wammeswaggel Geplaatst: 24 juni 2010 Geplaatst: 24 juni 2010 Launch window: From 11:41 p.m. to 12:45 a.m. in Paris, on June24/25. Ik ga naar bed. Bye, bye. Mvg, wammes. Ik lees veel dus ik hoef niet veel te posten.
bramj Geplaatst: 25 juni 2010 Auteur Geplaatst: 25 juni 2010 Bron : Arianespace June 24, 2010 – Ariane Flight V195 Tonight’s dual-payload Ariane 5 mission with the Arabsat-5A and COMS satellite passengers was postponed following a “red” indication for the Spaceport’s launch infrastructure that occurred during the final countdown. The heavy-lift Ariane 5 ECA and its two payloads remain in a safe standby mode on launch pad. A new launch date will be announced as soon as possible.
Ou-Tannu Geplaatst: 25 juni 2010 Geplaatst: 25 juni 2010 dacht ik afgelopen nacht ook maar.. k had op den duur zo iets van.. als die gaat.. dan gaat tie maar :') en anders zie ik binnenkort wel weer eens Philips LNB, 60cm pan, HVR-5500 DVB-S/S2/C/T, Cinergy HTC stick DVB-C/T, FS DVB-T stik HVR-5500 -> CDS/TVV / Ziggo Digitaal Cinergy HTC -> Ziggo Digitaal / FM FS DVB-T -> Digitenne
bramj Geplaatst: 26 juni 2010 Auteur Geplaatst: 26 juni 2010 Poging 3. bron : arianespace ARIANESPACE FLIGHT - Arabsat 5A & COMS Liftoff is set for Saturday, June 26, 2010 Kourou, French Guiana, June 26, 2010 In the two synchronized sequences performed during the launch countdown on Thursday, June 24, an atypical pressure value was observed in the pressurization system of Ariane 5’s cryogenic main stage. After precise analysis of this phenomenon, and complementary checks were carried out, Arianespace has decided to resume final countdown operations for Flight 195 with the Arabsat-5A and COMS satellite payloads. Liftoff of the Ariane 5 launcher is now set for the night of Saturday, June 26, as early as possible in the following launch window: >> From 6:41 p.m. to 7:52 p.m., local time in Kourou, French Guiana >> From 5:41 p.m. to 6:52 p.m. in Washington, D.C. >> From 9:41 p.m. to 10:52 p.m. UTC. >> From 11:41 p.m. to 00:52 a.m. in Paris, on June26/27. >> From 00:41 a.m. to 01:52 a.m. in Riyadh, on June 27. >> From 06:41 a.m. to 07:52 a.m. in Seoul, on June 27.
bramj Geplaatst: 26 juni 2010 Auteur Geplaatst: 26 juni 2010 En weer een test uitzending op 5 west 12543 h 3/4 27500 4.2.0
klaas Geplaatst: 26 juni 2010 Geplaatst: 26 juni 2010 Inmiddels is de uitzending begonnen (tevens in meerdere talen beschikbaar). Dank voor de melding, dit ga ik ook volgen. Dm8000-Newnigma \\ Big-Bisat \\ West: 5/0,8 Oost:4,8/9/13/19,2/23,5/28,2/42 \\ Ziggo
hvdh Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Arabsat 5A is sinds gisteren in gebruik genomen, op 30,5 Oost. De Ku-Band Pan-ARAB FSS footprint reikt ook een beetje in onze richting, zie hier. Vele feeds zijn door anderen al gevonden tussen 12500 en 12750 MHz, meestal verticaal. Ik kan er met 100 cm tot dusver nog maar één goed ontvangen: 12574V 3000 "MAJD 1". Dr.HD F16, TBS 5927, ET 8500, T-55 voor 9/13/19/23/28/39/42/45°O, Technisat 52/53°O, Laminas 120cm 1°W...68°O.
