be displayed containing a list of
non-consistant files for currently installed image. So you'll decide if continue or not:
Note: it's strongly recommended to abort installation, the image mostly won't boot if has corrupted files.
So, as I'm saying from months, the bug was definitely a squashfs 2.0 bug, this new powerful option
will show you clearly as it is.
This procedure is implemented via a patched "cp" command (took from new busybox 1.01 and modified by me),
used instead of standard one while installing.
If no popup window is shown during install, you are now sure of a perfect result.
If corrupted files are found, simply try to reinstall the image a second time.
Even better, do first a full reboot of your dreambox:
it has been proved, during tests, that error rate is by far less after a complete reboot.
- Quick FTP
On SmartTelnet Window, you can now find a quick drag-and-drop FTP client, very comfortable for most operations.
You can just drag and drop your files from Windows desktop to the needed panel, each one will FTP the dropped
file(s) on the stated directory (the most used places on dreambox, like /var/tuxbox/plugins - /var/bin - /tmp ...)
In addiction, you can specify the file attributes after FTP transfer, also if the destination file will be
deleted before FTP, plus an option to change (cd) automatically SmartTelnet to the FTP dir after the transfer.
Two customizable FTP panels are provided too. Enter there your preferred FTP dir ;-)
Actual version does NOT support directory transfers, only one or multiple selected files can be dropped.
- actualized Advanced SmartSettings Copy
The latest config variables are now updated for SmartSettings Copy parser, including teletext cache, samba on/off,
audio channels priority (thanks redneck :-), saved mountpoints NFS or CIFS.
- Kill enigma before flash install
A killall command is issued to exit enigma before installing an image in flash memory, stopping most dreambox
processes, load and activities, to avoid install problems.
Note: it is always recommended to leave it ON.
- New Boot menu 1.5
NFS install procedure is enhanced and fixed, hopefully now always working on all connected hardwares.
- Automatic /hdd/epg.dat files delete at boot
A workaround for actual Enigma epg cache bug.
When you boot a different image than the last booted one, automatically epg cache files are deleted
from your hard disk, avoiding enigma to crash on startup.
- Support for localized charsets
Long awaited feature... you can choose the Character set most suitable for your Country (in language file):
# DEFAULT the default charset
# SHIFTJIS Japanese shift-JIS characters.
# HANGEUL Korean characters (Wansung).
# JOHAB Korean characters (Johab). Not available on NT 3.51
# GB2312 Simplified Chinese characters (mainland china).
# CHINESEBIG5 Traditional Chinese characters (Taiwanese).
# GREEK Greek characters. Not available on NT 3.51.
# TURKISH Turkish characters. Not available on NT 3.51
# VIETNAMESE Vietnamese characters. Not available on NT 3.51.
# HEBREW Hebrew characters. Not available on NT 3.51
# ARABIC Arabic characters. Not available on NT 3.51
# BALTIC Baltic characters. Not available on NT 3.51.
# RUSSIAN Cyrillic characters. Not available on NT 3.51.
# THAI Thai characters. Not available on NT 3.51
# EASTEUROPE Includes diacritical marks for east european countries. Not available on NT 3.51.
- and...
as ever, some other little updates and fixes, not so many this time, to be honest :-))))
Download op Sjerom...
Hemertje.Dreambox Webmaster
Sat-nerds Moderator
Plinux Member
Bedankt Hemertje ,
Ga hem direct testen of ie het ook met m'n eigen werkjes het doet <img src="/forums/images/graemlins/smile.gif" alt="" />
RuKo <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
kan deze over de vorige versie heen worden geinstalleerd of gelijk maar geheel opnieuw met de nieuwste CS, moet je toch opnieuw beginnen. <img src="/forums/images/graemlins/smirk.gif" alt="" />
Ik bedoelde eigenlijk op de dreambox, maar bij starten van de nieuwe versie vertelde FWP zelf dat er een oudere versie op de box stond en ging deze spontaan updaten, werkt prima. <img src="/forums/images/graemlins/xyxthumbs.gif" alt="" />
ja dacht ik ook, maar wordt helaas nergens vermeld.
staat alleen dat ie voor de 7000 is, ipv 70x0.
gelukkig is er ook DCC en die kan wel met de 7020 omgaan, maar is qua multiboot niet compatible met FWP.
Ziet er toppie uit <img src="/forums/images/graemlins/cool.gif" alt="" />
Al ff gezocht via google maar niet kunnen vinden . <img src="/forums/images/graemlins/confused.gif" alt="" />
Kan iemand mij een PM geven met een linkje ? <img src="/forums/images/graemlins/confused.gif" alt="" />
Thks
Fred
Hi,
Bij Sjerom te downloaden of vanuit versie 5.0.
Greetz
John
Hi,
Greetz
John
Of Hier
Dreambox DM7000S, Echostar 2200 2CI, Skystar 2.
Schotels: Triax 88 CM + DiSEqC Stab HH100 Rotor, Fixed Triax 66 CM.
Toch een bug gevonden.
Ik gebruik GOTO-X maar met Smartcopy had ie toch 3 rotor-sat-posities gevuld.
M'n rotor bleef heen en weer draaien na boot en ik had dus geen beeld op Astra.
Na wissen van die 3 posities (max eve goto-X vinkje weggehaald), was het probleem opgelost.
