[500S] Interne tuner start niet op bij Pli-images
Beste Dream gebruiker,
Ik heb een probleem met een van mijn D500.
Met de standard img werken de FTA zeker (dus de dreambox box werkt)
Als ik de laatste of voor laatste img van Pli er in zet werkt de interne tuner niet.
zie log file::::
01:00:20.250: ------------> changed! 0
01:00:20.250: [TUNE] tuning to 12342935/27502464/H/3@192
01:00:20.403: set continuous tone OFF and voltage to 13V
01:00:20.505: set continuous tone OFF and voltage to 13V
01:00:20.750: Horizontal
01:00:20.751: Hi Band
01:00:20.751: DiSEqC Switch cmd = 00f3
01:00:20.751: 1 DiSEqC cmds to send
01:00:20.751: no Toneburst (MiniDiSEqC)
01:00:20.884: FE_SET_FRONTEND OK
01:00:20.884: <-- tuned
01:00:20.884: [ENIGMA_DYN] lockWebIf = 0
01:00:20.888: [ENIGMA] starting httpd
01:00:20.889: [NET] httpd server started on port 80
01:00:20.900: activate enigma serial http interface
01:00:20.901: [ENIGMA_MOUNT] automountMountPoints...
hdparm: /dev/ide/host0/bus0/target0/lun0/disc: No such file or directory
01:00:20.933: [ENIGMA] ok, beginning mainloop
01:00:20.934: + (54) wizard: tv system
01:00:20.934: tvsystem already selected.. do not start tvsystem wizard
01:00:20.934: + (55) wizard: language
01:00:20.935: + (56) wizard: fpudate
01:00:20.935: + (57) wizard: timezone
01:00:21.015: Dont run Timezone Setup.. timezone is already selected
01:00:21.101: waited for child 144
01:00:21.103: [eZapTimeZoneSetup]: couldn't set /share/zoneinfo/CET as /var/etc/localtime: No child processes
01:00:21.107: + (58) wizard: scan
01:00:21.107: reached rl 75
01:00:21.111: [DHCPC] info, udhcpc (v0.9.9-pre) started
debug, Sending discover...
debug, Sending select for 192.168.1.180...
info, Lease of 192.168.1.180 obtained, lease time 259200
01:00:21.120: [DHCPC] route: SIOC[ADD|DEL]RT: No such process
01:00:22.219: [FE] evt. failure
01:00:22.229: FE_SET_FRONTEND OK
01:00:22.230: [color:"red"] [/color] [TUNE] tune failed
01:00:22.244: write servicenum to led-display
01:00:22.259: creating new font color cache entry 10424268 .. 10d6a556
01:00:23.577: [FE] evt. failure
01:00:23.587: FE_SET_FRONTEND OK
01:00:23.587: [TUNE] tune failed
01:00:23.589: write servicenum to led-display
01:00:24.871: [FE] evt. failure
01:00:24.882: FE_SET_FRONTEND OK
01:00:24.882: [TUNE] tune failed
01:00:24.883: write servicenum to led-display
01:00:26.166: [FE] evt. failure
01:00:26.176: FE_SET_FRONTEND OK
01:00:26.177: [TUNE] tune failed
01:00:26.178: write servicenum to led-display
01:00:27.461: [FE] evt. failure
01:00:27.471: FE_SET_FRONTEND OK
01:00:27.472: [TUNE] tune failed
01:00:27.473: write servicenum to led-display
01:00:28.756: [FE] evt. failure
01:00:28.756: [color:"red"] [/color] [TUNE] tuning to 12342935/27502464/H/3@192
01:00:28.908: set continuous tone OFF and voltage to 13V
01:00:29.037: set continuous tone OFF and voltage to 13V
01:00:29.282: Horizontal
01:00:29.282: Hi Band
01:00:29.282: DiSEqC Switch cmd = 00f3
01:00:29.283: 1 DiSEqC cmds to send
01:00:29.283: no Toneburst (MiniDiSEqC)
01:00:29.425: FE_SET_FRONTEND OK