Feedhunter Rini Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Reported by Feedhunter Rini on 2010-07-21 05:14 pm 0 Comment moet 30.5 E Frequency: 12528 - Pol: H - SR: 27500 - FEC: 3/4 Category: Mire / Test card Transmitted in: MPEG-2 4:2:0 (PAL) Comments: card ID Kuwait Feed I work with: Technomate TM 5402 HD M3 CI super+, or Dr HD F 15, or Clark Tech HD 4100 plus, or VU+ Duo or DVB/Dream DVB met TBS 5980 USB DVB S2 TV Q Box CI and a 110 c.m. Triax dish with quad 0.3 Invacom LNB and a DiseqC 1.2 Motorized H-H Moteck Motor
Feedhunter Rini Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Reported by Feedhunter Rini on 2010-07-21 05:21 pm 0 Comment Arabsat 2B (30.5°E) Frequency: 12739 - Pol: H - SR: 3000 - FEC: 3/4 Category: Newsfeed Transmitted in: MPEG-2 4:2:0 (PAL) Comments: woman ID amman sng I work with: Technomate TM 5402 HD M3 CI super+, or Dr HD F 15, or Clark Tech HD 4100 plus, or VU+ Duo or DVB/Dream DVB met TBS 5980 USB DVB S2 TV Q Box CI and a 110 c.m. Triax dish with quad 0.3 Invacom LNB and a DiseqC 1.2 Motorized H-H Moteck Motor
hvdh Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Rini die 12528H 27500 is die op 30,5 oost, of de Koewitse transponder op 26 Oost? En in je bericht staat Eutelsat W1 (10 Oost). Dus dit snap ik even niet! Dr.HD F16, TBS 5927, ET 8500, T-55 voor 9/13/19/23/28/39/42/45°O, Technisat 52/53°O, Laminas 120cm 1°W...68°O.
Feedhunter Rini Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 foutje heb ik veranderd. Kan jij kijken of mijn schotel eventueel verkeerd staat. wel 28.5 E mar geen 30.5 E Ik hoor het wel Rini I work with: Technomate TM 5402 HD M3 CI super+, or Dr HD F 15, or Clark Tech HD 4100 plus, or VU+ Duo or DVB/Dream DVB met TBS 5980 USB DVB S2 TV Q Box CI and a 110 c.m. Triax dish with quad 0.3 Invacom LNB and a DiseqC 1.2 Motorized H-H Moteck Motor
hvdh Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Rini ik denk inderdaad dat je schotel op 26 Oost stond, beide frequenties staan bij Flysat op 26 Oost vermeld. Je gebruikt geen USALS zeker? Dr.HD F16, TBS 5927, ET 8500, T-55 voor 9/13/19/23/28/39/42/45°O, Technisat 52/53°O, Laminas 120cm 1°W...68°O.
Feedhunter Rini Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Hi hvdh Neen ik gebruik geen USALS . Ik moet hem handmatig vastzetten in mijn FIBObox. Dus het is 26 oost/ Ga ik weer verder zoeken Bedankt en Groeten Rini I work with: Technomate TM 5402 HD M3 CI super+, or Dr HD F 15, or Clark Tech HD 4100 plus, or VU+ Duo or DVB/Dream DVB met TBS 5980 USB DVB S2 TV Q Box CI and a 110 c.m. Triax dish with quad 0.3 Invacom LNB and a DiseqC 1.2 Motorized H-H Moteck Motor
hvdh Geplaatst: 21 juli 2010 Geplaatst: 21 juli 2010 Ik zie dat je ook een 1 m schotel gebruikt, dan zal het nog een lastige worden met Eurobird 1 op 28,5 Oost zo dichtbij. 12574V 3000 bereikte tussen 16:00 en 17:00 mooie quality waardes tot 52% (drempel ligt met de C-Tech rond 45%), nu is die nog maar af en toe te locken. Dr.HD F16, TBS 5927, ET 8500, T-55 voor 9/13/19/23/28/39/42/45°O, Technisat 52/53°O, Laminas 120cm 1°W...68°O.
