Gast Geplaatst: 10 september 2005 Geplaatst: 10 september 2005 Voor de liefhebbers Gemini Projekt 2.20 var fix gefixt : var auslagern funktioniert jetzt treiber : 09.09.05 neu : Dreamnetcast im BP nfs Server ecm_info auch als Experten modus OGG Dateien können abgespielt werden und OGG info und aus dem cvs rds radiotex rest siehe 2.20 DMM 7000 Beschreibung Based on DMM 1.09.1 Technical info: Enigma from 28.08.2005 gcc 3.4.4 Original CVS Web Interface: 5.0.3 BLUE Button - Blue Panel YELLOW Button - Quick-Button (can be adjusted over BluePanel) AUDIO Button - Audio Selection TEXT Button - Videotext RED Button - EPG List for the current channel 2x RED Button - Double Click for EPG Style Menu GREEN Button – Subservices Features: * AutoCam: Emus can be linked to Channel/Provider * CamName: Renaming of Emus * OSD: EMM- & ECM-indicator * Record CIFS: Recording on a harddisk mounted via CIFS (only available if there is no hdd in the box) * Record NFS: Recording on a harddisk mounted via NFS (only available if there is no hdd in the box) * Quick-Button: permanently showing the clock, freeze image or zapping to a predefined channel can be assigned * Addons: available via Internet or manual installation * DreamInfo: many additional information of the Box (e.g. HDD-Temperature, Enigma Settintgs) * Extra Menu: Settings for additional components like Inadyn, HTTPD, EPG-Cache or swap-out of /var) * MP3: Random feature * Gemini-News are loaded in a background process * BusyBox v1.01 * smbmount * JPEG-Pictures can be rotated and EXIF-Tags can be shown * Support for CD-/DVD-ROM, multiple HDDs and USB-Sticks NFS/CIFS in Timermenu only, if mount changed successfully, there is a size inquiry now, if storage capacity in NFS/CIFS mount bigger than 3GB and /mnt/hdd mount is bigger than 3GB it will be shown in Timermenu; like always, it functions without a mounted HDD only! Please mount now PC-harddisk to /mnt/hdd !!! Warning Image functions with FrontProcessor v1.6 only, because there are newest drivers included in CVS !!! Kan downloades HIER
Tonskidutch Geplaatst: 10 september 2005 Geplaatst: 10 september 2005 net als hier dus. is al beschreven dus en gelinked.. maar toch bedankt. cheers <img src="/forums/images/graemlins/smirk.gif" alt="" /> Theme From The Monkees The Monkees
Gast Geplaatst: 10 september 2005 Geplaatst: 10 september 2005 Citaat: net als hier dus. is al beschreven dus en gelinked.. maar toch bedankt. cheers <img src="/forums/images/graemlins/smirk.gif" alt="" /> ups sorry