01:00:29.426: [TUNE] tune failed [color:"black"] [/color]
01:00:29.427: write servicenum to led-display
01:00:30.709: [FE] evt. failure
01:00:30.720: FE_SET_FRONTEND OK
01:00:30.720: [TUNE] tune failed
01:00:30.722: write servicenum to led-display
01:00:32.004: [FE] evt. failure
01:00:32.015: FE_SET_FRONTEND OK
01:00:32.015: [TUNE] tune failed
01:00:32.016: write servicenum to led-display
01:00:33.299: [FE] evt. failure
01:00:33.309: FE_SET_FRONTEND OK
01:00:33.310: [TUNE] tune failed
01:00:33.311: write servicenum to led-display
01:00:34.594: [FE] evt. failure
01:00:34.604: FE_SET_FRONTEND OK
01:00:34.605: [TUNE] tune failed
01:00:34.606: write servicenum to led-display
01:00:35.889: [FE] evt. failure
01:00:35.899: FE_SET_FRONTEND OK
01:00:35.899: [TUNE] tune failed
01:00:35.901: write servicenum to led-display
01:00:37.182: [FE] evt. failure
01:00:37.183: [TUNE] tuning to 12342935/27502464/H/3@192
01:00:37.335: set continuous tone OFF and voltage to 13V
01:00:37.464: set continuous tone OFF and voltage to 13V
01:00:37.710: Horizontal
01:00:37.710: Hi Band
01:00:37.710: DiSEqC Switch cmd = 00f3
01:00:37.710: 1 DiSEqC cmds to send
01:00:37.710: no Toneburst (MiniDiSEqC)
Het ziet er na uit dat hij de tuner wel wil starten maar dat het niet gaat....
Hebben jullie misschien een oplossing
Grt Frank
je conclusie is misschien voorbarig...
wat had je erop als officieel image
en
wat heb je der (en ook hoe) nu op gezet?
een factory reset zal bij menige overstap van officieel naar cvs image <img src="/forums/images/graemlins/grin.gif" alt="" /> helpen
cheers
He's Sailing
'Jon & Vangelis
en vooraf bij dreamup een erase opdracht gegeven?
uh o ah dat is niet bij elke dreamup een optie zie ik nu.
ik zou dus enkel per nulmodem flashen met dm 500 en dreamup.exe (netwerk uit)
en meteen na aansluiten en de eerste drie setup vragen via menu exit exit exit een factory reset doen bij instellingen.
als je er niet uitkomt, kun je altijd nog een ander image proberen, maar ik denk dat de Pli er met nulmodem en dreamup goed op moet kunnen draaien,
je hebt toch ook wel tijdens flashen alle overige kabels ontkoppelt he?
cheers
He's Sailing
'Jon & Vangelis
Ik de erase opdracht gegeven.
Ik heb ongeveer 30x een dream 500 15x een 7000 en 1x 600 geflasht.
zonder problemen dit is de eerste keer met problemen.
Ik denk dat ik maar eens een keer Gemini ga proberen.
Grt Frank
Of een backup terug van een werken de 500 Hmmmm
Grt Frank
dan kan het misschien de bron zijn waar een image gedownload net niet de checksum haalt..
had je dat ook al eens bekeken.
ik geloof niet dat je tuner zo maar niks meer wil
en
ik geloof niet dat het standaard procedere, flashen per dreamup zo'n ellende levert als het image van formaat is.
de officiele
de cvs
de boxman
de alternatieve - Pli, fixy&foxi en Gemini voor dm 500
moeten alle dm 500 modellen netjes kunnen aanzwengelen
het wisselen tussen de een en de ander kan een enkele keer een probleempje geven maar niet als je dreamup per nulmodem doet en erase.
cheers
He's Sailing
'Jon & Vangelis
